can u say pauls turbo 2.0
Old Sep 27, 2007 | 12:46 PM
  #101
607Motorsports's Avatar
drop your tire pressure to 23-25psi, and reduce boost in 1st gear to @70% (test it out btwn runs) and you should be able to get it better. My friend pulled a 2.0 60' on stock tires, so it can be done. (not saying I did though, I managed a best of 2.1 on stock tires)
Thanks for the info man, i'm going to try these new 16's out and they should grip better than my POS p-zero's that are pretty bald lol
Unfortunately I can't pull out any boost in 1st gear due to the fact that i'm running the boost bypass mod. It's the only way I can get the car to hold boost to redline... I tried all the pcm stuff the get it to hold and nothing worked. I'm thinking the bypass is bad...
Old Sep 27, 2007 | 12:49 PM
  #102
06blackg85ss's Avatar
I have my old setup for sale. Worked fine and held 21 psi. Don't use the bypass solonoid (which is probably what went) so if you need it let me know
Old Sep 27, 2007 | 12:56 PM
  #103
Red2.4SS/SC's Avatar
looks good man i like it , time to go hunt some Stage 3 SRT-4's
Old Sep 27, 2007 | 01:59 PM
  #104
NYC_Eddie's Avatar
paul pm me a price? i might take that off your hands...unless CA takes the turbo kit and go public with it then im going to wait...just pm me a price and ill see...aite...
congrats on the getting the kit installed and ready to woop some a$$ (srt 4)...lol
Old Sep 27, 2007 | 02:05 PM
  #105
M-Dub's Avatar
Originally Posted by Jackalope
You can boost a 2.4 just ot as high but you don't need to cause the larger displacment makes the same power levels and makes more torque. Look what happens with the blower swap from a 2.0 to a 2.4. Boost levels drop due to the larger engine BUT it makes the same hp if not more then the 2.0 does and it makes more tq then a 2.0 running a stage 2 kit. I'm not knocking the 2.0 but remember thers NO replacement for displacment.
There is a replacement for displacement, it's called NOS!
Old Sep 27, 2007 | 03:21 PM
  #106
thanks man, as for the old setup I just have the boost control solonoid left, s/c is on mezzano's car since his grenaded
Old Sep 27, 2007 | 04:08 PM
  #107
Jackalope's Avatar
And we can spray our 2.4's too ya know. You may get more rpm out of your 2.0's but sorry guys when the same technology is applied to a larger engine it will always make more power. You know the laws of physics and all
As for NO 2.4 are in the 400 hp range I would invite you to call HAHN and see what he has to say on the topic. After his laughter dies down I'm sure he can clear that up for you.
Also lets not forget the 2.4 N/A in Import Turner that girl runs at the track (can't remember her name now) that makes over 400 WHP and its N/A! As in NO BOOST!
Now I know your 2.0's can make gobs of power but don't be so narrow minded to think our 2.4's can't. One day one might just surprise you at a red light.
Old Sep 27, 2007 | 04:17 PM
  #108
Edubs's Avatar
No disrespect, but drop it everyone...
This is Paul's thread about his turbo, not a thread comparing LSJ's to LE5's. Go start your own thread if you want to debate that.
Anywho, Paul, are you going to be tuning it w/ the Meth right away?
Old Sep 27, 2007 | 04:29 PM
  #109
1gmfanatik's Avatar
Thank you Edubs...Most def waiting for some updates on this kit.
Old Sep 27, 2007 | 04:30 PM
  #110
nah holding off on the meth until I get everything dialed in, then I'll up the boost, add the meth, and hang on lol.
and yes please stop the bickering guys. I have not seen one damn thread on this forum where people didn't start bullshit arguments that got nothing to do with the thread. so please if you need to argue, do it elsewhere.
thanks for stopping by
Old Sep 27, 2007 | 04:34 PM
  #111
1gmfanatik's Avatar
Hey Paul, not sure if reading is > me, but what are you running other then the mild turbo swap? I mean, full exhaust, any motor work??
Old Sep 27, 2007 | 04:35 PM
  #112
well I still have the 3" CTI catback, 2.5 into 3" catless downpipe, stock motor, stock clutch, upgraded axles, 60lb injectors. that's basically it
Old Sep 27, 2007 | 04:42 PM
  #113
1gmfanatik's Avatar
That's awesome...You and I are true proof that our stock clutches can hold up. Mine has 26K and climbing, and I took her to the track on Tuesday and got two runs in. Axles will be my next big mod though...
Old Sep 27, 2007 | 04:51 PM
  #114
CJ BadBlackSS's Avatar
oh oh my clutch still holds! 23k and climbing and have been to the track and one 9 runs
Old Sep 27, 2007 | 04:56 PM
  #115
Onyxd04Redline's Avatar
Boy gm didn't leave us any room back there for an aftermarket turbo kit. Thanks gm. Tight engine bay bullshit.
Old Sep 27, 2007 | 05:05 PM
  #116
07yellowbalt's Avatar
Originally Posted by slick54
if u ACTUALLY put turbo why the hell did u buy a ss/sc u should have gotten a 2.4
thats paul's car not his.
Old Sep 27, 2007 | 05:15 PM
  #117
elecblue06's Avatar
Red lines/ ions don't have that issue our bay is a little bigger
Old Sep 27, 2007 | 07:09 PM
  #118
intense_SS's Avatar
Question for paul:
hey man I havent posted on here in a while because I am in the same process as your in, finishing up my custom turbo kit, looks pretty similar to mine. Anyways are you running stock internals? If so, how are they holding up and do you think they will last for awhile under the high compression? Also I dont know if you will know this but if I have say a Gt3071r turbo or something like it, can I just order the cobalt addiction kit w/o the turbo and just slap mine on their? Next, what are your other mods that your running with this setup, and can you pm me some of your tuning secrets for this setup cause thats where im having trouble. Also around what number will you be shooting for on this base kit? my custom one made 326whp on a safe tune and relatively low boost.
Thanks for the info.
Old Sep 27, 2007 | 07:11 PM
  #119
I always thought so but never bothered to ask if it was larger.
Old Sep 27, 2007 | 07:27 PM
  #120
Cobalt_Supercharged's Avatar
Originally Posted by intense_SS
Question for paul:
If you are wanting to use the twinscroll GT3071R that I posted a link to, you will need a twin scroll manifold to make it useful. (you would need to pair cylinders 1&4 and 2&3) Not sure if the flanges will line up, and the piping may be off because the larger turbo dimensions. I'm not that informed about turbos, but those are things that popped into my head for concerns.
Old Sep 27, 2007 | 07:39 PM
  #121
iLLmaTic3s's Avatar
id figure i put some input on this thread..i was in pauls car last nite..we were gonna get some vids but his camera died..shud have some 2morrow nite. yo his car is very fast...sounds amazing despite the exhaust leak...but god damn guys...no words can describe how fast that thing is..sounds mean too.
Old Sep 27, 2007 | 07:40 PM
  #122
yeah fitment will def be an issue with that setup
lol semi fixed the exhaust leak today, its a little better, work a litttle more tomorrow night on it, and go to town on the car this weekend and go over every damn bolt again til it aint leaking no more... but spool is getting faster already
Last edited by 06blackg85ss; Sep 27, 2007 at 07:40 PM. Reason: Automerged Doublepost
Old Sep 27, 2007 | 07:51 PM
  #123
intense_SS's Avatar
Any other answers to my questions? Pm if ya want to tell me throught there.
Old Sep 27, 2007 | 08:56 PM
  #124
c0baltic's Avatar
paul was your pasenger seat sticky after sean got out... lol... lucky sean cant wait to see this beast tomorrow
Old Sep 27, 2007 | 09:53 PM
  #125
Kennyspec's Avatar
Sweet looking setup. I know it has probably been said before but what size turbo are you running? I am gonna be using a GT2871 for my setup. Internal or External gate?
