GM STAGE KITs FAQs - Read Me First!
Old Jun 6, 2007 | 10:26 PM
  #326
BCobaltSS's Avatar
Stage 3 100 octane mode: Well just filled up with the 100 octane and it was kinda funny the nosel for the pump would not fit the hole it pushed open the flap luckaly. I put in half a tank . Tuned on the adjustable rev limit then set the 100 octane mode and it's kind weird to see the shift light to indicate the 100 octane mode . I have never seen the light before.
So I can feel the diifference in the 10 extra hp and the shifting seems to be easier and when I step on it in 1st gear at a 4000rpm roll it just spins the tires. Second gear getting on it from a 40 mph roll it crazy . It screams and starts to spinn the tires. I can't wait till I hit the track.
$30 for a half tank of gas ouch .. won't be doing it all the time but just enough every once in a while.
poly mounts are oin and man the vibrations are bad hopefully they will go away.
Old Jun 7, 2007 | 12:12 AM
  #327
Degashoot's Avatar
Lightbulb Installing Stage II abroad
Hi there,
Glad to be here, this is my first post !
I have just bought a 2005 Cobalt SS/S and it will arrive in about 3 weeks. Now I've been reading a lot about the Stage II kit and I really want to install this upgrade.
My local Chevy dealer doesn’t' even import Cobalts and they don't offer support for imported Chevy's...
Now my question is:
If I order the Stage II and get a skilful mechanic to install it for me, how should I go about reflashing the system? I mean is it a standard number/code? Should I call the US and ask? What if they don't offer support to Chevy that have been exported?
I hope there is a way to get this done
I'm just asking this before I go ahead a buy the kit. Maybe some of you can give me some good advice as I've noticed you've been giving a lot of them in this thread
Thanks in advance my fellow Cobalt SS/S enthusiasts
Old Jun 7, 2007 | 07:56 AM
  #328
BCobaltSS's Avatar
The reflash must be done by the dealership because they down load the software from the tech support line and into the scan tool to reflash the computer in your car. You can do the install yourself it's no that hard but you will only get the parts warranty instead of parts and labor warranty if you were to go to the dealership for them to install.
Old Jun 9, 2007 | 01:33 AM
  #329
Brian's07SS's Avatar
Question.... What can I do if the dealership threw away the paperwork with the Stage2 Kit Code on it and didnt flash the computer correctly? GM wont give them the VCI# with out the code that came with the kit? I see on the first page or so that there is a Part number for the flash for 05-06...anyone have one for an 07? Im really up $hit creek here... I got everything back from them except the paperwork. Any help Please PM me.. thanks..
Old Jun 9, 2007 | 02:36 AM
  #330
WopOnTour's Avatar
Assuming everything transpired as you've indicated, and the dealer ordered and installed the kit should be THEIR problem.
(BUT If YOU provided an open box kit you purchased elsewhere or on-line it could be argued YOU lost the instruction sheet with serial number)
Best case scenario, the dealer will accept responsibility and purchase another kit for you and use the serial number for the new kit.
Worst case scenario YOU will have to purchase another kit
Good Luck
Wop
Old Jun 9, 2007 | 01:16 PM
  #331
Good Luck
Wop
Thats not what I wanted to hear..haha..
I brought it to them opened.. They are giving me crap because they are saying its "aftermarket" because I didnt buy it from GM. I looked around there are no Aftermarket Stage2Kits for this.. its a manufacturer part only.. Unless you wanna piece together one which I didnt. So Im going to have to spend another $600 just for a Fn code? because the dealership screwed up? they said that they never needed a VCI# before when doing the Reflash. and as we all know GM wont give them the VCI# with out the code from the Kit. This blows that THEY Fd up and I get screwed.
Old Jun 9, 2007 | 01:24 PM
  #332
braineater's Avatar
it sounds like you are going to need to find someone near you with HP tuners and have them tune your car. the good news is that if the person doing the tune knows what they are doing you will end up with a better tune then what you would get from GM
Old Jun 9, 2007 | 01:50 PM
  #333
I was thinking that... Anyone in the North Jersey Paterson/Clifton or surrounding area with HP tuners?
Old Jun 9, 2007 | 05:31 PM
  #334
im confused, is it or is it not installed, from what im reading its not, but your signature says it is?!
Old Jun 9, 2007 | 08:54 PM
  #335
the parts are installed and they gave it some BS flash.
that they thought was a Stage2 Flash.
They said they have done 12 Stage2Kits and have only called the tech line for the first one.
2 days after the Parts were installed it threw a Code. P0172. Running Rich Bank1.
So yes the pully, injectors, and Belt are all on. only thing missing is the Actual Flash for the Kit that I have.
And the ONLY reason I questioned it was because I got on it good one day while on lunch, to see the redline and BANG 6500..buck buck...not 7K like its supposed to be.
Old Jun 10, 2007 | 12:18 AM
  #336
id call that bullshit place up and say either your fixing this or my car is coming thru the front door of your office.
Old Jun 10, 2007 | 10:03 AM
  #337
EmperorJJ1's Avatar
lol 07
Old Jun 10, 2007 | 11:05 PM
  #338
Degashoot's Avatar
Lightbulb So basically I'm f*cked :(
Originally Posted by Degashoot
Hi there,
Now my question is:
If I understood you correctly, basically I'm f*cked
My local dealer doesn't support imported cars so there is no way to get them to reflash my CPM. What a bummer, I really wanted to buy and intsall the Stage II. I will try searching for more info on this matter before I give up on it
Thanks for the help !!
If anyone knows more info about this issue, please let me know !
Old Jun 27, 2007 | 03:14 PM
  #339
moedeenterprises's Avatar
Used Stage II kit
I bought a used stage II kit from a friend. Got it installed and now gm wont give up an vci number. Can somebody PLEASE help me on this. Is it ok to drive it without the flash??
Old Jul 1, 2007 | 07:28 PM
  #340
Onyxd04Redline's Avatar
So if i buy S1 i have to take it to the dealership so they can reflash it correct?
Old Jul 2, 2007 | 10:44 PM
  #341
K-Man's Avatar
Stage Kit Identification
I purchased my 2005 SS/SC back in November of 2006 and I love it. Having bought the car used, I don't know if the car has a stage I kit installed or not. I know it doesn't have a stage II kit because it is still running the stock pulley. Here's the dilema: I took the car in for service due to a couple known electrical glitches. When the car was in, they flashed the ECM with an upgraded program. Ever since the flash was done, the car doesn't seem to have near the performance. The dealer tells me there is no going back and they don't seem to think there is a problem. I think the car has a stage I kit installed and they flashed the ECM with the "regular" program. Power and torque don't seem to appear until around 3000rpm now. I have noticed that my friend's stage II kit has black injectors and my car has bright green injectors if that helps.
Can anyone tell me how to identify a stage I kit?? The dealerships don't seem to be able to tell me.
Old Jul 3, 2007 | 09:45 AM
  #342
SS_Canuck's Avatar
No, don't drive it without the flash. Sorry can't help with the GM problem.
Look for the blue bolts on the pulley? I think that is a way to check.
Old Jul 3, 2007 | 09:54 AM
  #343
brett5's Avatar
i have stock injectors and there green also so you probably dont have astage kit the 42lb injectors are normally silver or white
Old Jul 16, 2007 | 03:37 AM
  #344
Jmc007's Avatar
GM Stage 3 FAQ ...
http://www.crateenginedepot.com/stor...s-W57C196.aspx
Old Jul 25, 2007 | 12:47 AM
  #345
lrk322's Avatar
No warranty on stage 3! Looks like Ill be going with stage 2. Ill have my warranty and eat it too!
Old Jul 25, 2007 | 07:53 AM
  #346
I have a 2007 with Stage 3 pulley and am doing the dpic and wont have any problems.
Old Jul 26, 2007 | 08:16 PM
  #347
bcss/sc's Avatar
hey i just bought a 3.25 pulley and they wont give me a belt size without buyying the full kit so i cant find any belts so if anyone has any ides that would help out alot
Old Jul 28, 2007 | 03:16 PM
  #348
BaltSS1052's Avatar
How do you know where your redline is after you install your stage 2 kit?
Old Jul 28, 2007 | 04:53 PM
  #349
bc/ss why would you buy that pulley? thats the stock size.
baltss - your redline should be at 7k after stage 2 install
Old Jul 29, 2007 | 05:55 AM
  #350
cobalt5SS's Avatar
can you have stage 2 and switch between stage 3 and back to stage 2 with a/c
