Official Turbo LSJ thread!!!
Old Sep 17, 2011 | 09:06 PM
  #576
BLAZIN07SS's Avatar
I'm too JDM for you
You are really overthinking this 07sssc. An s252et is a journal bearing turbo. Due to the small size of the turbo, it spools very quick. For your power goals you do not need valvesprings or balance shafts. I'm on a s256et on 25psi with a 100% stock engine
Old Sep 17, 2011 | 10:48 PM
  #577
07sssc's Avatar
Ya Blazzin ive just had so much input form others im just trying to break it all down wih questions as they come up so i really know. when i put this kit together but thank u for telling me that..so i only order what i need.
Old Sep 18, 2011 | 10:06 AM
  #578
mexi_loco's Avatar
guys whats all i would need if i wanted to go external wastegate? i know i need a different turbo mani, another turbo, wastegate dump, waste gate obiously...what else? would my hahn dp work if i were to switch turbos
you don't need a different turbo. I am running the s20g and all I did was remove the internal gate and welded it closed. Other than that, you will need a wastegate flange welded onto your turbo mani, and a dumptube. Also you want to make sure the spring in the wastegate is the right one for the boost that you're setup for.
Old Sep 18, 2011 | 10:48 AM
  #579
terry11's Avatar
I'm liking the knowledge
Old Sep 18, 2011 | 11:25 AM
  #580
Black05's Avatar
Well, I might be turning to the dark side eventually here. A blown Lsj ring (among other things) has gotten a bit expensive, and the idea of putting a new motor in is looking better and better each day
Old Sep 18, 2011 | 11:47 AM
  #581
jonathan923's Avatar
i see that sounds real good man. but how do they customize the hahn manifold like that? and where or how can i find the wastegate flange? i like that idea but i didnt know it was possible
Old Sep 18, 2011 | 12:25 PM
  #582
mexi_loco's Avatar
well, I actually ended using a zzp log manifold that came with a wastegate flange already welded to it. So that's one way to do it. Other than that, it's really just a simple means of finding the most direct flow of exhaust on your mani and tapping that for the wastegate.
ZZP also sells all the flanges you need. But before you go out and get one, make sure that the wastegate you are getting doesn't already have one. I got a TIAL 38mm that already came with one as well.
built zzp motor with their 256et setup?
Old Sep 18, 2011 | 12:48 PM
  #583
slawson0042's Avatar
I'm officiall turbo'd now....
kinda..
lol.
Old Sep 18, 2011 | 12:56 PM
  #584
woohooo lol. welcome to the family
whats missing? why kinda?
Old Sep 18, 2011 | 12:58 PM
  #585
ZZP also sells all the flanges you need. But before you go out and get one, make sure that the wastegate you are getting doesn't already have one. I got a TIAL 38mm that already came with one as well.:
thanks for the input bro. yea terry11 here was telling me about the manifold so i think its an easier way with the zzp mani. now does it bolt up with the s20g?
Old Sep 18, 2011 | 01:14 PM
  #586
theres three manifold bolt i couldnt get tight and its not spooling the turbo till around 5500.
Old Sep 18, 2011 | 01:30 PM
  #587
what turbo is it that ur using again? and i dont think it was a good idea to try running the car with loose bolts lol
Old Sep 18, 2011 | 01:43 PM
  #588
05Slowline's Avatar
gotta use an open end on some of the bolts lol and that's prob why theres no spool till 5500 though idk what turbo u have lol...
Old Sep 18, 2011 | 03:04 PM
  #589
yea its a big leak. i only drove it home. i havent been hard into it. coasted it all the way home. its dying to spool at 3300 but im thinking the leak is whats keeping it from doing it then when it hits 5500 the pressure in the manifold is enough to spool it up.
Old Sep 18, 2011 | 03:06 PM
  #590
problem is that the bolts are right between the logs on the manifold i can't get an open end on it due to that damn coolant pipe. im working on it right now using an apparatus of extensions and swivels.
Old Sep 18, 2011 | 03:42 PM
  #591
05Slowline's Avatar
what mani?
Old Sep 18, 2011 | 06:42 PM
  #592
07sssc's Avatar
that sounds intense
Old Sep 18, 2011 | 08:11 PM
  #593
EXsoccer1921's Avatar
was i not lieing when i said the manifold is going to be a bitch? hahahah.
Old Sep 18, 2011 | 08:57 PM
  #594
BlkWdoSS's Avatar
thats probably what they did. cause i was asking about the ewp anyways. i don't have ANY of the hvac lines haha. no t-stat housing, lines, compressor, condensor, oil cooler, whatever that pipe is called that goes from the waterpump to the housing, etc. thats why i want to go with a different piping setup so all you see is the cold side going in to the manifold. would look so clean
mine has all of those things and the IC piping is hidden except for the cold side going into the throttle body
you have pretty much everything listed you will need, there are instructions on getting a flange welded onto your current manifold and what angle to the exit that it needs to be. Your downpipe will still work you would just need to change the flange to be the same as your turbo.
Originally Posted by 07sssc
I figured it would not be over kill if i had my tuner dial down the timming a some and set my boost at 10-15psi. I figured its all in the tune. I just figured ball bearing turbo spools quicker and flows more air. then the joural turbo.s do. so i figured that would be the turbo to go with. an like someone said almost no lag which is a good thing.
would i need 78lb vavule springs and netural balance shaft ? to for this turbo build ?
you are making this too difficult, slow down, do some research and if you really want to know a **** ton about turbos and everything you need. there is a book, Maximum Boost by Corky Bell, that will get you perfectly set for turbo-ing any car.
asking questions is a good idea and easy way to learn but asking too many questions too quickly and getting confused doesnt help anyone. slow down, read things, and do tons of research, a lot of the questions you are asking have already been answered in so many different places. Honda sites, mitsu websites, nissan, subaru, ford, this site and tons of other sites. The information is there, you just have to research it. Try to stay away from companies websites because they are all trying to sell you something. Look for independent answers.
l8r,
PD
Old Sep 18, 2011 | 09:16 PM
  #595
BlkWdoSS's Avatar
ratchet wrenches FTW! thats how I got mine in, also could help to listen the motor mounts and angle the engine forward to allow for more room between the block and firewall, just make sure you have a jack/engine hoist/something holding the engine up
l8r,
PD
Old Sep 18, 2011 | 09:31 PM
  #596
l8r,
PD
I have tried every wrench, ratchet wrench, socket combo i can and still cant get one of them in. it needs about 3 more full turns.
Old Sep 18, 2011 | 09:55 PM
  #597
mexi_loco's Avatar
that's what my s20g is currently bolted to right now, although i should tell you that I have a custom vband and exhaust piece connecting it to the downpipe.
Old Sep 18, 2011 | 10:40 PM
  #598
BlkWdoSS's Avatar
if you were closer, I would definitely give you a hand. It took a lot of finesse but we got mine in.
are you coming at it from the top or the bottom? what else is in the way, what is restricting you? you may have to take the turbo off, and remove everything, what causes the most restriction, I know and have a **** ton of specialty tools, I may have a solution just have to have an idea of what im up against
l8r,
PD
Old Sep 18, 2011 | 11:17 PM
  #599
l8r,
PD
Thanks for the help bro. Its between the two outlets on the drivers side. If I'm up top the open ended wrench won't fit because of the little block sticking out of the head. If I go from the bottom the coolant pipe won't allow me to get the wrench in the position I need it to be in. The turbo isn't anywhere near it. Idk what to do. I got tired of looking at it and decided to go at it again tomorrow.
Old Sep 19, 2011 | 02:55 AM
  #600
BlkWdoSS's Avatar
Have you tried a quarter inch deep socket with a low profile ratchet? the quarter inch tools fit in tighter spots
l8r,
PD
