Turbo Swap Time!
also how do your valve springs compare to supertech or patriot? ( supertech is more and patriot is less i think)
also whats you opinion on running 72lbs valve springs instead of 78?
The ZZP Ecotec valvesprings come in right around 78lbs when running the stock retainers. Coil bind is also around .450". Switching to ZZP retainers changes the installed height approximately .025" allowing .475" to coil bind with a seat pressure of 74 lbs. The best feature of the ZZP springs is the price being almost half of the price of the Supertech kit, yet still getting the job done very well.
Stock spring seat pressure varies from car to car depending on mileage and usage. We have measured some as low as 45 lbs, while others are in the low 50s.
I wanted to give an update on the car. The car is running great! The new stage 4+ clutch feels good. The drivability is good, no chatter the tension is good with out being too stiff.
I am learning to drive the car higher in the RPM range with the new turbo and motor work. On a hard run I now need to shift around 7300 RPM's. The car pulls very strong up high in the RPM range.
I took the 245/40 18 tires from the front of my C6 and put them on the car to try to see how they fit and try for some more grip. They seem to fit good with no rubs. I have KW2 coilovers on the car so it is lowered some but no rubbing.
The tires did not give me alot more grip. The car has LSD and still spins all the way through 2nd gear. It seems to be gripping better in 3rd.
So from a 40 roll you spin for a bit but get the traction in 3rd? And daily driving wise how is it? And can you still use Launch Control and No-Lift Shift?
and that's on a mustang dyno too. I love it.
I saw a big difference in boost between Matt's car with same setup 23psi vs this car which is 28 psi. Why didn't you try higher boost levels with Matt's car?
Also, Matt was mentioning he hit fuel limitations. You said you are working with Vince and the fuel issues are solved since he unlocked the fuel table. Also you have your "mechanical HPFP mod" which allowed you to push 540whp, is there a reason that this mod was not done in this case?
The reasons I was able to get well past 500whp last fall were the larger turbo(256), ported head, and race gas.
I just got a bracket for the camera mount this morning. I will be out of town this weekend but should have something for next week.
Matt,
I do remember how you showed me to do the boost adjustment by gear. For now I am having too much fun doing 150ft long burnouts in 2nd gear!!LOL
I am going to switch to my race nitto tires and see how that works on the grip first. That will give me a good idea of what I need to do. Also since the 245/40 size is working well, i will plan on that size on my next set of tires.
The track opens for test and tune sessions in 2 1/2 weeks. I can't wait to get it back out on the road course and see what the new lap times will be.
Matt,
Just want to ask again real quick to see if anyone has some input on this:
Id imagine this kit would have you struggling for traction in third gear as well without good tires. Hell my Trifecta tune gets me loose on a 40 roll and this thing is making like 100whp more than me.
Really? Mine is rather linear. I spin a little, but not too much in 2nd. I'm on a trifecta tune and full bolt ons.
I too was looking into the cryo kit.. similar to the SRT-4 II, but does not use distilled water. What are peoples thoughts on this kit??
lol
