getting knock!
getting knock!
k guys i know i need some fuel but i went out testing just to see how much i needed tonight with the aeroforce and at 16.5 psi at 6k rpms im getting 3.5 of knock retard
so i will deff be ordering the maf trans and bigger injectors next week and ill just baby her till i get them....hey badgtp...do you get any knock on your car at all? and did you try the 2.8 pulley without the injectors and how much knock did you get?
although any KR is bad KR, 3.5 is not bad at all if youre going to have KR. I would not suggest running it like that for an extended period of time, but you dont necessarily have to baby it.
i beat the crap outta my cav wnd it shows at time as high as 6
all its telling you is the compter is seeing a signal from the knock sensor , and that its adjusting the timing accordingly
fo rall out performance its best to see 0 or close to it , but it shouldnt be anything to be scared of
I truley believe that most of our tuning issues will be solved with the GM Stage reflash. GM set it up that way to make money on the kits and not lose money on warrenty engine, trans, ect.. Can't wait for Stage 1(Reflash and Injectors), 2.8 pulley, I, H, E should be a nice SAFE hp numbers.
You have much to learn Luke Designed for longevity/warranty, NOT performance. How do i know? I have worked as a technician and service manager at chevy dealers for 16+ years
so i will deff be ordering the maf trans and bigger injectors next week and ill just baby her till i get them....hey badgtp...do you get any knock on your car at all? and did you try the 2.8 pulley without the injectors and how much knock did you get?The car BADGTP talks about is mine, no KR yet but did have 1 isolated occurance yesterday. I made a quick 50 to 110mph, turned the corner and nailed it again. Got 2.3deg at 6K the second time. Have had none since.
You need more fuel!!! The cars fueling is maxed out with a 3.2 pulley PERIOD!
Running the 2,6" pulley and 42 lb/hr injectors since yesterday, I see around 4 degrees of Knock Retard for the few last RPM's. Better gas available here is 91 octane gas, unless I fill it with racing gas. I am waiting to log a few parameters, then I will post my results achieved on the dyno soon ...
Originally Posted by Tofu
How's the butt dyno feel w/ that 2.6 pulley Jmc?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
twilson380
Sep 14, 2015 10:52 AM
