MAF Sensor Bad?
Old Mar 2, 2013 | 04:29 PM
MrSlickSter06SS's Avatar
Question MAF Sensor Bad?
What have you guys experienced with your MAF Sensor going bad? My air to fuel drops to 10 flat, and boggs my power down when I even push a quater throttle cruising at 70 mph on the freeway. Thinking its bad, or maybe needs cleaned? Or different issue? Thanks for any help.
Old Mar 2, 2013 | 06:02 PM
silvercharged's Avatar
Read how much its flowing off scan tool i personally havent had to do this so i cant give you a base value but someone will chime in.
Old Mar 2, 2013 | 08:50 PM
Where do I get this flow scan? I'll gladly do this ause my car is slow right now.. ;/ lol.
Old Mar 2, 2013 | 09:22 PM
Vander Nars's Avatar
Im having the same problem it seems, i didnt get any codes but mine bogs down after a few pulls.
Old Mar 2, 2013 | 09:42 PM
If you have access to a scanner you can read the values of almost all sensors on car it should a voltage or percentage cant remember off the top of my head. If it beaking up under load you have to watch the maf value and see if it changes dramatic at that given load or just dyes out. Hope that helps a little someobe else should jump in here for the technical stuff i missed. I have a $60 obd scanner from mac in my glovebox that shows these peramiters. Interceptor should also.
Old Mar 2, 2013 | 09:44 PM
Squints's Avatar
Better than what mine did last night. Sitting at idle letting my phone charge and it started spuddering then bam it dies. tried to start it up nothing tried and tried and tried nothing. Finally i got it to turn over started then threw a eng reduced power and engine disabled message unhooked the battery and unplugegd the ecm started right up made it to the house did the same thing when i put it in park. now it want start and if it does it jumps around then bogs down then jumps back then dies and wont start again
Old Mar 2, 2013 | 10:20 PM
Yeah man it helps trust me lol, thanks a bunch i look into this.
Old Mar 2, 2013 | 10:21 PM
WTF? - That is weird and you have no codes?
Old Mar 3, 2013 | 12:25 AM
Squints's Avatar
nope
Old Mar 7, 2013 | 10:04 AM
Nabes07SS's Avatar
Before I put my car away for the winter I had an issue with a MAF code. I would be driving the car and go to WOT and the car would fall on its face. It wasn't the meter itself but rather a year in my intake coupler between the CAI and throttle body. Allowing in metered air in causing the issue.
Old Mar 7, 2013 | 10:09 AM
check ur plugs, this ended up being my problem, my plugs where bad.
Old Mar 7, 2013 | 12:33 PM
Squints's Avatar
Finally goT two codes p2138 &p2122
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Oct 13, 2015 09:32 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
