how much boost with...
Old Feb 5, 2008 | 08:09 AM
rms7design's Avatar
stage 2. How much psi do you get with your stage 2? I get 15psi. have a good one
Old Feb 5, 2008 | 08:15 AM
G WOOD82's Avatar
From: I'm currently busy putting 10,000 kids on your mothers face!!!
depending what size pulley you are running with, but 15 sounds right if you're running a 3.0 or 2.9 pulley.
Old Feb 5, 2008 | 08:45 AM
rms7design's Avatar
pulley that came with the kit which is a 3 if I am not mistaking...
Old Feb 5, 2008 | 08:50 AM
Misery5567's Avatar
My stage 2 is going in this morning. I'm substituting a ZZP 2.8 for the GM pulley.
I think I should wind up with about 16-17 PSI. Might get lucky and get 17.5 as long as
the stage 2 belt doesn't slip.
Old Feb 5, 2008 | 08:51 AM
Rangerondubz's Avatar
Should be around 15 w/ 3" Pulley
Old Feb 5, 2008 | 08:53 AM
G WOOD82's Avatar
well stock pulley is 3.3 so you went down .3, so i dont know 14-15psi sounds right for that since we are stock at 12psi. I have a 2.6 pulley and im at 19-20psi. So sounds right man.
if your belt is slipping get the oversized idler pulley to go with it for 19.99 it will help eliminate all slip. You can get it at intense or you can get something like it at murrays for a grand prix. It's the same thing.
Old Feb 5, 2008 | 08:57 AM
2fastSS's Avatar
my friend did the same thing last year and two months later he blew his engine....2.8 isnt safe on a stage 2 tune how many times do we need to discuss this
Old Feb 5, 2008 | 08:58 AM
EdCobaltSS's Avatar
i'm runnin a 2.9" pulley and i get between 17.5, and 18psi
Old Feb 5, 2008 | 09:05 AM
rms7design's Avatar
so just by reducing my pulley I can increase that much my psi.... interesting ... arghhhh.. I like the fact we can go up to 7k rpm... next time maybe.. a smaller pulley...
Old Feb 5, 2008 | 09:10 AM
2fastSS's Avatar
the reason alot of people are gettin those high psi numbers are because they dont have a full exhaust which has alot to do with.
Old Feb 5, 2008 | 09:14 AM
Misery5567's Avatar
Sorry for your friend. Hopefully I won't suffer his fate as I don't beat on my car (i.e. run to redline everytime I get on it). I have tuners nearby so I can get it changed if I need to or I can go back to the S2 pulley if it starts acting up. Either way, I got lucky and got one of the 'good' Cobalts. You know? The ones that never have to go in for the multitude of standard issue problems? I thought I had some early on but I was wrong.
Didn't mean for you to get upset and have to discuss it
Old Feb 5, 2008 | 09:15 AM
XCRuna1201's Avatar
What was your point in this? That a full exhaust would make it lower PSI? Just Wondering
Old Feb 5, 2008 | 09:17 AM
EdCobaltSS's Avatar
I Have A Full Vibrant Exhaust, Header Downpipe And 3" Straight-through Cat-back Stainless. I Still Get Those Numbers. An Exhaust Will Not Drop Your Boost. It Lets The Engine Breathe More, Makes The Charger Work A Little More, But Wont Drop Boost
Old Feb 5, 2008 | 09:19 AM
XCRuna1201's Avatar
Yeah I know but 2fastSS said that they were getting that high because they didnt have the new exhaust thats why i was asking.
Old Feb 5, 2008 | 09:21 AM
Misery5567's Avatar
Originally Posted by XCRuna1201
Yeah I know but misery said that they were getting that high because they didnt have the new exhaust thats why i was asking.
I didn't say a word about any exhaust I knew i wasn't seing things lol
Fast on the edits there
Old Feb 5, 2008 | 09:22 AM
EdCobaltSS's Avatar
Oo Ok, I See Now, Yes, If You Dont Let The Engine Breathe, It Wont Get Numbers That High, When You Put An Exhaust On, It Should Raise The Boost By About 0.5psi Or So
Old Feb 5, 2008 | 09:24 AM
XCRuna1201's Avatar
yeah srry i meant 2fastSS
2.9 with stage 2 is pretty safe right?
Old Feb 5, 2008 | 09:25 AM
EdCobaltSS's Avatar
Absolutely
Thats What My Buddy Bobby Is Runnin With The Gm Stage 2 Tune And 42.5 Inj's
2fastSS's Avatar
how does adding a exhaust add boost?? LOL are you serious? My point is 3 inch catless downpipe, exhaust, and 4-1 headers me and my friend both experience loss of boost you wont gain boost
Old Feb 5, 2008 | 09:30 AM
Misery5567's Avatar
Most everyone says 2.9 is safe. Some people say 2.8 is ok too as well as not ok. I'm gambling the 2.8 is ok for ME. My GM service department here seems to think it should be fine as well. They haven't lied to me yet and are very upfront.
i think he was referring to the boost increasing or staying the same.
Look at it like this.. Blow into a bottle.. You can put x amount of pressure into it. Pop a hole in that bottle and you will have to work harder to maintain that pressure. That's what he meant by the charger having to work harder to maintain/increase the pressure. No hole in the bottle and you're just blowing to be blowing.
Old Feb 5, 2008 | 09:31 AM
zrated89's Avatar
you guys obviously havent done your research. oping up you exhaust system will drop your boost. with an intake and exhaust your motor will breathe much better, therefore putting LESS stress on your blower. Think of it this way, someone has their hands around your neck hard to breathe right? they let go you breathe more. And to answer your question about what size pulley i would run. i see your in NC im in VA so altitude is about the same. I wouldnt go lower than a 2.85 on the stage tune.
Old Feb 6, 2008 | 09:43 AM
Texas SS's Avatar
boostin 15 pounds for me on stock stage 2
Old Feb 6, 2008 | 10:59 AM
FryLoch's Avatar
Im boosting about 16-17 with the Stage 3 pulley.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
