more boost?
Old Jan 5, 2010 | 12:37 PM
Rob9_ss's Avatar
more boost?
I have heard that on my stock 06 sc, you can switch some tubing around from the wastegate to get more boost. if its true what engine problems should i expect if any?
Old Jan 5, 2010 | 12:44 PM
SCcobaltSS's Avatar
Alot of people will tell you use the search button. Just remember that. But I see your new so I will get you the link.
https://www.cobaltss.net/forums/show...ost+bypass+mod
Also, more boost doesnt mean more power all the time.
Old Jan 5, 2010 | 12:47 PM
Fonzi1289's Avatar
Yeah in the how to section man.. Its called the Boost Bypass Mod
Old Jan 5, 2010 | 12:49 PM
Staged07SS's Avatar
Administrator
Administrator
Do not do the boost bypass mod ....
Old Jan 5, 2010 | 12:51 PM
Rob9_ss's Avatar
i appreciate it man..
any one ever done it?
Old Jan 5, 2010 | 12:55 PM
D4u2s0t's Avatar
yea, it's silly.
basically, you want to run the least possible amount of boost to hit a certain hp goal. Suppose you want to hit 300hp. One car does it on 21 psi, and the other car does it at 16psi. (just making up #'s here) The car that does it at 16psi is running much more efficiently. Less boost, same hp, more reliable car.
Ricer math says more boost = more power. not always the case.
Old Jan 5, 2010 | 12:58 PM
SuperSilverSaturn's Avatar
Buy upgraded injectors and a smaller pulley with a tune. Its the only way to get more boost.
Fonzi1289's Avatar
^This
Old Jan 5, 2010 | 01:07 PM
Staged07SS's Avatar
Administrator
Administrator
read the post directly above yours .... more boost does not = more power all the time
Old Jan 5, 2010 | 01:24 PM
Pyros777's Avatar
boost bypass mod should only ever been used as a troubleshooting tool to determine whether your bypass actuator is working or not.
Old Jan 5, 2010 | 01:31 PM
Staged07SS's Avatar
Administrator
Administrator
agreed !!!
Old Jan 5, 2010 | 05:05 PM
BlueSS/SC's Avatar
yup! helped me figured out that my belt wasn't slipping.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
