My potential mini-build list...
Lol soon enough John. When I have things worth posting ill have em up. Right now I just have mostly a pile of parts in my spare bedroom. Waiting on a few little things to get rolling hard.
just to keep it updated:
zzp stage 2 cams - aquired
80# performance autowerks valvesprings - aquired
ecotec viton valve seals - aquired
lap existing valves onto new head
lsjion head - being paid for and worked on!
ati overdrive dampener - aquired
zzp machined front cover - aquired
zzp magnetic drain plug - aquired
coppertech exhaust mani gasket - aquired
ottp 2.7" pulley - aquired
zzp stealth heat exchanger - aquired
new devilsown progressive stg2 meth kit - aquired
Mrb timing chain bolts
still needed
Arp headstuds
80# injectors, more fueling stuff if needed
timing set (75k may as well do it)
smooth out intake manifold
plug blower silencer holes
balance shaft delete bushings
Cylinder Head Gasket 2.0 LSJ 55352039
Loctite 510 Flange Sealant
Loctite 277 Tread Locker
CMD #3 Extreme Pressure Lube
Kent Moore J-43649 Valve Spring Compressor
lots of new oil and NGK BKR7E spark plugs
And a dynotune at performance autowerks
fixed?
still needed
Arp headstuds
fixed?
a spark plug has 2 functions 1 is to ignite air and fuel charge 2 to help control the combustion temp e 85 burns a lot cooler then gas so a 1 step colder plug can pull to much heat from the combustion chamber and affect the burn and cause cold start problems so you need to keep some heat in the chamber go back to stock heat range now nitrous and e you may need to drop back to a 7 due to the extra extra heat induced from the nitrous
