My potential mini-build list...
Old Dec 11, 2013 | 02:04 PM
  #426
Staged07SS's Avatar
Administrator
Administrator
i just checked out without the info.
whatever lol.
bet money the dude at the counter asks me if they are for my ss and tells me they are wrong.
If he does, tell him to go pound sand, lol.
Old Dec 11, 2013 | 02:06 PM
  #427
Originally Posted by mrbelvedere
its at the post office I got to get it
Thanks buddy!
Old Dec 15, 2013 | 10:30 AM
  #428
Got some parts in yesterday. This ati is therealfuckingdeal.com
Also prepped my other rims, strut tower brace and valve cover for getting powdercoated.
These are gonna be JDM #As #****
Old Dec 15, 2013 | 11:08 AM
  #429
574's Avatar
574
Nice color choice
Old Dec 15, 2013 | 11:10 AM
  #430
Its actually gonna be more like that new light blue mustang color - like 1lsj2nv actually
And thanks, really hope it works great!
Old Dec 15, 2013 | 11:16 AM
  #431
TStone's Avatar
Was the link for MrB bolts posted?
And for the correct heat range copper plugs?
You can order them directly from MrB or from CED. Same thing.
Old Dec 15, 2013 | 08:25 PM
  #432
ThexGovenor's Avatar
Hey rice, out of curiousity, why are you going to still run meth? If you are using E85 and the cooling mods you have listed... I cant see it being beneficial enough to bother running. The rest of the build looks great! Cant wait to hear your numbers.
Old Dec 15, 2013 | 10:50 PM
  #433
Heres my worthless philosphy
During the summer with the same setup minus the stealth h/e the temp difference was great.
Running a cooler burning gas will not affect how the blowers spinning rotors from generating heat and warping, as well as creating hotter intake temps
Old Dec 15, 2013 | 10:55 PM
  #434
So guys i really need your opinions here.
Was at Joses exhaust shop yesterday talking to Hector, and he was telling me to get an EKG gauge. I said what for? He says to monitor my EKG valves.
So i go home and look up on ebay an EKG gauge. It looks so simple to install and use. You simply hook one wire up to the battery, and another to ANY point on the chassis. It can pick up the signal anywhere from the vehicle. As long as it is connected, a green light will stay on telling you that the EKG valve is fine.
Id rather be safe than sorry so i bought one.
Old Dec 16, 2013 | 05:45 AM
  #435
Corey V's Avatar
Yo is that the gauge with the beeps and the lines? Like when the battery dies it goes all flat and ish? And you gotta jump it and it brings it back to life?
Old Dec 16, 2013 | 07:47 AM
  #436
JapEatr's Avatar
South Central *********
ElectroKardioGraph?
Old Dec 16, 2013 | 08:04 AM
  #437
Powell Race Parts's Avatar
Smh
Old Dec 16, 2013 | 08:53 AM
  #438
Pretty sure you mean EGT and get an AEM, you'll learn where normal operating temp it and where your normal 1/4mile will put your EGTs then you know when it starts going higher to back off before your engine dies (also probably could figure out if you're actually spraying meth or if it's having an issue)
Old Dec 16, 2013 | 08:59 AM
  #439
Originally Posted by JapEatr
ElectroKardioGraph?
Mayb's
i'm just trollin. lol
Old Dec 16, 2013 | 10:34 AM
  #440
InfraRedline's Avatar
Lookin good! And had to let out the inner troll didn't you lol
Old Dec 16, 2013 | 11:23 AM
  #441
mrbelvedere's Avatar
the troll is not strong with this one
Old Dec 16, 2013 | 03:09 PM
  #442
i admit too easily haha
Old Dec 19, 2013 | 03:19 PM
  #443
so i've been thinking. before i put the car away, whenever id go WOT i'd hear some bad noises in front of me. i thought it was something with the trans/axles... not sure...
but maybe it was engine knock??
it did sound quite a bit like in this video below.. :/
if so... i'm hoping it just something in my tune since it wasn't doing this before my meth quit working. the reason id go wot knowing this was because James Rakes told me it was not tuned for meth... fml
kinda like this maybe... i gotta get a video i think
Old Dec 22, 2013 | 03:35 PM
  #444
looking for a few things:
adjustable cam gears?
and balance shaft delete bushings.
should i go this route:
http://www.ebay.com/itm/Ecotec-Balance-Shaft-Delete-Elimination-Kit-/180538061734?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a08e833a6or this route:
Level Zero Motorsports
also... some new powdercoated goodness...
Old Dec 22, 2013 | 03:40 PM
  #445
other questions...
what other tools to i really need? like do i really need the valve spring compressor? engine will be out of the car.
and can anyone link me to where to get the camshaft alignment tool or do i not need that since new cams are goin in?
just looking to save my time and money
Old Dec 22, 2013 | 03:46 PM
  #446
Blairwolf's Avatar
Rice is LSJion porting you a head for this or are you just going to put the cams in? I had josh install my valve springs when he did the head saved me some time.
  #447
IonNinja's Avatar
other questions...
Valve spring compressor
Piston ring compressor
Cylinder hone deglazer
Those are the only special tools I needed
Old Dec 22, 2013 | 03:49 PM
  #448
Omiotek's Avatar
I DOUBT you have rod knock.....ecotecs rarely have rod knock unless you are running the corn and not doing the proper care or someone has your car tuned really really rich or has too much fuel at idle.
anyways when rod knock strikes you usually have rod knock even when the cars running not just at wot. easy way to check is to pull the pan off and wiggle the rods around. if they wiggle a lot its going to spin sooner or later and at that rate you might as well build the bottom end.
Old Dec 22, 2013 | 04:01 PM
  #449
lsjion is porting my head i oughta bring this up to him thanks for the tip!
Old Dec 22, 2013 | 04:10 PM
  #450
other questions...
you want to preferably have a machine shop do it at a 320grit blade hone if not use a 240 grit ball hone go clockwise then counter clockwise there Is no camshaft alignment tool
get the guides checked
Last edited by mrbelvedere; Dec 22, 2013 at 04:10 PM. Reason: Automerged Doublepost
