Le Riceburners OFFICIAL Build Thread
I had an identical build to Adams with a 2.5" exhaust. Sounded restricted while on the dyno, like a jet. Switched to a 3" and all is well now sounds wicked too. The dyno showed gains up top. Just sayin'
I was hoping that he'd make bigger #'s here and the cams would've peaked higher, but it is what it is. I'm very surprised your maxing out the 80's already. Hey at least your just about ready for a TVS!
both setups had a straight through non-chambered muffler and resonator.
yeah idk why my injectors maxed out and hockeymans didn't :/ they are the ev6 injectors i did buy them used maybe that has something to do with it?
i'll run some cleaner perhaps. meth kit is hooked up and was spraying during the pulls
but we didn't tune for it as a fuel source, but simply a means of keeping temps down - which do SKYROCKET considering this heaton m62 makes 21 psi now!!
May help you rev out to 8k if you do use it as a fuel source. I'm still baffled at how you're making 21psi. Aren't you at a higher elevation than me too?
Hmm i have no idea and yeah you said you were making 18ish psi right? 21 just seems stupid high to me lol hence i suggested earlier perhaps meth has clogged my cat some
hmmm yeah idk because granted my gauge could simply be off or something but i was spraying quite a bit of meth in this s.o.b. so who knows haha
damn, that is crazy to hear. I've had a few converters fail on me and all have simply vanished. Never ran much meth through one though.
yeah. can the aeroforce read fuel pressure?if i'da had the time ida gotten a aem e85 pump and brfs hell that would have been cheaper too
