meth...the big unknown
Old Jan 27, 2009 | 04:53 PM
  #51
ajjaro's Avatar
lol, np
Old Jan 27, 2009 | 05:04 PM
  #52
tdipowered's Avatar
haha alrighty man
Old Jan 27, 2009 | 05:37 PM
  #53
WickedSS2005's Avatar
I made a meth FAQ thread a while back. Just like my TVS FAQ, never got stickied.....
Old Jan 27, 2009 | 09:41 PM
  #54
Sharkey's Avatar
Originally Posted by Zach06CobaltSC
I would tell you how stupid it is to do what your doing, but its not really worth my time lol. I bet your af/r is in the 9s with meth roffle.
no my afr are around 10.9-11.0, they are 11.2 ish without the meth. you can say its stupid but thats your opinion. im not an idiot, if it didnt work i wouldnt be running it, i do know what im doing.
Old Jan 28, 2009 | 04:25 PM
  #55
tdipowered's Avatar
why cant we all just get along
Old Jan 29, 2009 | 08:58 AM
  #56
Zooomer's Avatar
Supporting Vendor
Washer fluid will never allow more power than a car with a proper tune and the proper pulley size. The only thing you can hope for is to recover some of the power you lost by running too small a pulley.
This has been extensively tested and proven and explained by ZZP. We have a standing $1000 challenge to prove us wrong. No one has taken us up.
Old Jan 29, 2009 | 10:53 AM
  #57
ShortStack's Avatar
For one. we dont care.
IF you use meth, you see power gains.
Doesnt matter if its from power lost running too small of a pulley.. you still got that power back.
SO.... if you want it, get it... Despite what ZZP said.
Old Jan 29, 2009 | 11:37 AM
  #58
06_SS_S/C's Avatar
Old Jan 29, 2009 | 03:28 PM
  #59
tdipowered's Avatar
lol i cant wait to get meth...with so many different applications for it including sc and tc....why would so many ppl buy it if it didnt help in some way..im buying it to help with cooling cuz ill be running a 2.7... and according to everyone else i will see gains as well...
i like how OTT is all for it and there people use it...and ZZP is against it...OTT FTW
Old Jan 29, 2009 | 03:30 PM
  #60
Zooomer's Avatar
Supporting Vendor
You'll hear a lot of "it works" or "i like mine" or "I can feel it" or "you 'see' power gains" but this is not proof of anything. You'll never see a comprehensive dyno showing you the gains because they cannot be had. Water or washer fluid can only decrease power for the purposes here.
Water added to fuel slows the burn rate which has a similar effect of lowering ignition timing. This cannot be overcome by boost except in low RPM situations where lower timing doesn't cause such a loss in HP and parasitic blower losses are lower. So in theory, you could gain some torque but HP will always suffer over less boost and no washer fluid. We plan on doing a graphical chart in a manner that easy for new modders to understand shortly. Stay tuned...
It's popular because methanol and water are verbally used as if they are the same thing. The people making gains are spraying methanol, tricking some people who spray washer fluid into thinking they are doing the same thing.
As far as it being popular? Only in this market because it's new and most people don't dyno their cars w/ and without. 1/2 water 1/2 gas was very popular for a while; the patches on the bottom of your feet to remove impurities were popular; stones for the washing mathine instead of soap, magnets for your fuel lines or for your ankles/wrists; electrolysis kits for under the engine to make hydrogen and oxygen. All of these sold millions of dollars. The argument you're using is ad populum, meaning that if everyone is doing it, it must be right. It's not. Do the reasearch by checking in other forums using supercharged cars. Find out what mixtures they are spraying and you'll quickly learn that washer fluid isn't a good mod. If you find a kit that sprays 90 or 100% alcohol, it will work and work well once you tune it in but don't be confused into thinnking that a high water content mix will perform a similar task.
Old Jan 29, 2009 | 03:40 PM
  #61
ajjaro's Avatar
what about anti freeze? it comes as 99.96% methanol if im not mistaken, add some water, make it 90/10 would that be ok?
Old Jan 29, 2009 | 03:43 PM
  #62
ShortStack's Avatar
Id use more water for the cooling aspect of it.
Old Jan 29, 2009 | 03:55 PM
  #63
tdipowered's Avatar
yea thats what im saying..im using it for more of the cooling aspect...maybe ill see gains becuase the air charge is cooler but thats what i want it for
Old Jan 29, 2009 | 03:56 PM
  #64
Zooomer's Avatar
Supporting Vendor
ethanol glycol. It would form the same function of knock supression by slowing the burn rate and the addition would cool the charge but the motor wouldn't like it, the cat would get detroyed, the emissions would be terrible and the HP would still drop.
Do you have a before and after IAT using washer fluiid? Do you have before and after MAP readings? How about MAF?
Old Jan 29, 2009 | 03:58 PM
  #65
ShortStack's Avatar
No im saying add more water than justa 90/10 mix...
Once again, no one uses just straight washer fluid... If they are smart they mix in a bottle of heet or two.
Last edited by ShortStack; Jan 29, 2009 at 03:58 PM. Reason: Automerged Doublepost
Old Jan 29, 2009 | 03:59 PM
  #66
PhantomSS's Avatar
fact
more timing doesnt mean more power
i personally like 70/30 mix. More water didnt help when tuning.
Old Jan 29, 2009 | 04:04 PM
  #67
tdipowered's Avatar
no becuase ther reason i started this thread was to figure out to buy it...and what would the maf matter its way before the charge would be and there are post in this thread with people saying there low iat2s becuase of meth/water injection...if you dont like it or agree with it then why are you posting in here?
Old Jan 29, 2009 | 04:07 PM
  #68
zinner's Avatar
Moderator Alumni
I prefer nitrous oxide injection. It has a seat of the pants increase for sure. Just ask Boxxy
Old Jan 29, 2009 | 04:08 PM
  #69
tdipowered's Avatar
lol not a fan of NOS though ^^
Old Jan 29, 2009 | 04:22 PM
  #70
06SS ALL DAY's Avatar
I don't think you should put drugs in your car... It's as addictive as nose candy I heard
Old Jan 29, 2009 | 04:29 PM
  #71
1badBlueberrySC's Avatar
I do... however... I'm not going to divulge them to you, why because I frankly am one of the few members tired of your misinformation!
Old Jan 29, 2009 | 04:44 PM
  #72
ShortStack's Avatar
^^^ Thankyou God.
Old Jan 29, 2009 | 04:45 PM
  #73
tdipowered's Avatar
1badBlueberrySC FTW!!!!!
Old Jan 29, 2009 | 04:46 PM
  #74
qwikredline's Avatar
hey blueberry have you heard of ethanol glycol? I have heard of ethylene glycol, propolene glycol, isopropol alchohol...ethanol glycol? huh? more misinformation....
Old Jan 29, 2009 | 04:47 PM
  #75
ShortStack's Avatar
^^^ lol.
