can u say pauls turbo 2.0
Old Sep 28, 2007 | 07:51 PM
  #176
Edubs's Avatar
That's what I was looking for. It'll give a good idea of what Hahn's kit should sound like. They're using a Super 20 too...
  #177
06blackg85ss's Avatar
I'm running a super 60, the super 20g is a little bit bigger I think.
Old Sep 28, 2007 | 07:53 PM
  #178
Edubs's Avatar
Jesus, how the hell did I miss that? lol
I must've been supplementing 20 in for 60 just because I wanted to...
Old Sep 28, 2007 | 07:58 PM
  #179
It happens man, I would have like to run that too, but budget was tight. We'll see what I decide to upgrade to once this setup is maxed out.... cause that's just how I roll
Old Sep 28, 2007 | 07:59 PM
  #180
Edubs's Avatar
lol...
Old Sep 28, 2007 | 08:32 PM
  #181
Kennyspec's Avatar
what did you do about the belt routing? make a idler pully or use the alternator from a 2.2?
Old Sep 28, 2007 | 08:37 PM
  #182
Edubs's Avatar
He used the Tag pulley delete thing I think...
Old Sep 28, 2007 | 10:44 PM
  #183
intense_SS's Avatar
where are these vids dammit!!!!
Old Sep 29, 2007 | 01:05 AM
  #184
iLLmaTic3s's Avatar
sorry no vids guys.. everyone had to check out pauls setup and we got hungry n needed beers...paul and i are going to plan a day this week to take lots of vids..lol sorry guys dont worry a lot of vids will be coming asap
Old Sep 29, 2007 | 08:28 AM
  #185
yeah man my friend sam adams got in the way, plus I didn't realize how late it was getting. I'm gonna try to get something up today when I get home from work.
And yes I bought the tag pulley kit, but it's damn easy to make.
Well another IAT update some actual data for you guys,
out side temp was 68 degrees, after air/air intercooler IAT 1 was 108, after stock air/water
IC final IAT2 was 81 degrees at 18.68 psi @112mph and 7023 rpm. IDC was 86-89%, maf lb/min was 38.22 with an afr 11.4:1. 18 degrees timing advance and 0 deg KR the whole time. I don't even get any more throttle tip in .7 kr like the car used to. and VE airflow (lb/m) 38.36. Getting a little more dialed in. Hopefully I can get my wireless working, or some burning software so I can post up some screen shots of the logs for you guys to get an idea of what the car is doing.
Last edited by 06blackg85ss; Sep 29, 2007 at 08:28 AM. Reason: Automerged Doublepost
Old Sep 29, 2007 | 10:14 AM
  #186
Edubs's Avatar
Good to see you're VE is around 38.
That's very similar to what I used to analyze compression maps. What do you think our engine's pressure ratio would be. I was getting a little over 2.7. If I'm on w/ that too, then the GT2871R w/ 52trim, .60 A/R should be perfect for this engine...
Old Sep 29, 2007 | 10:20 AM
  #187
gotta finish doing the math on that one man. Been working like a madman just trying to get everything finished up. I'll have all the calculations up soon.
Ve with 2 more psi was going up @40.xx I"m just trying to get my fueling issues in the lower gears figured out. Big issue though is the piping, so it won't be perfect til then.
Last edited by 06blackg85ss; Sep 29, 2007 at 10:20 AM. Reason: Automerged Doublepost
Old Sep 29, 2007 | 10:24 AM
  #188
Edubs's Avatar
You get that bigger piping and you should prob only see a pound increase down by sea level...
Old Sep 29, 2007 | 10:29 AM
  #189
since I'm pretty much at sea level... should be good. I think I'm at 15' elevation by my house
Old Sep 29, 2007 | 10:36 AM
  #190
Edubs's Avatar
Sounds about right...
Unfortunately, between the IC, charge piping and stock manifold, it'll still mess w/ ya, lol. I can't wait to see how you make out.
When you talk to Kenny, see if he'll offer different turbo's w/ the kit instead of just pigeon holing us into a specific turbo. My cams are going to change things a little bit and I'm thinking I'd be happier off w/ the GT2871. GT30 is just too damn big. I need some power down low to suppliment the cams and build boost by 3K. Was he planning on using the Super 60 for the kit? Cause I'll push that way out of it's efficiency range.
Old Sep 29, 2007 | 10:40 AM
  #191
CJ BadBlackSS's Avatar
lol...can't drive the car at much lower of an elevation.
Old Sep 29, 2007 | 10:45 AM
  #192
truth. I'm sure as long as the turbo will fit, he can offer it. I'll hopefully be picking a gt2871 up soon to see if will fit since that is the turbo I'd rather run. Just waiting to hear back from him on some info and whatnot.
Old Sep 29, 2007 | 10:54 AM
  #193
Edubs's Avatar
Let me know how you make out. I think it comes as a T25, but you might be able to get the housing w/ the T3 connection. Could be wrong though. It's so tough pricing out turbos because you have two inlet and outlets to think about. I know the compressor isn't as big of a deal, but the **** just gets so complicated, I go cross-eyed. When you run your numbers, try them against this. I'm curious to see what you think:
http://www.turbobygarrett.com/turbob..._472560_15.htm
Old Sep 29, 2007 | 11:17 AM
  #194
My head hurts too much to go through that lol. I think you can get it with a t3 flange, or at least get an adapter flange.
I know my boy is running that on his srt-4 and the car is a beast through the whole rpm band
Old Sep 29, 2007 | 11:23 AM
  #195
Edubs's Avatar
Yeah, it looks to be a great turbo choice.
I like the fact you can go w/ a .86 turbine A/R too, for you drag racing guys. The .64 is perfect for me and the street. Should build boost like crazy!
Old Sep 29, 2007 | 11:24 AM
  #196
Darksun's Avatar
I'm not gonna lie **** is cute. Once he got it up and running that night i had to tip my hat to him. Hearing him drive home that night was funny as hell once his waste gate dump opens up. Kinda surprises you that that kinda sound is coming out of a cobalt. AND THANK THE SAINTS PAUL this is the first time an exhaust sounds manly on your cobalt. To bad it took you shoving a turbo at the front of it for that to happen LOL! I think im stuck with my cobalt so even if CA doesn't mass produce the kit i think i'll have paul help me put one together for myself. Deffinatly worth it IMO
Old Sep 29, 2007 | 11:31 AM
  #197
Phil you let me know when you want to get it done and it will be done man. My friend has a welding and fabrication shop now in Mineola who will hook you up cheap for fab work.
you gotta hear the car now at 18 psi instead of 7.8. **** sounds badass.
But yeah man, when I first started thcar up that night and it barely idled I didn't think it was gonna be coming home, but lo and behold my skills at tracking down leaks got it back that night. I still can't believe we did that whole thing in one night, and I was able to drive home, and even get into boost completely untuned. Phil if you're around this weekend I"m taking you for a ride in the car, you'll **** yourself. Thing pulls like a monster now.
Old Sep 29, 2007 | 12:26 PM
  #198
CobaltOrange's Avatar
Wow, the car sounds like a beast! I like the fact you are keeping us all so frequently updated on everything. Absolutely can't wait to see vids!
Old Sep 29, 2007 | 12:38 PM
  #199
I'm trying to fix my camera today, hopefully get a friend over to tape for me later
Old Sep 29, 2007 | 12:40 PM
  #200
iLLmaTic3s's Avatar
hey paul can u tape with the sd card?
