brfs vs return style
Old Apr 25, 2012 | 12:37 AM
  #101
thedude411's Avatar
So Ignoring all the bashing... Will the Zzp brfps installed as option 1 on their site be sufficient enough to handle a TVS with 60s on either a 2.9 or 2.7 using 93 octane? I'm thinking yes, but it's been a challenge finding answer for this.
Old Apr 25, 2012 | 02:00 AM
  #102
G11's Avatar
G11
Just get 80s imo
Old Apr 25, 2012 | 08:22 AM
  #103
thedude411's Avatar
I already have 60s. There's no e85 up here either yet
Old Apr 25, 2012 | 09:54 AM
  #104
ebristol's Avatar
He is saying to get 80s instead of spending the money on the ZZP BRFPS. The injectors are cheaper and will for sure give you all the fuel you need.
Old Apr 25, 2012 | 10:32 AM
  #105
Chevycobaltss3's Avatar
And 60s with the tvs is still fine. It'll just have close to staic idcs. But if you have a referenced system already just use it. It'll be a lil better.
Old Apr 25, 2012 | 08:42 PM
  #106
thedude411's Avatar
So I don't have to worry about running lean since ill be over running over 17.5 lbs with 80s??? I've noticed on the stock pulley for the tvs I'm pushing just over 17.5 psi of boost. I just want to keep afr's normal with the higher amounts of boost
Old Apr 25, 2012 | 09:04 PM
  #107
advise's Avatar
id get the 80's if your staying on gas and skip out on the brfs or rsfs
sell your 60's for 100
get 80 bucks bam
80 lbs injectors
Old Apr 25, 2012 | 10:59 PM
  #108
thedude411's Avatar
So don't worry about the fact I'll be over 17.5 psi and that the car won't add extra fuel after that level of boost? 80s will be enough? Any other reason other than cost and that 80s won't be maxed out?
Old Apr 25, 2012 | 11:27 PM
  #109
advise's Avatar
You can tune for that factor
I Was running about 21psi in the winter with no knock
Old Apr 25, 2012 | 11:39 PM
  #110
thedude411's Avatar
Interesting. You need a manual boost gauge tho right since the stock gauge stops at the max 17.5 psi. I'm also tuned by trifecta so how difficult would it be for him to tune to that factor?
Old Apr 26, 2012 | 12:17 AM
  #111
Commanded.vs Afr error!!!
Old Apr 26, 2012 | 03:23 AM
  #112
RooTBeeR's Avatar
factory gauge ends at 22.5 just like the map sensor
Old Apr 26, 2012 | 12:29 PM
  #113
SCcobaltSS's Avatar
Let your tuner worry about the fueling. I have tuned TVS's above 17.5 psi no problem. With 80's or a BRFS your tuner will be able to get you enough fueling. Get the BRFS to hold you over and take advantage of the clean idle that system allows. Then when you have E85 available get 80's and drop a pulley size! haha
Old Apr 26, 2012 | 02:04 PM
  #114
advise's Avatar
exactly!
Old Apr 26, 2012 | 02:42 PM
  #115
ebristol's Avatar
Originally Posted by advise
exactly!
Who is tuning your car?
What do you have your base pressure set at?
What are your IDCs like?
Did you install the DW300 because you HAD to or because you thought it would be a good idea?
Old Apr 26, 2012 | 02:48 PM
  #116
bwahahahah wow!!!
Old Apr 26, 2012 | 04:38 PM
  #117
ebristol's Avatar
Oh no...
jk
I am just trying to get some info here. I want to know what to expect when I slap on this 2.7".
I am maxing out (100% IDC) my Fuel system right at 7k with a 2.9" and my base pressure set at 43.5. I don't want to waste a bunch of time messing around with more fuel pressure to find out I don't have enough pump.
Old Apr 26, 2012 | 04:42 PM
  #118
SCcobaltSS's Avatar
What size injectors do you have?
Old Apr 26, 2012 | 05:15 PM
  #119
ebristol's Avatar
80s.
Old Apr 26, 2012 | 05:17 PM
  #120
advise's Avatar
Byt
Going to try 50 psi
Don't know yet lol
Just to know I'm going to have enough pump
Old Apr 26, 2012 | 05:21 PM
  #121
ebristol's Avatar
Byt
Going to try 50 psi
Don't know yet lol
Old Apr 26, 2012 | 05:25 PM
  #122
advise's Avatar
Not to go off topic but has anyone had the trans leak were the case splits?
ashalle2
Sep 27, 2015 03:28 PM
Cptnslo
Sep 24, 2015 09:32 AM
90white240
Sep 14, 2015 09:51 AM
Josh@ottp
Sep 8, 2015 10:18 AM
