ZZP Silicone Couplers
Old 07-17-2014, 10:33 PM
SECRETARIAT's Avatar
Has anyone used these silicone couplers from ZZP
ZZPerformance - LNF Replacement Silicone Couplers #ZZ-LNFSILCP
and how were they ?
Easy to install ?
I trust the 90 degree piece replaces the rubber piece that comes off the turbo ?
How is the "band clamp" that joins the rubber elbow from the turbo to the plastic piping at the top removed ?
I've heard this could be a good improvement because the stock rubber elbow could expand during high boost causing loss of velocity.
Sorry for the basic questions, but I'm new to the turbo world and couldn't find just a coupler replacement thread in the How-To section.
Thanks for any help.
Old 07-18-2014, 12:13 AM
imSLAYER666's Avatar
I don't know of any part from ZZP that cannot be trusted. I am sure you will have no problems buying any part from them.
Old 07-18-2014, 12:29 AM
Yep, I just installed their upgraded intake tube yesterday, no problems.
Anyone know if replacing the upper rubber coupling will improve performance ? And how the stock band clamp is removed that joins the rubber coupling to the plastic charge pipe ??
Old 07-18-2014, 12:40 AM
Youre not going to notice anything different. The zzp parts are just higher quality.
Old 07-18-2014, 12:51 AM
Dust SS's Avatar
install pretty easy. only thing is the lower stock coupler was pretty tight onto the intercooler. and for the lower one youll wanna be under the car
Old 07-18-2014, 01:09 AM
Thx
Old 07-18-2014, 05:08 AM
tuned08ss's Avatar
The couplers work great. Mine has held boost better than the stock ones.
Old 07-18-2014, 05:15 AM
What exactly do you mean, they've held boost better than the stock ones ?
Thx
Old 07-18-2014, 08:09 AM
tomj77's Avatar
They replace the stick couplers, are same as stock except silicon . I got them. Work good. I got the Zfr one, that one is a pain to keep on the turbo, u don't do it just right it pulls out from the tbolt while u tighten and pops off after a few pulls.
Old 07-18-2014, 08:54 AM
slapbetcommissioner's Avatar
Never had a problem with the stock couplers.
If you want an uograde replace the pipes and the couplers. More of a quality improvement mod then a power mod but looks nice under the hood. I wouldn't bother cutting the banding off a shirty plastic pipe to upgrade the couplers which aren't a problem. The pipe is what needs the upgrade.
Old 07-18-2014, 12:15 PM
tomj77's Avatar
Agreed with slap, don't upgrade ur couplers unless u have to. I had to that's why I did. If u don't have to spend the money on something else
Old 07-18-2014, 12:28 PM
tuned08ss's Avatar
I agree. I also had to
Old 07-22-2014, 10:58 PM
I bought them for peace of mind.
Old 12-13-2014, 09:27 PM
Hey guys well i have my couplers since i got the intercooler package from zzp my question is they seem like they have dirt inside like they where in the same place for years and dust just collect it. What should i clean it with? Im thinking just plain water. Also im sure once im getting to installing ill figure out but for now i would like to know what coupler goes connected to what? And last question if i install the intercooler without a tune would it be fine? I know i wont see much of a benefit
Old 12-14-2014, 01:55 AM
tomj77's Avatar
just just soap and water,
Old 12-14-2014, 03:19 AM
Thanks tom. Any idea on what coupler goes to what if both are for the hot side or 1 for cold and 1 hot?
Old 12-14-2014, 05:13 AM
footballplaya3k's Avatar
Doesn't matter.
Old 12-14-2014, 08:34 AM
sam1031's Avatar
When i got tuned the stock couplers kept blowing off the upper charge pipe at the ic. Got the zzp silicone couplers with new t bolt clamps and it's been fine ever since. Highly recommend these.
Old 12-15-2014, 01:11 PM
GreenySC2's Avatar
are the couplers really needed for the intercooler install or can you go without them?
Old 12-15-2014, 07:58 PM
sam1031's Avatar
It'll make life a lot easier and will hold better under pressure. Plus you dont need to worry about cutting the stock upper charge pipe couplers.
Old 12-15-2014, 08:39 PM
GreenySC2's Avatar
sup pretty much I should order the couplers if I get the IC off someone else?
sorry for the thread jack after an answer please return yup regularly scheduled topic
Old 12-16-2014, 02:45 PM
sam1031's Avatar
I would, its definetly worth it. Looks much better too besides the fact that they work 10000x better than the stock couplers.
Old 12-17-2014, 07:17 PM
GreenySC2's Avatar
options to paint an IC?
just regular paint or powder coat?
05-28-2022 03:47 AM
01-12-2016 12:01 AM
no_ss
10-18-2015 11:58 PM
justinchinn
10-02-2015 12:18 PM
jimbofug007
10-02-2015 12:06 PM
Quick Reply: ZZP Silicone Couplers
