getting knock!
Old Dec 23, 2005 | 11:39 PM
1MEANSS's Avatar
getting knock!
k guys i know i need some fuel but i went out testing just to see how much i needed tonight with the aeroforce and at 16.5 psi at 6k rpms im getting 3.5 of knock retard so i will deff be ordering the maf trans and bigger injectors next week and ill just baby her till i get them....hey badgtp...do you get any knock on your car at all? and did you try the 2.8 pulley without the injectors and how much knock did you get?
Old Dec 23, 2005 | 11:50 PM
Mike_42's Avatar
do you mean it is showing 3.5 "knock retard" ?
what octane gas are you using ?
Old Dec 23, 2005 | 11:57 PM
1MEANSS's Avatar
yes 3.5 knock retard....i only have ever run 93 oct...and i have 1 step colder ngk plugs...
Old Dec 24, 2005 | 12:12 AM
1MEANSS's Avatar
BAD GTP you think if i go 1 or 2 steps more colder on the plugs that will help some???
Old Dec 24, 2005 | 03:22 AM
stuffy236's Avatar
although any KR is bad KR, 3.5 is not bad at all if youre going to have KR. I would not suggest running it like that for an extended period of time, but you dont necessarily have to baby it.
Old Dec 24, 2005 | 03:33 AM
97cavie24ls's Avatar
i beat the crap outta my cav wnd it shows at time as high as 6
all its telling you is the compter is seeing a signal from the knock sensor , and that its adjusting the timing accordingly
fo rall out performance its best to see 0 or close to it , but it shouldnt be anything to be scared of
Old Dec 24, 2005 | 08:02 AM
1MEANSS's Avatar
so with some more fuel it should deff be ok right....i dont want to see any knock at all....
Old Dec 24, 2005 | 09:20 AM
eastcoastz's Avatar
I truley believe that most of our tuning issues will be solved with the GM Stage reflash. GM set it up that way to make money on the kits and not lose money on warrenty engine, trans, ect.. Can't wait for Stage 1(Reflash and Injectors), 2.8 pulley, I, H, E should be a nice SAFE hp numbers.
Old Dec 24, 2005 | 09:40 AM
FAST06SS's Avatar
You have much to learn Luke GM has to design a package with EMISSIONS in mind NOT performance! I would bet 1,000,00 bucks that the reflash will lower timing, have the IFR table adjusted for the new injectors, and adjust the commanded afr table.
Designed for longevity/warranty, NOT performance. How do i know? I have worked as a technician and service manager at chevy dealers for 16+ years
Old Dec 24, 2005 | 09:44 AM
FAST06SS's Avatar
The car BADGTP talks about is mine, no KR yet but did have 1 isolated occurance yesterday. I made a quick 50 to 110mph, turned the corner and nailed it again. Got 2.3deg at 6K the second time. Have had none since.
You need more fuel!!! The cars fueling is maxed out with a 3.2 pulley PERIOD!
Old Dec 24, 2005 | 11:05 AM
Jmc007's Avatar
Running the 2,6" pulley and 42 lb/hr injectors since yesterday, I see around 4 degrees of Knock Retard for the few last RPM's. Better gas available here is 91 octane gas, unless I fill it with racing gas. I am waiting to log a few parameters, then I will post my results achieved on the dyno soon ...
Old Dec 24, 2005 | 11:17 AM
Tofu's Avatar
How's the butt dyno feel w/ that 2.6 pulley Jmc?
Old Dec 24, 2005 | 01:03 PM
stuffy236's Avatar
torque management perhaps?
Old Dec 24, 2005 | 04:14 PM
Jmc007's Avatar
Butt dyno defenitly feels the difference, but that's the Mustang dyno who notice the most ... at the very least 10 WHP and 12 TQ more over the 3" pulley, but yesterday I was not able to tune perfectly my air fuel mixture with the 42 lb/hr injectors. The idle and the acceleration is great, but i'm still too rich. The entire powerband comes sooner too !
Old Dec 24, 2005 | 10:56 PM
1MEANSS's Avatar
so 06fastss....if i put the injectors and the maf trans like you have there will be no knock right?? i want 0 knock .......none zip zero.....
Old Dec 25, 2005 | 12:26 AM
FAST06SS's Avatar
Yes, you need bigger injectors and a MAFFT to tune your AFR to 11.8 to 12.1
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
Sep 30, 2015 08:18 PM
dennis69
Sep 22, 2015 08:56 AM
OrngBalt
Sep 16, 2015 07:45 PM
twilson380
Sep 14, 2015 10:52 AM
