Lash adjuster replacement?
Old May 12, 2013 | 04:27 PM
Powell Race Parts's Avatar
Originally Posted by cavfiredesire
Is that guide able to be changed without removing the timing chain?
Like I had asked before though...if it was broken wouldn't the noise be there all the time?
no it breaks at the bottom at first and that allows the chain to float and the tensioner tries to compensate for it so it comes and goes. Meh, you will dive in and find the answer sooner or later. IIRC the guide is not difficult to change, BUT pieces of it will be in the oil pan. Best to drop the motor down enough to pull the crank damper and front cover and fix it right the first time with all the right parts.
LSJ L61 Timing Chain Base Set CEDLSJBTC
$223 plus shipping
Old May 12, 2013 | 05:42 PM
cavfiredesire's Avatar
I ordered the deluxe timing set...
$300 is cheaper then a new motor.
Old May 12, 2013 | 05:58 PM
^^^ good plan. I would use blue loctite on the new 6 mm x 1.0 mm guide bolts, you MUST use a torque wrench ,the spec is 89 inch lbs. The water pump bolt through cover bolt is different its 14 ft lbs IIRC ask Armclure he just replaced that bolt .
Old May 13, 2013 | 08:08 PM
I was reading the LSJ build book..
When it comes to assembly lube does it really matter what kind?
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
