Handbreak, garbage. Any ideas how to modify?
Old Jan 12, 2008 | 10:20 AM
maregis's Avatar
This advice still does not add strength to my hand break. I understand what people are saying but it just does not work for me and my experience. My question is simple, "does anybody know how to improve the strength of a Cobalt handbreak"? I had a Civic for many years, the hand break was strong unlike the Cobalt. It actually helped me get out of a few black ice situations in the 10 years I owned this car so in saying this, the hand break "for me" is an important safty feature. Maybe thats why they call it the emergency break. If you want to argue my "personal" preference for the use of the handbreak just think back to the main point of this post "does anybody know how to improve the strength of a Cobalt handbreak"?
Old Jan 12, 2008 | 10:36 AM
ted5986's Avatar
ok first off like hack said...twice......hand BRAKE not break , second.. it hasnt been called an emergency brake for quite a while. it is reffered to a parking brake or hand brake but anyway. people have told you how to tighten the cable and thats the only way to "strengthen" it. if you use a 10mm wrench on it and tighten the cable you lock it up easier. believe me thats all you need to do. you will be able to toss the rear around in the dirt without a problem
Old Jan 12, 2008 | 10:40 AM
JohnnySasakiMGS's Avatar
Yes I think the handBRAKE is just for parking.
Old Jan 12, 2008 | 11:06 AM
RedEcotecSS's Avatar
for parking or not, when i pull mine (never when moving) my car still tends to roll.. lol..
Old Jan 12, 2008 | 11:11 AM
articzap's Avatar
A good driver does not need a handbrake for rally-x. A good driver will left foot brake and weight transfer if they need a bit of rear end slide.
To whoever said that the handbrake couldn't hold there car at the track, it means your car has to much traction or you don't have enough power to do a burnout.
Old Jan 12, 2008 | 12:37 PM
D4u2s0t's Avatar
wait, so if you're on black ice, you intentionally try to lock up the tires and consider that a safety feature? don't take this the wrong way, but learn to drive better and you won't need to be yanking your brakes like that. why not just look into better brakes.
Old Jan 12, 2008 | 12:50 PM
Deersniper17's Avatar
ok well what ur looking for is to make ur brake have more bite.....on the bottom of the handle there is small cut..that is what the cover for the handle locks into...using a screwdriver push it in and while pulling off the cover u will find a piece of threaded rod with a nylock nut...just tighten up that nut till u find it meets ur needs and re-install the cover and ur ready to rock and roll
Old Jan 12, 2008 | 12:58 PM
Cobalt_SSTuner's Avatar
Originally Posted by HackAbuse
If you want your handBRAKE to be stronger, I suggest hitting up the gym
weak....i expected better out of you
Hell yes! I know exactly how that goes!!
thank you
Old Jan 12, 2008 | 12:59 PM
maregis's Avatar
I will try this, thanks Deersniper
06MetallicBalt
Jul 20, 2025 08:47 PM
Oct 20, 2015 09:56 PM
tomj77
Oct 4, 2015 11:39 AM
Tupp
Sep 30, 2015 08:18 PM
Rduncanss06
Sep 27, 2015 11:17 PM
