IAT2 Temp....
Old Apr 13, 2012 | 11:39 AM
startingline05's Avatar
Originally Posted by I8URVET
So i need to hop in here, my car has been running very bad when i hit 190 engine temp and 90 AIT, but im confused with AIT and AIT2? which one am i seeing on my PLX? it says AIT, do i need parts or what to read AIT2?
get an interceptor, it reads AIT2
Old Apr 13, 2012 | 11:43 AM
I8URVET's Avatar
Well i would have but turbo tim told me to get the plx instead cause its better. Fock
Old Apr 19, 2012 | 09:36 PM
DarkChild's Avatar
PLX is a wideband I believe. The aeroforce interceptor monitors the car.
UPDATE on the CX racing pump: Saw a tiny package waiting for me thinking that there is no way this would be the pump. Well, it is literally half the size of the stock pump. I get the exact same results with this pump as the stock pump BUT worse.
Don't waste your money into this pump. My IAT2's where at 80-100*F with the stock pump and they hover around 120*F with this CX Racing one; this is while cruising.
WTF is wrong with my cooling system then? I'm going to rebuild my stock pumps I have laying around but why is it when I clutch out(neutral) the temps raise like a bat out of hell? This is really starting to annoy me.
Old Apr 19, 2012 | 10:03 PM
I8URVET's Avatar
My PLX reads everything thru the OBII except for AIT2, i have a seperate AEM wideband. It supposed to be just like the Aeroforce. So where is the AIT2 sensor at? maybe i can add a sensor and tie it into the PLX. Sucks that i cant get any info on this AIT2 crap.
Old Apr 20, 2012 | 08:34 PM
DarkChild's Avatar
I'm not exactly sure where the sensor is itself but I'm sure you could tie into it.
Another UPDATE: I opened my pumps up, the one I was using is still brand new. I need to see why the cooling system is doing what it is doing.
Old Apr 20, 2012 | 09:33 PM
cavfiredesire's Avatar
The IAT2 sensor is the Map sensor located on the pass side on top of the intake manifold.
Atleast thats where it is on my supercharged cav.
Old Apr 20, 2012 | 10:46 PM
I8URVET's Avatar
yeah i would think i can tie into it, problem is its built into the map sensor so that could get wacky. as for your cooling, are you sure the plumbing is right? is the coolant flowing from left to right? in the filler neck of course.
Old Apr 21, 2012 | 03:23 PM
DarkChild's Avatar
Me and my brothers are going to re-route the system. If that is where the sensor is then I'm not sure how that would work. You don't want tuning software attached all the time either. You should make a thread and see who else is using the PLX. Getting a good answer is hard to get sometimes. I wish I could help. How many wires tie into the sensor and what do they all do?
Old Apr 22, 2012 | 12:04 AM
I8URVET's Avatar
on the PLX it accepts 2 conductor sensors but im not tapping into the MAP. i will start a PLX thread and see if anyone else has been dooped into buying it.
Old Apr 22, 2012 | 12:29 AM
thedude411's Avatar
I has the Plx phone thing. It was the dumbest thing I've ever purchased. All the **** u want to know it won't read. Brutal.
Old Apr 22, 2012 | 12:31 AM
  #36
aikidoshadow's Avatar
Check your hose routing for kinks and flow and your pump for flow. Also make sure the system is bled, OPTB should do that for you. Your temps will heak soak up from the intake manifolds contact with the head as well as the lack of air flow from going slower, stopping, etc. The front mount will basically be useless while your stopped as well.
Old Apr 22, 2012 | 09:04 AM
  #37
I8URVET's Avatar
Funny you say that, i called PLX about AIT2 readings and they told me to buy that phone one KIWI, i asked if they were sure it read AIT2 and they said " well, i dont know". lol. great support team.
Old Apr 22, 2012 | 09:47 AM
  #38
I haven't seen over 90 on my iat's at WOT in a long time. How about all you other lsj's?
Old Apr 22, 2012 | 10:16 AM
  #39
I8URVET's Avatar
same here, 90 on AIT is the highest ive seen so i would assume my AIT2 is within the range of safe. But i have no idea. I think i need a new TB to fix my issue.
Old Apr 22, 2012 | 09:26 PM
  #40
DarkChild's Avatar
What cooling mods do you have? How is it routed?
Old Apr 23, 2012 | 06:29 AM
  #41
Air to air
Old Apr 23, 2012 | 09:19 AM
  #42
I8URVET's Avatar
i have dual pass and S3 HE. No option B, i didnt have any issues bleeding either. Routing is the standard that you find on the forums or from instructions that are online. I cant remember the exact way its routed but i had to redo mine because of kinks. i will look today and let you know how its done.
Old Apr 23, 2012 | 09:29 AM
  #43
Staged07SS's Avatar
Administrator
Administrator
https://www.cobaltss.net/forums/how-...rnator-274630/
^See my "How To" Guide....
I have photos of my hose routing, and other good info.
Old Apr 23, 2012 | 09:40 AM
  #44
distillion's Avatar
get an areoforce and a stock pump and make sure your connections are proper with no kinks.
My iat2s are incredible cruising, idleing and at wot.
Old Apr 23, 2012 | 02:58 PM
  #45
DarkChild's Avatar
What are everyones IAT2's? I have the Aeroforce and the stock pump. I will follow the how to. Thank you.
Old Apr 28, 2012 | 04:15 PM
  #46
DarkChild's Avatar
UPDATE: I redid my cooling system and put my stock pump back on since it did work. There entire system was routed wrong but there were more problems than one. I also put my Phenolic spacer on by ZZP. All I can say is... wow, my IAT2's while cruising are at 69*F-low 70's*F.
I'm smiling from ear to ear. Big headache to fix but now that is is done. Well worth it.
Use these threads for help. I routed it the way that is posted in the first post on this thread:
https://www.cobaltss.net/forums/2-0l...ctures-274777/
Read through this thread about information on the option B. The small hose and big hose from the Option B have to be the highest part of the cooling system:
https://www.cobaltss.net/forums/2-0l...inside-262676/
I would like to thank all of you who helped me out. I really do appreciate it. It's nice to have brothers who can also help and makes things easier for when you get frustrated, LOL.
Old Apr 28, 2012 | 07:08 PM
  #47
I8URVET's Avatar
Awesome Bro, glad to hear a fix. Maybe i should do the spacer and see if my "limp mode" fixes. I dont wanna have to buy an aeroforce just to read my damn AIT2 after i spent $300 on the PLX.
Zach06CobaltSC
Jun 22, 2008 06:00 PM
Scoot05RedSS
Mar 31, 2008 10:54 PM
LopsidedJester
Sep 1, 2007 10:54 PM
Blown 4-banger
Oct 24, 2006 06:25 PM
