Enthusiasts and vendors alike... header testing inside!
breathe...
They're up now.
well, hurry up and get down here.
Last edited by Deathscythe; Aug 18, 2009 at 10:04 AM. Reason: Automerged Doublepost
Thats what I was wondering. Are all these dynos on the same tune? or was the stock header maxed out, then all the aftermarket ones on the same tune?
Thanks for this thread DS.
I've been stuck in the decision with what header I should get.
You think you could post the links to your dynos on the first page, so we don't have to sort through 9102854712 pages to find them?
Both Joe and I are kinda scratching our heads because he feels it should have done better. I'm still having trouble with burst knock upon laying into the throttle. So in the background, we are still trying to find a middle ground but he thinks that the tune might have been skewed slightly. Meaning that the timing wasn't where it needed to be so the tune would be on level with what was run with the stock header.
Theoretically, that would also say that with a few degrees lacking on the last runs being added to it, that it would perform better. Regardless of the fact, the vibrant has way more room to work with, and I think that is the misconception here. It is by no way limited to the numbers that we came up with on Monday. Like I've said before, we are committed to doing things right, and that's why we did the dyno on the noodle header twice. If he finds something that leads him to believe that it wasn't level due to us hunting down the burst knock..., then it'll be on the dyno again. We don't want to leave anyone wondering.
Bottom line..., the vibrant is definitely worth buying.
The clear image is going to be next once we know for sure that the vibrant was on an even level.
I plan on doing that tonight, since I've had a few requests for it.
All of them now will be done with a catted downpipe. I had to do the noodle header without one because I blew it out right before I dynoed with the stock header. The flexjoint on the inside also collapsed on me, so it had to be done. Either way, the horsepower sacrifice is less than 3 hp in most cases. Not enough to make a real difference.
I would send the piece its on because its the only piece that detactches but its still like 3 feet long and I doubt it would just happen to be cut in the same place you exhaust is lol
