Official Turbo LSJ thread!!!
Old Jan 10, 2014 | 09:52 PM
  #7451
armcclure's Avatar
Lsjion (josh billheimer) did on his redline.
Old Jan 10, 2014 | 10:55 PM
  #7452
i944scania's Avatar
Good I'm not the only one
Old Jan 11, 2014 | 12:32 AM
  #7453
BlkWdoSS's Avatar
Originally Posted by i944scania
Can valve float get worse depending on how much air the turbo flows? Example a k20 at 25psi and a 50 trim .63 turbine at 25psi?
I dont know much about valve float but Ive not ever heard of it because of too much flow, but I may be wrong
Anyone used the Maf section from an lsj k&n typhoon intake for charge piping maf housing?
I used a 3"maf tube so that I could get a straight section to the maf but I cut the typhoon intake Maf section off and then used the rest to form my upper piping
Old Jan 11, 2014 | 08:20 AM
  #7454
i944scania's Avatar
Good to know! I was curious if the maf seal was good under boost. How close did you have your maf to the tb?
Old Jan 11, 2014 | 11:37 AM
  #7455
BlkWdoSS's Avatar
I kept MAF in stock position, I try to move as little around as possible, I like keeping things where the car was designed for them to be, its easier to diagnose issues if you can isolate issues then its easier to fix later.
Old Jan 11, 2014 | 12:26 PM
  #7456
i944scania's Avatar
Well I mean on ss sc the Maf if pre boost on the intake and I moved mine to charge piping to run a bov instead of bypass. Its about 15 inches away from throttle body
Old Jan 11, 2014 | 12:57 PM
  #7457
armcclure's Avatar
Meh you can run a bov with draw through just fine as long as you don't run full maf only.
Old Jan 12, 2014 | 01:32 PM
  #7458
bmxracerchamp12's Avatar
zzp 3" exhaust for my ion. the tip is in another box with all my other goodies. should hopefully sound stock ish
Old Jan 12, 2014 | 03:12 PM
  #7459
noorj's Avatar
damn looks real nice. any pics of the clamps they give? my magnaflow can't seem to stay leak free with any clamp I put on the slip fits.
Old Jan 12, 2014 | 04:12 PM
  #7460
i944scania's Avatar
Looks so cleannn
Old Jan 13, 2014 | 09:37 AM
  #7461
going to weld it up. im going to have 2 vbands put in. 1 at the dp and one for the axle back. that way no leaks and its easy to take it all apart
Old Jan 13, 2014 | 10:45 AM
  #7462
armcclure's Avatar
Fired her up for the first time since august last night! A few things to fix but overall it went really well!
First start it went lean once residual cranking fuel was gone and died. Added 25% to maf, fired up and after a few seconds smoothed out and was idling in the low 10's.
4 moth old corn was smokesteaming like crazy lol.
I really was amazed it ran that smooth with so much changed. Bigger maf housing and injectors that no one has ran yet.
Noticed bov was wide open, so I'll play with the springs tonight.
Fuel return line was leaking, so I picked up a new fitting that I'll throw on tonight.
With as many things as are still left to tweak, I was AMAZED how smooth the 1200's idled. Dead on to commanded rpm, and zero idle surge.
Things are looking promising
Just need to fix those bugs, get the bumper, wheels, hood, and trunk on and she'll be ready for her turbo maiden voyage
Old Jan 13, 2014 | 10:53 AM
  #7463
InfraRedline's Avatar
As I said, good to hear! Now I need some injectors.
Old Jan 13, 2014 | 10:55 AM
  #7464
noorj's Avatar
nice man!
how big maf housing? its the draw thru right?
Old Jan 13, 2014 | 11:52 AM
  #7465
armcclure's Avatar
Yes draw through. The maf is 3.375 ID. I'll probably have to go bigger than that sooner or later.
Since we have both maf and ve you CAN run a bov on draw through with a minimal rich spike when it goes off. You just don't want to be engine braking everywhere you go lol.
I was surprised how stable everything was. I'll see if I can get a screenshot of the log here in a little bit.
edit: here's the last quick startup
commanded idle rpm starts at 1200 and drops to 1000. it was just getting there when i realised my return line was leaking all over the floor and had to shut her down.
Old Jan 13, 2014 | 09:41 PM
  #7466
Bass_Waves's Avatar
p1183 popped up when running the car. this is the 2nd time running the car. thats the inlet pressure sensor on the blower right???????? im using the intake manifold provided with the zzp full turbo swap. doesnt that code get tuned out? im on a canned zzp tune for now. just to get the car running.
Old Jan 13, 2014 | 10:28 PM
  #7467
armcclure's Avatar
It should have been deleted, yes.
Old Jan 14, 2014 | 10:25 AM
  #7468
armcclure's Avatar
So... Who wants a set?
Old Jan 14, 2014 | 10:27 AM
  #7469
You already know I do.
Old Jan 14, 2014 | 12:48 PM
  #7470
so do you guys think a cutout would yield any noticeable gains with my exhaust choice? i know the 20g's exhaust side limits a good bit already. the dp is catless too
Old Jan 14, 2014 | 12:54 PM
  #7471
Bluelightning's Avatar
Got Bewst?
Not gonna lie Al your car running reeeeealllly makes me want to start mine and go drive it lol.
Dump tube straight up like a baws haha. Love it. That's gonna be loud.
Old Jan 14, 2014 | 01:10 PM
  #7472
SPDDMN36's Avatar
Uh yeah!
Old Jan 14, 2014 | 01:12 PM
  #7473
SPDDMN36's Avatar
My friend runs his like that on his evo. It is quite loud but my favorite part is shooting flames out of the hood
Old Jan 14, 2014 | 01:19 PM
  #7474
armcclure's Avatar
Lol I was all smiles the whole way home from the garage last night. Most excited I've been in a while!
I still have several days worth of work before it's on the road. Hopefully my box from jp gets here soon and the weather and roads stay clear for this weekend!
Old Jan 14, 2014 | 01:26 PM
  #7475
armcclure's Avatar
I'm looking forward to that as well lol
