ZZP LNF IC is Getting Closer!
Welllll...it says $399 on their website...and that it should be ready for delivery in July.
http://www.zzperformance.com/cobalt_...1185&catid=187
I have the Synapse IC, and the ZZP does look much nicer, but it does not hang down 1-1.5" on my car...maybe a .5" at most, and I could bring it up a tad more. If you're lowered you just have to be extra careful not to bang the front end off the ground or when pulling into parking spots b/c you always see way too many people with their front end mashed up onto the curb.
Good deed sir.
First batch will be at least 100.
$399 is not 100% yet, but I think we can get them in that range.
I have one mounted on my car, but you can't see it very well with the grill. We would like to put one on an LSJ sometime soon.
I wish it was faster as well. These slow process product developments turn out very nice, but we miss a lot of sales due to not having them in stock yet.
I'm just trying to make out how much is tucked behind the cover. my core rite now is about an inch to tall for my likes, but its also mounted it up a bit more then this.
I'm definitely in line to buy one of these, i'm just curious to compare its fitment vs what i have now.
also, is anodizing possible?
thanks.
any chance we could get a pic of just the front end of your car? upclose?
thanks.
thanks.
I have seen a few problems with the Stage kit lower sensor being an issue. You might want to install the new sensor and check for clearance issues around the A/C line. It seems to be a common problem. The Charge pipe is just too high.
Not sure if this can be fixed or not, just giving a heads up.
I have the crazy steve intercooler and it's too close, but I found a solution on mine
Hey ZZP, can you test something (if you already haven't)?
