Official Turbo LSJ thread!!!
Old Nov 23, 2011 | 09:19 PM
  #1076
05Slowline's Avatar
lmao
Old Nov 24, 2011 | 02:13 AM
  #1077
EXsoccer1921's Avatar
pause at 0:52. badda bing badda boom. hahah came across this while searching for videos taken at the local track.
Import Face Off - Tulsa Raceway Park - 9/18/2011 - YouTube
Old Nov 24, 2011 | 03:46 AM
  #1078
terry11's Avatar
nice
Old Nov 24, 2011 | 05:41 AM
  #1079
BlkWdoSS's Avatar
not too shabby, the rest of the vid is pretty shitty though lol, extremely poor camera angles
l8r,
PD
Old Nov 30, 2011 | 02:17 PM
  #1080
BumbleBee's Avatar
Well, got my car back and it's running fine but i'm seeing a little oil on the coil cover from my breather filter. Should I just use my stock oil cap? I am not running high boost yet, only 12 psi right now. Will it effect the tune if I just switch them out real quick? Just wanna make sure.
Old Nov 30, 2011 | 03:19 PM
  #1081
keep it on there if you like your turbo
Old Nov 30, 2011 | 03:26 PM
  #1082
BumbleBee's Avatar
Roger that.
Old Nov 30, 2011 | 07:08 PM
  #1083
05Slowline's Avatar
lol 12psi and spittin oil? mine has not a spec on 15
Old Nov 30, 2011 | 10:15 PM
  #1084
06SIBLT's Avatar
Mine has some on it 27 psi
Old Nov 30, 2011 | 11:40 PM
  #1085
BLAZIN07SS's Avatar
I'm too JDM for you
24psi and not a single drop in my breather tank
Old Dec 1, 2011 | 05:41 AM
  #1086
BlkWdoSS's Avatar
ive got oil, but i know the issue and Im working on it lol.
l8r,
PD
Old Dec 2, 2011 | 12:50 PM
  #1087
terry11's Avatar
Wait... Cars are supposed to have oil? :/
Old Dec 2, 2011 | 06:32 PM
  #1088
What year saabs can we use their intake manifolds? Im considering going turbo and found a bunch for around 50 bucks. just dont know what years work for the LSJ conversion.
Old Dec 2, 2011 | 06:35 PM
  #1089
05Slowline's Avatar
easier to just get zzp's and a 2.4tb. they drill the map in the back, add a reference port, add brake booster etc etc. instead of rigging it with a spacer and spacers for the map yada yada.
Old Dec 2, 2011 | 06:49 PM
  #1090
yeah it does bolt on directly, but it has to be modified to work on our setups
Old Dec 2, 2011 | 07:03 PM
  #1091
jonathan923's Avatar
i would think is just better to get zzps manifold since its already and aviod any hastles. Am actually thinking about either getting either the saab mani as well from zzp or the ott intake mani. which one do you guys think flows better performance and durability wise compared to my hahn mani?
Old Dec 2, 2011 | 11:57 PM
  #1092
if you don't get a saab type manifold. you're better off with an rd fabs, worx, ttr, hahn manifold as people have said vulcan's aren't great quality and when they have problems it takes a while to be sorted out. personally i would get one from a vendor that you know will fix any problems.
Old Dec 3, 2011 | 01:51 AM
  #1093
mexi_loco's Avatar
i have a used hahn intake mani. From what I can tell, it has suffered a stress crack in one of the welds, but thankfully the guy I bought it from fixed it good. I will, however, say that I am experiencing a hissing noising from it (a ticking....**** i'm sick of all the noises my car makes ). So first chance I get, I believe I'm switching to a saab from zzp.
Old Dec 3, 2011 | 08:16 AM
  #1094
05Slowline's Avatar
how much power zzp make on their car, what intake mani do they use
Old Dec 3, 2011 | 10:45 AM
  #1095
mexi_loco's Avatar
zzp uses their modified saab mani.
Old Dec 3, 2011 | 10:53 AM
  #1096
05Slowline's Avatar
hence the "" lol
Old Dec 3, 2011 | 10:55 AM
  #1097
mexi_loco's Avatar
i see wat u did thur...
Old Dec 3, 2011 | 11:33 AM
  #1098
slvr 04 rl's Avatar
have you bought a boost leak tester yet? modern sells them for pretty cheap. i have a 4inch boost leak tester and a homemade 3 inch boost leak tester. if you want to borrow one, if you dont have one yet? you could come to my work and i can check it out if you want.
Old Dec 3, 2011 | 11:37 AM
  #1099
05Slowline's Avatar
yea if u have a turbo car you should have a blt lol boostpro.net has one also with gauge and valve stem fitting for like 30 bucks too.
got the 3" and bought a 3" to 2.5" reducer and just pull the cp off the compressor and put it on there when i do mine
Old Dec 3, 2011 | 11:57 AM
  #1100
mexi_loco's Avatar
don't have a blt yet, but i will be getting one soon. I just want to swap anyhow to make it look a little more sleeper, lol. As it is, you can't see any of the charge piping, and the only way you can tell it's turbo'd is the intercooler poking out front.
