ZZP LNF Cam Testing
Old Nov 11, 2010 | 09:59 PM
Matt M's Avatar
Hopefully these will be available to purchase before spring.
Old Nov 11, 2010 | 10:32 PM
Zdeuce4's Avatar
Originally Posted by Matt M
That's a good idea. It's actually pretty easy and only takes a couple hours. You just need to be careful with the cam timing.
We should be releasing 2.4 cams as well.
YES!! im rebuilding next yr too.. nice to know ill have somethin i can pop and extra 20 whp out with possibly.
Old Nov 12, 2010 | 12:50 AM
CordiaDOHC's Avatar
Got my attention! Keep talking!
Old Nov 12, 2010 | 08:59 AM
cardelino18's Avatar
dam dam dam dam!!! i cant wait!!!!!! any ETA??? price range may be? will they have different stages as for bigger turbos, more agressive etc?
Old Nov 12, 2010 | 09:17 AM
Matt M's Avatar
I should have mentioned in my first post, but forgot- both E85 tests(stock cams and ZZP cams) were done with our added fuel rail. With the stock cams, max HP was exactly the same with DI only or 2 rail. However, the powerband was a little better with the 2 rail setup. This was because the DI system was a little past it's max. With the ZZP cams, DI only was not capable of keeping up, so all full pulls were done with 2 rails.
Old Nov 12, 2010 | 09:20 AM
FF_ace's Avatar
do you have any pics of the added rail and cams? would like to see the setup. great work zzp
Old Nov 12, 2010 | 09:23 AM
hawlyns711's Avatar
nice are the specs similar to the lsj cams? hope mine produce this much of a gain, those are some nice numbers
Old Nov 12, 2010 | 09:24 AM
BYT*SS*TURBO's Avatar
Very cool, glad to see the 2 new things you were working on paid off Def curious to see what they do for a turbo upgraded car now too!
Old Nov 12, 2010 | 09:45 AM
me waaaaaant!!!! i want the cams and fuel rail!!!!!!
Old Nov 12, 2010 | 09:48 AM
Godly's Avatar
Preorder now?
Old Nov 12, 2010 | 09:49 AM
  #36
blackvette101's Avatar
These cams are not huge by any means. They are about 8-10 degrees longer duration than stock IIRC. Lift is increased by ~.018". The tops of the lobes are a bit wider, keeping the valves vear max lift longer, which is where the majority of the gains come from.
Hey Matt any chance you guys will make race cams with something like 20 degrees higher duration for us big turbo guys looking to go over 600 whp.
  #37
do you smell GROUP BUY!?!?!?!?!
Old Nov 12, 2010 | 09:52 AM
  #38
FF_ace's Avatar
im totally in. this would be nice since im building my motor here soon and going bigger turbo
  #39
ooohh and matt how is the cold start with those cams?
Old Nov 12, 2010 | 09:56 AM
  #40
Supercharged Guy's Avatar
I wish they were
I need them in time for my big turbo setup which will be before april so hurry guys lol
Old Nov 12, 2010 | 12:34 PM
  #41
FrossB's Avatar
Thread Killer
sub'd
Old Nov 12, 2010 | 12:57 PM
  #42
Perfect.disguise's Avatar
Will you be bringing this car back to the strip on the stock turbo?
Old Nov 12, 2010 | 02:35 PM
  #43
PrincessTurbo's Avatar
Do you project this to be tested with the big turbo any time soon ?
Old Nov 12, 2010 | 02:38 PM
  #44
cmiller8006's Avatar
I think we will see big turbo numbers before spring.
Old Nov 12, 2010 | 03:12 PM
  #45
RoadconeTuning's Avatar
lol, i doubt most people are going to be running a cat with these cams... not exactly emissions friendly im betting.
Old Nov 12, 2010 | 04:40 PM
  #46
cubaniche's Avatar
Damn...lol...I somehow thought it was by a miracle that they got the cams working with the stock fuel rail. Oh well. I want to see what the double rail looks like and how it works.
Old Nov 12, 2010 | 04:54 PM
  #47
The stock rail should work fine on 93 oct.
Old Nov 12, 2010 | 05:26 PM
  #48
elecblue06's Avatar
they say they use the double rail for the cams i think
Old Nov 12, 2010 | 05:33 PM
  #49
cubaniche's Avatar
Yeah its just a couple posts up. MattM said the cams on 93 stock rail would have run out of fuel....???
Old Nov 12, 2010 | 05:57 PM
  #50
Look again, he said that for E85, never mentioned 93.
