Idle & Boost Problems? Anyone else???
Old Feb 19, 2006 | 02:33 PM
Peter777's Avatar
Question Idle & Boost Problems? Anyone else???
So I've given it a bit of time. I picked up my SS SC at the end of November.
(I have 3600 KM's on it btw)
Here are the problems.
Thus far I have not been able to get past 8-9 PSI this kills me, I can't describe how upsetting it is to buy a performance car and be losing a significant amount of performance, though I am trying to be patient. Someone told me the first time they dinged it off 12psi was at 3000 miles so about 4500 kms. I'm not even close at 8psi. What is going on?
Am I going to have a hard time if i go to the dealer? Should I? Is there something I'm not doing? I mean im maxing out and believe me, I am pushing her WOT and really getting up there.
Also, I often find that when I'm in neutral I don't get a steady idle, it fluctuates up and down, this has actually caused me to stall a few times when backing up since its tricky to make fine adjustments on the clutch when your engine is idling up and down slightly as you back up.
Any suggestions? Anyone have common problems that they fixed etc? Thanks!!!
Old Feb 19, 2006 | 02:39 PM
Chevypowered's Avatar
What elevation are you at??
Old Feb 19, 2006 | 02:42 PM
BooSSted's Avatar
I have the same problem with my Idle but not with the boost. Do you still have the stock boost guage that reads in Kpa??
Old Feb 20, 2006 | 12:31 AM
Peter777's Avatar
Yep, stock boost gauge. Do you think it is the gauge? I mean other people on the same gauge are getting higher readings so I'd imagine it is all relative right?
I don't really know what elevation means in this situation :S sry.
Old Feb 20, 2006 | 12:34 AM
GotBoost?'s Avatar
Well i dont hit 12.5 psi untill i get close to redline.
Old Feb 20, 2006 | 12:39 AM
06black's Avatar
i'd say take it to the dealer and scan the PCM see if they find any thing...the dealer schould be more than willing to work with you
Old Feb 20, 2006 | 12:41 AM
Are you at sea level or at 5,000 ft in the mountains. How high are you from sea level?
Old Feb 20, 2006 | 11:17 AM
2K5SS/SC?'s Avatar
Well it says he's in Ottawa. I found it to be like 374 feet. He should be getting the 12.5 psi. Probably needs to get the boost gauge recalibrated.
Old Feb 21, 2006 | 10:45 AM
BADZSS06's Avatar
mine will surge at idle every once in awhile. i just rev it up a little and it straightens out. it is annoying but im hoping the stage kits clear it out
Old Feb 21, 2006 | 11:10 AM
glockglade's Avatar
a while ago a couple other people had this problem, they took it to the dealership and i think if i remember correctly they fixed a screw on the bypass valve and reflashed the pcm, also your altitude greatly effects this problem i live in palm beach and sometimes i can boost around almost 14 w/ an intake and exhaust the idle probllem is common blame the drive by wire system for that, or praise it b/c it is used for throttle control on jet airplanes.
Old Feb 21, 2006 | 12:04 PM
BLKSS's Avatar
I read 90 to a 100. Idle issue is normal. Unless it stalls then you need an update.
Old Feb 21, 2006 | 12:20 PM
M62SS's Avatar
i read 90 kpa a max boost near redline never see more tan 90kpa and my idle do the same thing almost once a week....its pretty common with our cars...
Old Feb 21, 2006 | 07:33 PM
Peter777's Avatar
I will mention that. I just hope I don't get idiots who argue with me or tell me 'ahhh man don't worry the car is fine'
Seems everything is always fine when it is under warranty but nothing is right when you have to pay for it.
Old Jan 30, 2007 | 09:29 PM
JohnfromVA's Avatar
my car is idling at 750rpm how do I fix that. It goes way below 1000 and almost wants to stall but doesn't. HELP!!!!
Old Jan 30, 2007 | 09:51 PM
Johnboy12358's Avatar
You people with the idle problem, go to the dealer and say "I heard there is an updated flash for my car to fix a problem with idle surge"
They'll take your car for 60-90 minutes, flash it, and when you get it back it will be fixed. As for the only getting 8psi, i would say calibration too, but have them look at that also.
I hit 12.5 psi as soon as i left the dealership.....
edit:
I forget the link, but GM has a site where you enter your VIN and it gives you the PCM calibration info, and you can take that to the dealer (i did) and show them the line that addresses idle surge, that way they know exactly what to ask when they call the techline about it
Last edited by Johnboy12358; Jan 30, 2007 at 09:51 PM. Reason: Automerged Doublepost
Old Jan 30, 2007 | 10:04 PM
βКˉSuPerCharged's Avatar
Yeah when I got Stage 2 it got rid of that damn stumbling idle.
But as someone said. NEW CAR= A Problem = take it to dealer= warranty baby!
Old Jan 30, 2007 | 11:02 PM
Yeah thats another way to do it. I got the flash before I got my stg2 and it fixed my problem with the idle surge
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
