Heat gun + tstat = ???
Old 06-22-2012, 12:37 AM
South Central *********
JapEatr's Avatar
Appreciate your patience here, but im doubting that will work...
That said ill try it this weekend amd let you know
Old 06-22-2012, 12:42 AM
Validater's Avatar
Ok well I wish you good luck. Sometimes it works sometimes it doesn't. Unfortunately the only proper way is the vacuum fill and that's a $150 tool up here in Canada.
Old 06-22-2012, 12:44 AM
JapEatr's Avatar
edit
Old 06-22-2012, 12:58 AM
Validater's Avatar
FJC 43610 43610 - Radiator Coolant Vacuum Refill Kit
That's what you'd need. Unless you know what I meant.
Old 06-22-2012, 07:36 PM
OttawaMark's Avatar
Ok, so what about doing this is advance? Can I prefill my block somehow before it gets crowded after I swap it in, and why can't you fill the block from the top rad hose on the head?
Old 06-22-2012, 07:43 PM
094doorSS/TC's Avatar
Originally Posted by Validater
AllData shows to Vacuum fill it. I still think you should be able to remove a heater core hose and bleed the air out as much as possible. A minimum of a gallon should go in then it should be able to be run and topped up from there.
this^^ vacuum fill is the best way to get air out.
Old 06-22-2012, 07:50 PM
carstedt's Avatar
after my build we filled up the coolant and bled it as much as we could making sure the lines are full..started it up and the tstat kicks on quick after that then itll start flowing in and jus keep pouring coolant..didnt do any damage for the very short time
Old 06-22-2012, 07:55 PM
Sunburst_SS's Avatar
I doubt it would do any damage....as soon as the engine cranks it will suck the coolant down into the engine. Just have coolant ready to fill the jug up when it gets low. If you had a vaccum filler that would be great.......Also if you are worried about it, take the upper radiator hose off and fill the engine from there.
Old 06-23-2012, 02:26 PM
insylem's Avatar
If the weather is warm, what about just removing the T-stad and filling the colant, running it some to warm it up whiel purging air. Then once the air is all purged and coolant all filled (Yes you may get a CEL but I doubt it if its warm weather and your not driving since driving is part of what triggers the Tstadt CEL Code) Then you can install the Tstadt and be good to go?
Old 06-23-2012, 02:50 PM
07cobaltguy's Avatar
Ive had done a few swaps and never had coolant in the block it dosent take long for it to open up.
Old 06-23-2012, 02:51 PM
  #36
fire it up with the coolant cap off and watch it dissapear
Old 06-23-2012, 02:56 PM
  #37
Terminator2's Avatar
Originally Posted by JapEatr
I have 1 1/2 gal of 50/50 mix in there now, but none in the block as i can ser
Take the thermostat out so the coolant/water will immediately start to fill the block.
Old 06-23-2012, 02:58 PM
  #38
This too.
Old 06-23-2012, 04:15 PM
  #39
insylem's Avatar
Hey that was my idea
I Guess great minds think alike
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
Sean Cummings
01-08-2020 10:17 AM
jmelton327
09-26-2015 10:04 PM
CobaltSS 16
09-06-2015 02:04 PM
Quick Reply: Heat gun + tstat = ???
