Official Turbo LSJ thread!!!
Old Jul 7, 2013 | 08:41 PM
  #6026
mexi_loco's Avatar
^this...
Old Jul 7, 2013 | 08:43 PM
  #6027
Killa SS's Avatar
i probably have about 350ml of oil in my catch can from the last few months. I need to clean it out but I still think it sucking the oil out of the crank case. I need more venting that is for sure, one way or the other.
I get about a quarter sized oil drop under my car everyday after several pulls coming from the bov area. Its not leaking a ton. My oil looks clean and is full, its just annoying to blow smoke after you pulled hard on someone in your car club and they are like, "dude why is your car smoking".
Tell them ur running on 3cyls lol
Old Jul 7, 2013 | 09:20 PM
  #6028
c130aviator's Avatar
I got one better, I cracked my hahn manifold again along the weld seams.. I take back all the stuff about my MBC... Sigh.
Old Jul 7, 2013 | 09:29 PM
  #6029
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by Killa SS
Thats what I got. Works better then the one I got from zzp. The one I had from zzp didnt lock and turned its self down while drivimg so id be boosting 18 one run then 15 the next.
then it must have been broken. mine from zzp locks
that Hahn manifold is a piece of junk. get a saab lk9
Old Jul 7, 2013 | 09:31 PM
  #6030
i have had two major issues with my build since I got this thing over 400whp. The hahn manifold was the cause of a 2 month long boost leak search that didnt turn up until i pulled it off the car. This time it was the first thing I checked before I bought another boost controller. I have already wasted 40 bucks on welding it up, now I think its going to go in the trash unless someone comes up with a better use for it.
Old Jul 7, 2013 | 09:36 PM
  #6031
574's Avatar
574
Woah woah woah don't throw it in the trash... Ill take it for free fitty free
Old Jul 7, 2013 | 09:52 PM
  #6032
noorj's Avatar
I'll buy it off you!!!!
It helps that I own a tig and love welding aluminum
Old Jul 7, 2013 | 09:55 PM
  #6033
what would you give me for it?
Old Jul 7, 2013 | 10:03 PM
  #6034
BLAZIN07SS's Avatar
I'm too JDM for you
in other news, i have never had to drain my breather tank. i always just get a light film of oil near the breather filter. nothing a little carb cleaner doesn't clean though
  #6035
Tjolley's Avatar
I could have told u those were junk along time ago. Lol
Old Jul 7, 2013 | 10:07 PM
  #6036
yeah, i knew it was going to be problematic just never figured so soon. I had a racecar builder fix this thing up, extra heavy welds. Its just that the plate is so thin that it flexed under boost and under vacuum and after just a week of 24 psi pulls its leaking boost like a sieve... MAN I AM SO sick of this car, right now. Time to take a break from it for a while.
Old Jul 7, 2013 | 10:09 PM
  #6037
thats cause you still have your vc baffles.
Old Jul 7, 2013 | 10:42 PM
  #6038
Tjolley's Avatar
Simple fix put a new flange on it done deal u can buy one with O ring grooves machined in the face. So that thing can flex and twist all it wants.
Old Jul 7, 2013 | 10:49 PM
  #6039
on a better note, got to run with my local car club and had a ton of fun racing cars with V8's kept up with them in spite of having a horrible boost leak.
Old Jul 7, 2013 | 10:51 PM
  #6040
Tjolley's Avatar
Here u go
Old Jul 7, 2013 | 11:14 PM
  #6041
Old Jul 7, 2013 | 11:36 PM
  #6042
Killa SS's Avatar
Im pretty sure I told u long ago that mani was junk dude! Weld plates on it so it cant flex. It will be ugly but function>form
Old Jul 7, 2013 | 11:41 PM
  #6043
Tjolley's Avatar
Get a saab mani
Old Jul 7, 2013 | 11:45 PM
  #6044
At the power I am making I am pretty sure the saab mani is going to hold me back. TTR made like 20whp on their manifold over the LNF unit. Taking a 20 horsepower hit after I come this far... I cant do that. I may buy a TTR manifold.
Old Jul 7, 2013 | 11:46 PM
  #6045
mrbelvedere's Avatar
Who all is running an open crank case system. I am blowing oil out the turbo seals on deceleration. My current oil catch can is pulling air out of the crank case all the way through 27 psi but when I get off the accelerator the pressures in the crank case are causing oil to vac out of the crank case and burn as bluish sometimes white smoke, I think. There is oil on my boost controller, blow off valve, and I get a white bluish puff of smoke on decel only. This leads me to believe its a PCV issue. I can see oil in my PCV setup passing the catch can and getting into the turbo on the intake side.
I rebuilt the turbo so I know the seals are perfect. I have searched other sites and found a guy in the same boat after a rebuild. Before I speculate that my turbo is messed up. It never does this below 15 psi, there is no smoke any other time in any of my runs, and my cyl pressures are 200 across all four cylinders.
I have read its OK, no biggie you have to expect some oil on big psi turbos, to its crank case pressures, to the worst of scenarios.
when you cut out all the baffling what do you expect
Got both pvc on back on back of vc and the oil cap tapped to a tee thru a catch can to the turbo intake so ita closed and has constant vaccum source
someone has paid attention
that constant vacuum is sucking oil into the turbo.
I am thinking of getting a zzp oil cap filter to try and see if it fixes it. Then invest or build my own vent catch.
that will create a vacuum leak
change the valve cover up the line size to -10 minimum directly over a crank vent
Old Jul 7, 2013 | 11:47 PM
  #6046
I am pretty sure you and everyone and their mother did as well. The manifold sucks, we have established that. And in my case I established it twice.
Old Jul 7, 2013 | 11:48 PM
  #6047
saab and lnf to different manifolds
Old Jul 7, 2013 | 11:52 PM
  #6048
Killa SS's Avatar
Im on the saab. Its fine. It holds together atleast!
Old Jul 7, 2013 | 11:53 PM
  #6049
Thanks for the info MRB. I paid attention the last time we had all these conversations way back but I didnt follow through. It has now caught up with me and will be next after I fix my manifold issues once again. I am going to come up with a couple of -12 AN over the steel plate on the back of the valve cover.
Old Jul 7, 2013 | 11:54 PM
  #6050
yeah, i am not trash talking it, its a solid piece, can be had cheap and they are easy to modify to fit the LSJ. Its just that the 20g needs all the help it can get.
