o2 sensor/ zzp downpipe
my o2 sensor on my 3" downpipe i installed last night hit the heat shield, rubbed a whole in it, and it rattles horribly. is there any fix to this? do they sell shorter sensors or what can i use to temporarily plug the 02 bung
Can't you push the heat shield out of the way? Any time I've ever had a clearance problem there, the heat shield easily pushed away enough to avoid contact.
tried that but the sensor wore a whole through the heat shield and was rubbing on the body of the car. so i might try that 90 or just plug it until emissions.
