Am i lean or not?
Old Oct 1, 2009 | 08:56 PM
07touringcoupe's Avatar
Am i lean or not?
Ok so today i installed my wideband, but before then i was watching my pw's and by redline in 3rd i was seeing 22.4 pws wich tranlates to my idc's being over 110, meaning i shouldve been running lean up top seeing as tho i didnt have fuel to give the leaner conditions, but by redline in 3rd my wideband says im 10.8ish giver or take a few, which should i go by?
Old Oct 1, 2009 | 08:59 PM
Supercharged Guy's Avatar
If your wideband is saying 10.8ish hell i would go by that...
Old Oct 1, 2009 | 09:03 PM
thats what i was thinking but i wanted to make sure. I mean if my pws are in the 22's my injectors are already static
Old Oct 1, 2009 | 09:07 PM
Hell yeah that would be...
Old Oct 1, 2009 | 09:17 PM
Bika's Avatar
Fail Less.
pulsewidths don't translate into rich/lean. pulsewidths of 20msec or greater just mean that your injectors have lost control of themselves trying to provide the commanded fuel ratios.
Tuning your AFR's to mid 11s will help lower those pulsewidths some... if not, you will need bigger injectors.
The injectors will eventually give up after a while of being over-worked and stick open or closed. Then you could have a lean problem...
Old Oct 1, 2009 | 09:27 PM
o ok i thought the idcs were good to be the highest of 85 percent then when your injectiors cant keep up you run out of fuel and go lean. So the pws are what the command afr wants it to be? Idk im tried as hell lol
Old Oct 2, 2009 | 11:23 AM
ebristol's Avatar
What tune, injectors and pulley are you using?
And who told you that you could run that pulley on that setup?
Old Oct 2, 2009 | 11:35 AM
I have 42s on the gm tune with a 2.97 inch pulley! And who told me? Umm everyone said the gm stage 3 pulley is fine to run on the gm canned tune
ShortStack's Avatar
Yea nothin wrong with that..
Old Oct 2, 2009 | 11:40 AM
See but I'm thinking of goin 2.9! I wanted to see if I was to lean to do so!
ShortStack's Avatar
If your afr is 10.8.. no.. lol.. your fine..
Old Oct 2, 2009 | 11:43 AM
Would that push me over? That's still a bit rich
Old Oct 2, 2009 | 11:44 AM
ShortStack's Avatar
Well just because you switch pullies, doesnt mean your AFR is gonna change...
Youll be fine.
Old Oct 2, 2009 | 11:48 AM
Why wouldn't my afrs change? I'd be adding more boost!
Old Oct 2, 2009 | 11:49 AM
ShortStack's Avatar
Okay?
Your afr has nothing to do with boost.
Old Oct 2, 2009 | 11:51 AM
How not? Afr is the incoming air to the outgoing fuel! I'd be bring in more air making me leaner
ShortStack's Avatar
You car is going to attempt to combust at the AFR the computer is set to.
if your computer is running a 11.3 afr...
Even if your at 12psi, or 21psi... the car is still gonna try to run the 11.3 afr..
the afr is how much air is combusted in the chamber to the ratio of the fuel.
If you bring it more air, the car will compensate and add more fuel, thus keeping the afr the same.
Old Oct 2, 2009 | 12:06 PM
And what if it doesn't?
Old Oct 2, 2009 | 12:12 PM
ShortStack's Avatar
... Then the ECM on the car isnt working properly and you should buy a new one.
the most common way is if the injectors can no longer keep up. Which may or may not be the case for you.
If it does make you lean, that means your over running your injectors and you should either pulley down, or get a custom tune and get your afrs up a little, or just buy bigger injectors.
Although if the injectors are fine and the only thing that changes is the boost, your afr shouldnt change.
Old Oct 2, 2009 | 12:30 PM
ebristol's Avatar
You should not lie to people who are trying to help you.
^^^ o my fault my current pulley size is a tad bit smaller than the gm stage 3 pulley. I have a 2.95
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/gm-stage-3-pulley-165505/
unsubscribed.
Old Oct 2, 2009 | 12:37 PM
That was a type o why would I lie about my mods? We are a fam here. I have nothin to hide but its a 2.97 and it is a tad bit smaller than gm stage 3.
Old Oct 2, 2009 | 12:40 PM
Steven Flit's Avatar
No sir
You are no where near lean.
Ditch the gm tune, buy 60s, and get tuned via HPT.
Old Oct 2, 2009 | 12:44 PM
That's what I was thinking but I don't have a tuner near me to tune for the 60s and I've heard I can't drive on the 60s wit no tune or I could wash out my piston seals
Old Oct 2, 2009 | 12:47 PM
ShortStack's Avatar
lmao...
You cant run like a daily driver...
as long as you dont go full throttle, ur not gonna hurt anything to drive to your tuner..
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
DocSvensk
Sep 27, 2015 02:24 PM
ATOMbomb
Sep 11, 2015 10:48 AM
