Official Procharger Build Thread
Old Feb 3, 2008 | 07:47 PM
  #1001
rickyw's Avatar
its currently being worked on
Old Feb 3, 2008 | 07:59 PM
  #1002
Ec0t3cHp0w3r's Avatar
?? wait a min. but i thought they made one 4 a 2.2l?? i know it was for an ion but its still the same engine as mine
Old Feb 3, 2008 | 08:05 PM
  #1003
chevytech007's Avatar
We havent finished the lsj but give me a pm and we can talk!
Old Feb 4, 2008 | 11:34 AM
  #1004
bc3tech's Avatar
speed mafia (http://www.speedmafia.com) does make one for the 2.2
Old Feb 11, 2008 | 08:54 PM
  #1005
update!
Front Mount Intercooler on the way!
2.4l intake manifold on the way!
Should be running the procharger very soon with the new setup.
New setup:
FMIC
intake manifold
Bigger K&N filter
Shorter belt
Custom adaptor plate for 2.4l manifold!
Full langth header and cat-back exhuast system. ( no more stock exhaust!!!!)
Sheet metal intake manifold coming soon!
Ill keep you posted!
Old Feb 11, 2008 | 10:39 PM
  #1006
elecblue06's Avatar
Originally Posted by chevytech007
update!
New setup:
FMIC
intake manifold
Bigger K&N filter
Shorter belt
what happened to the current vids
Old Feb 12, 2008 | 10:40 AM
  #1007
rickyw's Avatar
nice chev
Old Feb 12, 2008 | 03:47 PM
  #1008
elecblue06's Avatar
nice chev
yea it should be pure sex when he gets it running wel...untill his motor goes boom that is lo
Old Feb 12, 2008 | 05:26 PM
  #1009
XM15's Avatar
update!
New setup:
FMIC
intake manifold
Bigger K&N filter
Shorter belt
Doh! I missed your post about sending the PM. Oh well, I'll find someone to take this hunk of plastic off my hands. Good luck with the rest of the build!
Old Feb 13, 2008 | 12:27 PM
  #1010
Speed Mafia's Avatar
u got a mani or what?
Old Feb 13, 2008 | 02:47 PM
  #1011
IonNinja's Avatar
why are you getting rid of the LSJ mani?
i know you're going FMIC but still...?
Old Feb 13, 2008 | 05:32 PM
  #1012
ptrblkz24's Avatar
If people are getting 350+hp with the stock lsj manifold,im sure the procharger should be no different.Right?
  #1013
XM15's Avatar
Yeah, I've got the 2.4 manifold. If someone wants it, I'll sell it. It just doesn't have the brake booster hose.
Old Feb 13, 2008 | 05:50 PM
  #1014
rickyw's Avatar
Even Hahn had said our manifold sucks.....
Old Feb 13, 2008 | 05:56 PM
  #1015
Area47's Avatar
Rent me! per hour
the STOCK lsj manifold is good to well over 400.
Old Feb 13, 2008 | 06:08 PM
  #1016
ebristol's Avatar
Hahn said it sucks for turbo'd applications. But it does its job for the Heaton. If you are going to quote other people get it right.
Originally Posted by EcoBoost
The manifold is a key component of our apporach with this car, as we've found the stock intake manifold on LSJ to be an airflow nightmare. We refused to allow our turbosystem to be hobbled by its shortcomings. For its intended purpose, the stock LSJ intake manifold is adequate, and as an engineering achievement, they did a fine job of fitting so many components into such a tight area.
Old Feb 13, 2008 | 06:31 PM
  #1017
I think so. There are a few differences in the turbo vs the procharger! The procharger will only make as much boost as I can spin it. The turbo will overspin to hit my boost levels!
I did a test on the intake manifold with 2 boost guages to find out what im losing threw are stock intercoolers. And when I saw the stock boost guage hit 12 and the one in the pipe hit 16 it was time for a change. So that the reason for getting rid of the lsj manifold is for 3 psi of boost and less restriction for the procharger! This should solve the late boost problem and give me even more top end! Also I will be using a inlet big enough to feed a diesel pick! And the will give me another 1.5 psi of boost! I also tested the procharger without an air filter just to see!
So if the turbocharger wastegate is hooked to the manifold then it will make the boost it needs to hit the mark to open the wastegate! Do you see my point? So it will be one more go for the procharger!
Im just waiting on my intercooler! and then bame back in biz!
Old Feb 13, 2008 | 06:34 PM
  #1018
ptrblkz24's Avatar
Sounds good man.Hurry up and get er done
Old Feb 13, 2008 | 06:35 PM
  #1019
Area47's Avatar
Rent me! per hour
do you understand the concept of compressor maps?
have fun blowing apart the plastic manifold
Old Feb 13, 2008 | 07:28 PM
  #1020
IonNinja's Avatar
isn't boost a measure of pressure? meaning, removing restriction essentially should drop boost levels not raise them? i don't get how these things are going to increase boost levels...clarification?
Old Feb 13, 2008 | 07:55 PM
  #1021
Thats why I have a sheet metal back up but its not ready for awhile due to lack of funding at the moment but the plastic should take 20 psi I hope
That will at least give me a base where I can see what boost I can make without the lsj manifold!
As far as the higher boost is concerned there is more boost because there will be less restriction in the intercooler. All intercoolers of pressure drop but the lsj has a lot! That is where I am getting more boost. Not through the procharger because its already doing it! but it doing before the intercooler!
Old Feb 13, 2008 | 08:15 PM
  #1022
Area47's Avatar
Rent me! per hour
im fully aware of the pressure drop across a larger area vs a smaller area. leaving all of the techno bable out of this. my suggestion is simpley to find a slightly larger procharger instead of trying to overspin the blower that you have now to combat the pressure loss across the manifold, and the intercooler.
just a small suggestion.
dunno. just a random idea
Old Feb 13, 2008 | 09:37 PM
  #1023
bc3tech's Avatar
sounds like a C-2 is in order.
Old Feb 14, 2008 | 12:35 AM
  #1024
I would love to throw on the c2 or a p1sc (i dont think it will fit but)! The major problem is the lag is why i want the boost! I want that boost down low not up high. The procharger makes a lot of power up top but just taking to long to get there!
Thanks for the suggestion! I may run a f1r Think big!
But I think the FMIC idea will solve a lot of the issues with the lack of boost at lower rpm also there will be a custom belt to fit way better and hold tight to the pulley!
Old Feb 14, 2008 | 10:42 AM
  #1025
Area47's Avatar
Rent me! per hour
a p1sc is in order
you're dangerously close to the limit of that blower itself. just making a suggestion
remember. it's not a v8. you don't have torque
