Going to be swapping my clutch...
Old Mar 28, 2012 | 09:51 AM
sujomatt's Avatar
so how do you know if the throwout bearing is shot? gosh i feel dumb but honestly i have no prior experience with clutches/transmission work so this is all a huge grey area for me..
Previous experience has taught me when you have the clutch out in neutral you hear humming. When you push the clutch peddle in, you don't hear it (while remaining in neutral). Also having issues on occassion getting it into gear smoothly
Old Mar 28, 2012 | 10:34 AM
alleycat58's Avatar
Originally Posted by willdrew
No prob. and yes the LNF uses a different much better fluid than the LSJ. Its what im running in my car along with the GMPP clutch
Yup. Ditto here. GMPP clutch + LNF fluid. Shifts like buttah.
Old Mar 28, 2012 | 10:54 AM
well once in a while i certainly have issues getting into reverse and sometimes 1st
Old Mar 28, 2012 | 11:17 AM
robd53's Avatar
That could be simple cable adjustments under the shifter.
However, in my old Sunfire, reverse would always be hesitant to get into, or grind sometime. To remedy that I just put it in 4th, then reverse. Smooth as silk every time then.
Old Mar 28, 2012 | 12:09 PM
yea i always figured it was some bullshit with the linckage, our stock shifters so sloppy and notchy. hoping the revised shifter bracket helps firm that up a lil bit
Old Mar 28, 2012 | 12:28 PM
alleycat58's Avatar
It does a little. Do you still have the stock shifter or aftermarket? When I installed my Hurst I had to adjust a little more and fine tune it, but it works like a charm.
Old Mar 29, 2012 | 02:40 PM
naw i'm still stock everything clutch/shifter wise. gonna go twm when i can finally find myself spending $400 on that ****... i spend less for everything in my OP list!
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ThoR294
Oct 4, 2015 08:44 PM
ernnyyes
Oct 2, 2015 05:16 PM
ThoR294
Sep 28, 2015 05:31 PM
