ZZP Fifth Injector.
At the moment there aren't any after market High Pressure fuel injectors available for the LNF so we are stuck with the techniques discussed here for the time being.
... What sounds more reasonable is making a port fueler type but running the stock manifold..... Run four injectors and they are boost referenced so they'll com in just like your kit .. because to me, running one doesn't mean all the cyclinders get the same amount of fuel. Have you guys tested the flow and egts on each cyclinder and runner?
60# Siemens High Impedance Low Profile injectors.
It was used on first twincharged LSJ and managed with an SMT-6.
That would work a whole lot better then just one...... And in fact if someone did go this way they'd prob never have a fueling issue.. what kind of stately does it use... The only issue i see with that is the atomization of the fuel since it isnt at a angle the fuel will come together sort of like a dirty Injector
that's what I'm doing....the injectors on each runner of my intake manifold will be angled around 45 degrees towards the each cylinder...........to avoid any pooling of fuel on each runner. Better atomization
Plus of course having an injector on each cylinder will ensure a better and equal fuel supply for each cylinder.
https://www.cobaltss.net/forums/2-0l...lb-min-269240/
But I guess only having 1 injector is fine....since Matt and snakescythe (?).......are using this "5th injector kit"....without any issues.
good luck cmiller.....definitely let us know your experience!!!
You sir are a smart man lol....[/B]
I have run several different setups on my car. We have posted about them on here as well. Actually, the single injector works better than 4. The reason is that either supports a lot more HP than you can make without, but the single injector comes in smoother. It also eliminates the need for specific injection timing. Depending on the frequency you run the drivers at, running port injection near the cylinder can cause inconsistent fueling from cycle to cycle of the engine. High end fuel controllers that sync with the crank posisiton to avoid this issue cost a lot more money than our fuel controller. Next you have the cost of 4 injectors vs. 1 injector. Then consider the mods to the intake manifold which runs several hundred dollars for a 4 injector system. Then there is the labor involved to remove the intake manifold to modify it or replace it.
With our 5th injector kit, you spend a lot less money and it can be installed quickly and easily without even needing to remove the intake.
...and it works great...
ZZP EFR Cobalt 60-125 - YouTube
ZZP LNF Cobalt Runs 11.01 at 136.8 - YouTube
what do you mean by "smoother"?
since the controller in this "5th injector kit"...is boost referenced...........will this injector just turns ON and OFF during a certain boost? or will it inject fuel gradually as boost goes up?
thanks!
Matt, since you both tried the single....as well as the port injection (4 injectors on each runner).........
thanks!
thanks!
By smoother, I was just refering to a setup with 4 injectors sized to flow a lot more than our single 60. If you ran 4 very small injectors, it could be brought in smooth without much hassle.
^^^ now this supports why I can't stand you..your attitude is like a 6 year old who just lost there favorite toy..... Calm your Ass down. Because a single won't be better then a four.. Have you tested the flow of fuel for each intake runner? Have you tested egts to verify each cylinder is getting the correct amount of fuel. I have tuned many cars using secondary injection. So your assuption is honestly bullshit. Putting a single injector into the manifold might give you more fuel. but to which cylinder gets more? Because If you haven't tested tour system out it can be false, it can be unreliable and ****. So I'm sorry to tell yuh, but id rather not blow a engine because of some faulty secondary injection system. And showing a vid of your car going down the track doesn't mean bull. Because we are talking about the correct atomization of fuel and to each cylinder. Not how fast your car can go.
Having one injector in the middle of the mani does not mean fueling for each cylinder will be the same
Having a secondary that runs four with injectors that have been flow tested and are good to go , then that would mean fueling to each cylinder will be closer then runnin one injector. Since the runners will have differwnt flow depending on each cylinder.
You can say what you want... Facts are facts.....
Someone should do a test with a Meth nozzle running straight blue windshield washer fluid right where this fifth injector goes to see which of the cyls gets more blue vs. the others. I think James brings up a very interesting question regarding individual cyls and how much fuel they are getting. Hell, you could take the IM off and do a test on a piece of white paper. See which runner poors more if any....
You could take off the manny, put a nozzle in the spot, place each runner over a cup. Pour one gallon of Meth in a reservoir and turn it on then measure which cup is more full...
I originally bought 4 x 70 lb injectors for my port manifold injection.
But after careful thinking about my goals and set-up............I returned the 70 lb injectors......since they'll be too much
.....and I replaced them with 45 lb injectors instead.....to make fuel injection smoother as well.
It's a lot like a tbi setup, wherein the fuel is not equally distributed to all the cylinders. This means that the air/fuel mixture injected differs for each cylinder
It can cool the manifold much faster causing the fuel to puddle and condense in the manifold. The possibility of condensation is much higher since the fuel travels mix longer to the combustion chamber
It is a wet system and the mixture of fuel is still based per cylinder
So the equal amount of fuel will never happen...... Wash cylinder will differ on fuel and air
btw, we tested these systems for over a year. Do you really think we didn't consider the situations that you come up with off the top of your head? Yes, we test egts, as well as individual knock thresholds. I use an oscilloscope to map out the injection timing of the DI injectors as well as hpfp solenoid timing and compare to cam timing, spark lead, etc. We monitor fuel pressure before and after the hpfp and compile pages of data over hundreds of dyno pulls before we decide that a product like this makes the most sense to sell in our market.
Here's a question for you- have you tested the airflow to each individual cylinder on your LNF? If not, how would you know how to scale each injector that you add to the intake runners?
lol, one could ask the same about your tunes.
