Where is the GM stage kit?
Old Jun 9, 2009 | 02:16 PM
  #1326
08inBama's Avatar
Originally Posted by Buzz65
Wow, still under warranty????? This part amazes me!
Ok... Can you recommend these parts? intake, dp, catback? Which do you recommend that will keep it 'under warranty'?
Cheers!
Buzz
(This is looking better the more I understand it!)
exactly, bolt-ons will now actually do something
Old Jun 9, 2009 | 02:32 PM
  #1327
Gestapo007's Avatar
does the new map sensors do anything for people already tuned?
Old Jun 9, 2009 | 02:41 PM
  #1328
drewbroo's Avatar
My question is will you be able to flash a tune over the new tune, with the new sensors, and will the car respond just as well as it does with the current sensors. Or will new tunes have to be made up for the new sensors?
Old Jun 9, 2009 | 03:40 PM
  #1329
Stamina's Avatar
No. If you want to be able to use the new sensors then you will need the Stage Kit for its OS reflash. It will rescale the MAP voltage scale so it will properly read the sensors.
Since you're keeping the same ECU, I would imagine that it would react just the same to uploading a new tune then as it does now. A new tune would be needed though to fully utilize the new sensors.
In theory, you should be able to use your old tune after the Stage Kit. The OS reflash is on the ECU OS firmware level and shouldn't affect your tune (although a new Stage Kit tune does get loaded when you get the kit). The tune doesn't read the sensors hooked up to the ECU, the ECU OS does, so you should be able to reflash your old favorite tune back over the Stage Kit tune. You would then be able to retune with the ability to go higher than the current 22.5psi or so.
Old Jun 9, 2009 | 03:52 PM
  #1330
inquisit99's Avatar
^^i have no idea what that said. don't care. i think it said "more power".
they stated 275 hp, does anyone know about torque?
Old Jun 9, 2009 | 09:39 PM
  #1331
Adrenalin9150's Avatar
I think torque is goin to be the big surprise like with basic bolt ons and stage 1 340 ish ???? give or take 10????
Old Jun 9, 2009 | 10:19 PM
  #1332
umrdyldo's Avatar
They first stated that the kit would be 290HP and 340 Torque. That's probably with intake though so Stage one should be 320HP
Old Jun 9, 2009 | 10:20 PM
  #1333
inquisit99's Avatar
just curious what the official claims were that they were putting out with the 275. i know its potential with basic add ons and whatnot.
thanks though
Old Jun 9, 2009 | 10:42 PM
  #1334
sport-o!'s Avatar
Originally Posted by hunter19707
But those kits net more than +15hp.
my thoughts exactly...
Old Jun 12, 2009 | 02:41 PM
  #1335
buellfooll's Avatar
I've re-read that GM release twenty times now and get the same thing every time. If you buy the "Stage one" kit at the end of June you will get everything BUT the new intake. If you wait the 3 more months and buy the "Stage two" kit you will get everything in the "Stage one" kit AND an intake. I read this as if you want the GM intake you have to wait three more months and then you have to buy the WHOLE PACKAGE. It doesn't say anything about buying the intake seperately, only as a complete package. I really think GMPP understands many people have already bought aftermarket intakes, CAI's and SRI's, so why make the people spend the money for an intake they really don't need. I think they're making a subtle hint and giving us an added incentive to buy our intake of choice. You'd be saving the money you didn't spend on the GM part and applying it towards the one you really DO WANT. For those that HAVEN'T bought an intake, wait and get the matched GM part with your "Stage two" kit. Actually I think they are doing us a favor. Hey DAN at CIA!! Send me a Cold Air Inlet!!
JMHO!
Old Jun 12, 2009 | 04:02 PM
  #1336
Donny Brasco's Avatar
Injen FTW!!!
Old Jun 12, 2009 | 04:03 PM
  #1337
Injen FTW!!!
Old Jun 13, 2009 | 01:17 AM
  #1338
08inBama's Avatar
are there any companies that sell JUST the elbow that goes into the BPV?
that is the most restrictive part and is really where the gains are made in a new intake system, pretty much, its what I expect "Stage II" to consist of, a new freaking elbow
Old Jun 15, 2009 | 06:50 PM
  #1339
tomj77's Avatar
http://www.gmtunersource.com/index.p...your-intake-on
check that out, they are advertising all the diff intakes u can get to go with the stage kit, i guess they do want u to get an aftermarket intake. lol the stage 1 kit with the hahn intake will make the most power according to hahns dyno sheet, 304hp and i dont know about torque
hahn 275 + 29 = 304
aem = 275 + 17 = 292
injen = 275 + 15 = 290
they dont have the dejon on there. so thats about what we'll be seeing, how nice. if those numbers are accurate that is
Old Jun 15, 2009 | 06:55 PM
  #1340
Stamina's Avatar
275 + 29 = 304
Great find
They need to get the CIA flavors up there after they completely come out.
Edit: What's interesting too is it looks like they're only going by the advertised power increases. The need to slap these on a test mule and see fo' real.
Old Jun 15, 2009 | 07:16 PM
  #1341
steven6870's Avatar
My question is WTF do you want to honestly want to push your snail past 22-23 PSI? Do you really think the K04 will hold up very long at HIGH levels?
Old Jun 15, 2009 | 07:21 PM
  #1342
tomj77's Avatar
i seriously doubt that gm is gonna run 23 psi on the upgrade. maybe 20 at most. this is the gm stage upgrade info, not another tune
Old Jun 15, 2009 | 08:40 PM
  #1343
dunit121's Avatar
so stage 1 with hahn it is but if i get the intake after the stage1 will it need to be reflashed?
Old Jun 15, 2009 | 08:46 PM
  #1344
steven6870's Avatar
Im not talking about GM. Im talking about tuning on top of GM's "tune". These sensors are to help with reading proper/higher boost levels, thus making it possible to boost higher than 22.5. I thought the actual MAP of the borg warner showed it lost efficiency after this level.
no. the tune lets you reap the benefits of aftermarket. Stage 1 is basically a canned tune from GM.
Last edited by steven6870; Jun 15, 2009 at 08:48 PM. Reason: Automerged Doublepost
Old Jun 15, 2009 | 08:48 PM
  #1345
superchargedman's Avatar
hahn 275 + 29 = 304
So, does anyone know if this will void the warranty?
Old Jun 15, 2009 | 08:49 PM
  #1346
steven6870's Avatar
aftermarket parts do not void warranty. magnum moss. they can deny your warranty claim based on anything, but just because you "mod" your car does not mean it "voids" it.
Old Jun 15, 2009 | 08:54 PM
  #1347
well, has anyone's warranty work been denied b/c of a cai?
  #1348
KillerBee's Avatar
hahn 275 + 29 = 304
I need to get me a Hahn CAI!
Old Jun 15, 2009 | 08:59 PM
  #1349
CobaltSScrazy's Avatar
so we get this at the end of june right?
Old Jun 15, 2009 | 09:02 PM
  #1350
KillerBee's Avatar
That is the word as of now!
