need help balt blown 4 piston ring
Old Jan 20, 2008 | 06:24 PM
lsjwannabe's Avatar
thanks
Old Jan 21, 2008 | 11:17 AM
Area47's Avatar
Rent me! per hour
something is off. something happened out of the extreme ordinary for this sucker to go. id venture to guess that you held the gear upwards of 4k rpms for about 20 seconds, then laid into it. then it egt's skyrocketed to blamo zone.
dunno, just a guess.
Old Jan 21, 2008 | 11:25 AM
BriantheLion26's Avatar
How bad do EGT's get on a 1/4 mi run? That is the most I beat my car and I don't need a piston going. Last time I was there it was hot as ***** out but I let the car cool a good 30 min atleast in between each run with the pump and fans on.
Old Jan 21, 2008 | 11:30 AM
Area47's Avatar
Rent me! per hour
dunno. i did a 65-148 mph run saturday morning. mine hit 1425 at 148 mph when i let up in 4th. no hiccups to speak of.
egt's vary car to car due to difference in tunes.
Old Jan 21, 2008 | 11:31 AM
That is what i figured.. leaner will be hotter right? What is a temp that is "kaboom" territory? I'm sure your meth helps that a **** load too. With the gm tune being so rich I hope doing some 1/4 mi runs won't nuke it.
Old Jan 21, 2008 | 11:33 AM
Area47's Avatar
Rent me! per hour
meth, timing, open exhaust, afr. blah blah blah. i keep the cars at or below 1500 on a 3rd gear pull on a dyno.
street tunes vary.
Old Jan 21, 2008 | 12:16 PM
blacksssc06's Avatar
well i think im going to copy off of the 300+ lsj head work 283 cams and 10:0.1 pistons at 18psi return style fuel system and dual coolant bypass and bigger heat exchange
Old Jan 21, 2008 | 12:21 PM
Area47's Avatar
Rent me! per hour
6880 is a hell of a bang
Old Jan 21, 2008 | 09:14 PM
speed_demon05's Avatar
Im curious as to how you blow the #4 piston? I mean im not too sure as to how it happens. I've had my 05 for a year now and 32,500 on the engine. I just don't want the same problem that's all. Becuase i definately don't have 1500 for new pistons and internals not including whatever else.
Old Jan 22, 2008 | 08:37 AM
dont make more the 18 psi stay at a 10.7 afr dont go above 11.2 and dont beat the **** out of the car 24-7
Old Jan 22, 2008 | 10:56 AM
  #36
Psykostevo's Avatar
It's best to let the car idle for a little bit after a run, even if you have intercooler pump and fans running. Gotta cool the head itself first.
Good luck with that. You might want to pick up some tubes of elbow grease and excedrin while you are out at the store picking up your return fuel system and such.
Last edited by Psykostevo; Jan 22, 2008 at 10:56 AM. Reason: Automerged Doublepost
06MetallicBalt
Jul 20, 2025 08:47 PM
HEATON
Oct 16, 2015 07:21 PM
ThoR294
Sep 28, 2015 05:31 PM
roth
Sep 26, 2015 12:16 PM
