Changed S/C coupler and oil
Old Apr 18, 2009 | 11:08 PM
boostedss26's Avatar
So today i changed the supercharger coupler and oil on my friends car. I took the snout off and their was only a drop of oil in their. Is this normal? I wouldnt think so. I couldnt find any leaks and don't see where it could be going. So i put the new coupler in from zzp and put in 8oz of oil i guess i will have to check it in a few weeks. This just seemed weird but ive never done a supercharger oil change.
Anyone have any imput on this?
Last edited by boostedss26; Apr 18, 2009 at 11:11 PM. Reason: Automerged Doublepost
Old Apr 19, 2009 | 01:13 AM
leviticus88's Avatar
I did mine and it had very little oil in it. Like maybe a couple teaspoons. I put way more than that back in and havent had a leak. So who knows.
Old Apr 19, 2009 | 01:22 PM
Yeah it was the same for me. Their was oil on the gears but it takes 8oz's not 2 teaspoons lol
Old Apr 19, 2009 | 01:43 PM
ls1fbody's Avatar
Haz l33t wheelz.
magic. Just like the Dyno Dynamic eating HP.
Old Apr 19, 2009 | 01:47 PM
SSLOW06's Avatar
If Im Not Mistaken The Super Charger Is Only Supposed To Hold About 4 Ounces Of Oil You Lay The S/c Down And Fill Till It Leaks Out The Hole Just Like The Trani. If You Fill The S/c With Moe Than This It Will Eventualy Break The Seal And You Will Have A Leak If You Alread Y Didnt . I Changed My Oil Last Weekend Only Used Half Of The Bottle Of Oil.
If You Think Im Wrong You Should Do A Little More Research On This Before You Bus A Seal
Old Apr 19, 2009 | 02:16 PM
red06SC's Avatar
I hope you didn't put 8oz. back in, because it takes 3.4...
Old Apr 19, 2009 | 04:58 PM
Well what the heck, my friend said zzp said to put in 8oz. Thats what they sent when he ordered their refill kit. syringe, sealer, and 2 4 oz bottles
I just found this
How To: change s/c oil
got this directly from an Eaton rep. what isnt mentioned is unplugging the MAP sensor harness to fit the allen wrench. and the size hose i used was 3/16" vacuum hose. however 3/8" vac hose will also work. of course this is assuming the supercharger is still installed on the car. if you have the s/c off for a pulley swap or what not, then simply remove plug, dump oil, and replace
How its done:
Parts:
You will need two bottles of GM supercharger oil, GM p/n: 12345982 , this can be purchased at any GM dealership
Tools:
Turkey baster
Short hose- needs to fit over end of turkey baster, and in s/c plug, about
6" long.
3/16 Allen wrench or hex bit
NOTE: Make sure that your engine is cool before starting this!
1-Unscrew the super charger oil inspection plug (a black plug at the front of the
super charger snout using a 3/16 hex head).
2-Insert the tube (that's attached to the turkey baster in to the hole and suck out as much oil as you can. This may have to be done many times to remove as much of the oil that you can. Dispose
of your old/used oil with your old motor oil in an environmentally SAFE manner.
3- Add the oil until it fills the snout to the bottom of the threads. It will take almost two bottles. Be careful to NOT overfill!
4- Screw the plug back in and do not over torque. 8-12 ft/lbs is more than enough!
5- After driving around for a day or so, check the oil level while the car is on a level surface. It's also a good idea to check the level of your supercharger snout at every oil change.
Regards
Eaton Superchargers
Last edited by boostedss26; Apr 19, 2009 at 04:58 PM. Reason: Automerged Doublepost
Old Apr 19, 2009 | 05:01 PM
ssyellow's Avatar
ahh!! not one of the arguments again there are many diff views on this...we will just have to find out what one is right.
I remember seeing that :P lol now somebody will say its not right lol
Old Apr 19, 2009 | 05:05 PM
BoostedYards86's Avatar
mine took 8...no leaks.
Old Apr 19, 2009 | 05:06 PM
I would like to know what is right. I don't want to wreck my friends s/c. But that post i found is from the eaton rep and zzp sends 2 bottles so i'm assumeing that it does take 8 oz
Old Apr 19, 2009 | 05:17 PM
red06SC's Avatar
I'll search it, but there is a c/p of an email directly from an Eaton rep somewhere on here that says exactly 3.4oz.
Old Apr 19, 2009 | 05:27 PM
I've been on this site for 3 years and have asked many times, I have threads about this and I have gotten every number from 2oz to 10oz and from half a bottle to two bottles.
Fact remains no one has gotten a straight answer from anyone including the Eaton reps because they say it never needs to be changed. I just put in a little more than a bottle (about 1 1/4 and havent had a problem.)
Old Apr 19, 2009 | 05:32 PM
06superchargedbalt's Avatar
I had to remove the snout at one time to press my hub on the S/C...had a little more than maybe 3 oz of oil....and I replaced it with a full 3-5 oz of s/c oil.
Old Apr 19, 2009 | 06:22 PM
I posted the email a few posts above yours and it says 2 bottles
Old Apr 19, 2009 | 09:36 PM
05RLS2's Avatar
Ok so how exactly is someone to check the level on them? It is not like there is a dipstick in there.
Old Apr 20, 2009 | 08:00 AM
^^^ what are you asking me for that was from the eaton rep
Old Apr 21, 2009 | 12:34 AM
megaman311's Avatar
EATON SAYS 3.4 OZ from a dry fill. That means either taking off the charger and turning it over to drain, or removing the snout. If you use a turkey baster... you will not remove 3.4 oz.. you will have to measure what you take out and pour the exact amount of the new oil back in. 8 Oz. will create more pressure which will cause the snout seal to fail over time.
Old Apr 21, 2009 | 01:26 AM
SSLOW06's Avatar
When you have te s/c out lay it straight on something wether the table or on the floor over a towel ofcoarse. You pore the oil into the snout hole the only hole you have on the pulley end . You are supposed to fill it until it leaks out of the hole just like when yo uchange the trans fluid . Once it leaks out the hole just screw the plug back in and your done .
I have no idea how these other guys filled it up with 8ounces or more . Unless they stood the s/c up on the tb side and pored the oil directly into the hole wich then it mite take 8ounces . But for those who know you cant overfill anything that works with oil because it will bust a seal in time. Wether its the s/c or even engine oil seals will eventually leak.
Old Apr 21, 2009 | 07:56 AM
I had the snout off to change the coupler.
How its done:
Parts:
Tools:
Turkey baster
6" long.
Regards
Eaton Superchargers
brandon04
Oct 21, 2015 07:04 AM
jimbofug007
Oct 2, 2015 12:06 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
roth
Sep 26, 2015 12:16 PM
