Official Procharger Build Thread
The p1sc will not fit unless I had no headlight! Ill show you what i mean when I finish the piping end everything this weekend! The c1 should make enough power to hit 320 I have seen it in hondas so we should have no problems!
There very tame overspun! But heres a little sample of what im looking for. There is a civic hatchback in sweden or somewhere that is running 14 psi and making 308 whp! I want to be running 21-22 psi and make 320 or more with the new setup! I think that are stock manifold is that bad for the procharger and the factory exhaust system didnt help any either! But he is a b18c1 and I think the ecotec is built much better then a honda especially because we dont have vtec to stall us or get in the way of boost!
Anyone have flow bench numbers! From what I have seen are heads flow close to the same as a K series and better then a 4g63T. I get some numbers from my porting tonight to show you what I mean!
the information you have is way off base. even the race ported lsj head flows less than a stoc 1g dsm head
you can not compare a k series to this engine. it blows both of them out of the water
I know are exhuast ports are plugged for sure! I have ported the crap of them! The GM race head is only flowing somewhere in the 280-290 cfm I cant remeber but you get the picture! There is a reason that the ecotec holds most of the 4 cyl records in drag and max power type of events!
I know but there still there! No, Its to hard for me to explain by typing but Ill see if I can get somthing so paste on here so you can see what I mean!
Thanks for the conversation Area! I still think that we should be able to hit the mark on the procharger build with a better intake manifold and intercooler!
Rick
Last edited by rickyw; Feb 15, 2008 at 07:55 AM. Reason: Automerged Doublepost-Correction
Thats wrong. At the shop I used to work at we flow benched a ported 1g head, and it flowed like 255 or something. As I recall the race ecotec heads flow like 270-280.
