108 Octane boost
Old Dec 21, 2006 | 07:24 PM
rallyracer's Avatar
108 Octane boost
A friend gave me some Turbo Octane Boost 108 for a gift and Im just wondering if anyone has ever used something like this in a 2.0 Supercharged Cobalt?
Does it add power?
Will it mess with my CEL?
Is it bad for our cars?
etc...
This is a pic of the can.
Old Dec 21, 2006 | 07:27 PM
diablo2007's Avatar
i always run that type of stuff in my bikes and my jeep it doesnt really do anything in my jeep but it does in my bikes i think cause its less fuel to be adding to
Old Dec 21, 2006 | 07:32 PM
red_wing_2121's Avatar
Octane does not affect power. The octane required is determined by timing settings and combustion chamber temperatures.
Old Dec 21, 2006 | 07:37 PM
rallyracer's Avatar
So are you saying that this product does nothing for our cars?
Old Dec 21, 2006 | 07:39 PM
It may be ok to run in them, but it will not give you more power.
High octanes are for performance engines (not factory) with really advanced timing and high combustion temps. I made a thread about octane a while back, but I will have to search for it. I will post link if I find it.
Old Dec 21, 2006 | 07:52 PM
aavery's Avatar
i posted this in my regional post, my father races speedway there motorcycles , they run on methonal so i have a good knowleged about engines on methonal, for the stage 2 cobalts the compression under full boost must be around 12.5 -1 or higher it claims factory 9.5 - 1 but the boost creates artficial compression esspecially with the stage 2, now with higher compression we want more octane so with stage 2
100+ octane would be good, but so this fuel i found intresting, you can buy methnol at Canadian tire. They even make special oxygenated methonal, but that another thread
What are some of methanol's characteristics?
M85 (85 percent methanol and 15 percent unleaded gasoline) has an octane rating of 102, compared to 92 for premium unleaded and 87 for regular unleaded gasoline.
M85 showed a 50 percent reduction in total toxic air pollutants suspected or known to cause cancer (including acetaldehyde; benzene; 1,3 butadiene), when compared to gasoline.
here lays the problem this amount of methonal runs cooler then conventional gas.
so plugs will have to be hotter, timing will need to be retared, and more compression is better.
i know this is really long but i am looking for input from you guys
so i am thinking mill the head/after market pistons
hotter plug
just trowing i out there
Old Dec 23, 2006 | 08:15 AM
mattyfinch's Avatar
What are you smoking?
In a boosted vehicle, octane greatly determines power #'s
Running 108 octane allows the car to run more efficiently, allowing for better performance, HOWEVER, it also its self reacts a larger hotter reaction in the chamber, creating more horsepower.
wow.
Old Dec 23, 2006 | 01:32 PM
an0malous's Avatar
gonna have to dissagree with this too.
another situation is, if your car runs some knock....your engine will be pulling timing, and therefore losing some power.....(btw i personally believe all stage 2 cobalts have some knock in cold weather)
and if you put higher octane, your computer wont need to pull any timing, thereby allowing full power
Old Dec 23, 2006 | 01:41 PM
SuperCobaltSS's Avatar
i have tried that stuff before, it does NOTHING! the only thing it helps with is if u put like 87 in your car and you need to bump it to like 92 or so
Old Dec 23, 2006 | 05:37 PM
an0malous's Avatar
What kind of engine monitoring do you have.
how do you know it did "nothing"
Old Dec 23, 2006 | 05:56 PM
Cause i ran the same Quarter mile times Coulda been my driving but im pretty sure it did nothing because it wont unless you really have the tune for it
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
