Idling lean and pulling fuel...?
Old Apr 15, 2010 | 08:51 PM
SC07's Avatar
Ok, I'll try to keep this short and sweet. I'm a turbo LSJ car, blah blah, and I've been having this really annoying problem lately.
After I start the car up, and it is warm it starts idling between 16.5-18.xxx it sputters, misfires, all that jazz.
The funny part is the computer is pulling 20% fuel roughly , my LTFT's are at -20.5.
I'm almost positive I have no vacuum leaks, seeing as I've checked everything I could think of.
Things I have checked:
Maf-clean
Inj. buckets-sealed
clamps, charge piping
IM flange
IM sensors
EVAP system
exhaust leaks.
anyways, I have no clue what would cause this, or how to fix it, any help is appreciated.
Kev.
Old Apr 15, 2010 | 09:30 PM
skatin_boarding's Avatar
It just came out of nowhere? What about when the car is fully warmed up? Im going to point my finger at a vacuum leak. But then again I dont know. Edit- Are you on the hahn tune?
Old Apr 15, 2010 | 11:58 PM
SC07's Avatar
yes, I meant after it was warmed up, entering closed loop, it does this and stays like this.
and no, 06black tune
Old Apr 16, 2010 | 12:07 AM
RazaMaJazz's Avatar
My car would do the same thing, but only when it was cold.
Now that its gettin wamer I will start it up and it might do it once, rev's up to about 2K, and then idles smooth.
Old Apr 16, 2010 | 12:25 AM
What do the trims look like while cruising. I say check again for some boost leaks. Then talk to 06black to see if it might be something in the tune.
Old Apr 16, 2010 | 11:29 AM
SC07's Avatar
both trims are zero or close to cruising in vac or boost, pretty sure no boost leaks...yeah im not sure whats up
bump for ideas
Old Apr 16, 2010 | 02:55 PM
Get with your tuner if your sure its not a mechanical problem.
Old Apr 16, 2010 | 02:57 PM
JapEatr's Avatar
South Central *********
vacuum leak
or dead D1S1 o2, check voltages
Old Apr 20, 2010 | 10:57 PM
SC07's Avatar
I found a new little nuance if this give anyones ideas, while driving, it cruises lean, and still pulls fuel, but not as bad as idle (LTFT's -6 thru-10)
Then when i get on the gas and let off, especially when i get on it hard, the car stays rich for a while like 10-13 AFR for 5-XXX seconds.
Very confused.
Old Apr 22, 2010 | 12:37 PM
SC07's Avatar
I also pulled p0172 and p0455 last night
any help?
turbochargedss2012
Sep 20, 2023 12:17 PM
Oct 20, 2015 09:56 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
DocSvensk
Sep 27, 2015 02:24 PM
