Getting to 300 HP the right way...
Old Jul 22, 2011 | 11:53 PM
  #51
Area47's Avatar
Rent me! per hour
OMG GITZ DA C00LN MODZ!!!!111
shut the **** up about this. it does dick for power. you have a stock laminova cores that support 50hp EACH. you have 4 cores. guess what.
heat exhangers, tanks, blah blah blah yoursisterinthebackseat cooling mods aid in recovery.
Old Jul 22, 2011 | 11:54 PM
  #52
cmatthewb101's Avatar
300 is doable with E85 now.
Old Jul 23, 2011 | 12:55 AM
  #53
Heidrin's Avatar
Ok so I just ordered my stage to kit, so this will be my last question for a while. Once I receive the kit and install it... can I drive to the shop to get the programming done or should i not run the engine until its been programmed?
Old Jul 23, 2011 | 02:32 AM
  #54
09BlueBaltSS's Avatar
Originally Posted by RoelSS
GM Stage 3 can run a dry 50 shot controlled via the PCM
True. Most lsj's are either s2 or knocking the door of being s2 so I figured it would b cheaper to get a wet shot added rather than having the ecu rewrote as a s3 and unlocked but maybe it would end up the same. Idk
Old Jul 23, 2011 | 07:58 PM
  #55
yellowss7590's Avatar
N0s!
Old Jul 23, 2011 | 08:08 PM
  #56
100% METH's Avatar
You look like your having fun...
Your right, the stock inter-cooler system works just fine.
Old Jul 24, 2011 | 01:43 AM
  #57
RoelSS's Avatar
The nice thing about the stage 3 tune is that it has a lot of nice features. High Octane Mode for 100 octane, adjudtable rev limiter, and the Nitrous Algorithm. I run the dry 50 with GM stage 3 and works perfect. You can add the trifecta GM stage 3 tune with all these features for cheap compared to the actual GM stage 3 PCM. Plus, trifecta enables the AC the GM stage 3 PCM has AC disabled.
Old Jul 24, 2011 | 12:18 PM
  #58
Area47's Avatar
Rent me! per hour
the highest whp blower cars and the fastest blower cars share things in common.
Old Jun 27, 2022 | 01:00 AM
  #59
S/C_07_Cobalt's Avatar
Along with a stealth heat exchanger in conjunction with stage 3 heat exchanger/intercooler, and a dual pass end plate…. and a real good tune
Originally Posted by tylerjclance
80's 2.6 meth or e85 with exhaust ..
^^ just saw he said the same thing.
Old Jul 1, 2022 | 03:32 PM
  #60
holy 11 year bump
Old Jul 6, 2022 | 03:29 PM
  #61
Omnigear's Avatar
Old Dec 7, 2022 | 07:40 AM
  #62
martin231_day's Avatar
Originally Posted by Heidrin
Just bought an 06' Supercharged Cobalt yesterday, now I've been scouring the internet trying to figure out the best way to get my car to 300 HP (currently stock) without blowing anything up if you know what I mean. I've looked at the GM stage II kit which is very promising (to me who knows very little of these things) and also exhaust systems from the head back. If anyone could suggest a good relatively cheap FULL exaust system (mid header, downpipe, cat, exhaust) or your idea as an alternative it would be greatly appreciated. Please if your response is complicated simplify to I R BABOON.
just go to the modifications guide in the 2.0 LSJ section
GfSwindle06
Jul 13, 2015 09:52 AM
MfZx25z
Apr 10, 2008 08:22 PM
Jimmys2007CobaltSS/C
Sep 30, 2007 09:07 PM
Coyote
Aug 1, 2007 09:05 AM
Cobalt_SSTuner
Jan 4, 2007 05:31 PM
