Le Riceburners OFFICIAL Build Thread
So i revved earlier with my hood open, showing one of my friends the completed car, and the dipstick popped out! This is caused by too much crankcase pressure. But why i wonder?
My car started doing this after i had the intake off to do dual pass. I had bent the gasket a little when i installed it and it wasn't sealing around the pcv hole. I'd do a compression test, if everything looks fine with that then check the intake gasket after.
yeah admittedly i do still need to do leak tests and compression tests.
random thought; on top of the manifold, passenger side, there is a bosch sensor of some sort, i think its a map sensor? not sure; anyway i noticed the little o-ring holding it in was really loose fitting so i replaced it with a fatter one. perhaps it was meant to be the way it was?
all gaskets are brand new and installed with proper torque sequencing but i guess if it comes down to it i'll re-do that b.s.
Boost leak check is what you are referring to. But for your dipstick popping problem a leak down test to the motor is what you may need to perform if you can't stop it from happening
I second that.
Crankcase pressure pops the dipstick. Plain and simple. All you have to do is determine where it's coming from. If the check valve is stuck completely open, it could be that. But generally they don't get stuck, just leak.
Compression and leakdown test.
the pcv valve in the manifold
the chances of the pcv valve leaking is slim to none and it did not pop the stick on the dyno with the same valve cover on it not to mention a valve cover will not cause excessive case pressure there are only 3 things that will rings or piston and a the pcv valve and that's not whats causing his
But rice is running a completely gutted valve cover with a hose running to his exhaust I believe so the whole system isn't working properly. That's why it was suggested to just try a stock valve cover.
all he needs to do is to disconnect it from the header but those check valves they use in the evac system rarely go bad good idea though
Yup, I still feel his gutted valve cover is causing this.... If so, at least it will be any easy fix.
I WAS gonna do that but now its a hose going to a catch can and back into the intake so it should work just as good or better than the stock system (the stock hosing was clogged)
Even though your gutted VC is less than ideal, I don't think that is the main culprit to this issue. I'd do a leak down test. Not because I think your rings are shot necessarily, but since you had the motor apart and I don't remember if you re-ringed and honed or put it all back in the way it was. Does the car burn any oil at all?
