Official TVS Thread!!!
Old Oct 15, 2012 | 04:18 PM
  #2701
574's Avatar
574
Rev limiter is set at 7200 and I only go to about 7~ and the second part answered my question perfectly thank you. Now I just need to find out what needs to be done to my fuel system to do both. I think you saw me say earlier I'm going for 400whp with the TVS (eventually) I have the pump rewire and will be putting in the DW301. I think I'll need the 1000s and maybe a BRFS?
Old Oct 15, 2012 | 07:14 PM
  #2702
ebristol's Avatar
Originally Posted by carstedt
Wher the hell do u get e98 lol
Add 2 parts water to 98 parts E85. The Ethanol will absorb the water and the ethanol/water will separate from the gasoline. Syfine the Ethanol off the top or drain the gasoline out of the bottom.
Old Oct 15, 2012 | 07:30 PM
  #2703
JSimons47's Avatar
Old Oct 15, 2012 | 08:30 PM
  #2704
Omnigear's Avatar
Originally Posted by Area47
no, i don't remote tune.
you just snap your finger and
Old Oct 15, 2012 | 08:48 PM
  #2705
armcclure's Avatar
Dammit Eric you know someone is going to try that.
Old Oct 15, 2012 | 08:51 PM
  #2706
carstedt's Avatar
I would hope not
Old Oct 15, 2012 | 10:23 PM
  #2707
zrated89's Avatar
oh the s
Old Oct 16, 2012 | 12:05 AM
  #2708
ebristol's Avatar
Old Oct 16, 2012 | 11:16 AM
  #2709
armcclure's Avatar
Although, if you had a functioning still and a lot of time on your hands, that could work.
Old Oct 16, 2012 | 11:37 AM
  #2710
armcclure's Avatar
what about remote assistance/tweaking for a small remuneration....
Old Oct 16, 2012 | 04:36 PM
  #2711
G11's Avatar
G11
If you want a brfps I got one for sale 250 shipped it is the zzp and has the fuel lab regulator on it
Old Oct 16, 2012 | 11:30 PM
  #2712
Bad-A-SS's Avatar
Ok guys I need a little advice. I am hopefully getting ready to get a TVS and join the group lol but I am just curious what is the farthest I can push my 60s safely?
Old Oct 16, 2012 | 11:35 PM
  #2713
100% METH's Avatar
The playing field is limitless my son
The question is... how much methanol are you willing to run?
Old Oct 16, 2012 | 11:43 PM
  #2714
Bad-A-SS's Avatar
Well at this point I have no methanol kit so will just straight 60s get it for awhile?
Old Oct 16, 2012 | 11:45 PM
  #2715
100% METH's Avatar
Yeah if your on dino fuel...
Which ever pulley nets you 18-20 psi will be just about the ceiling of those injectors.
Old Oct 16, 2012 | 11:48 PM
  #2716
Bad-A-SS's Avatar
So basically if I am going to want to stay with my 60s I should just get a meth kit as well?
Old Oct 16, 2012 | 11:50 PM
  #2717
Melon's Avatar
Well how much boost/hp u lookin for? 18-20 psi on a tvs is a world of difference from where ur at now
Old Oct 16, 2012 | 11:53 PM
  #2718
Bad-A-SS's Avatar
I am at least wanting to break the 300hp mark and join the club
Old Oct 16, 2012 | 11:54 PM
  #2719
100% METH's Avatar
That or E-85 & 1000s
Your going to be fighting the efficiency of the blower as you pulley it down.
Stock TVS PULLEY
7-10gph 50/50 or 90/10 (higher the methanol concentration the greater the hp. IAT2 go up and knock suppression is lessened)
and you'll sit at 300whp without breaking a sweat.
Old Oct 16, 2012 | 11:57 PM
  #2720
Bad-A-SS's Avatar
Stock TVS PULLEY
7-10gph 90/10 mixture
So what is the difference between the progressive kit and the base meth kits?And I for tuning I have talked to James about meeting him at the Import Alliance meet @ Nashville
  #2721
Melon's Avatar
Steve should I run a mixture like that or go more 50/50
Old Oct 17, 2012 | 12:07 AM
  #2722
100% METH's Avatar
Progressive has a two step engagement
Engages the pump at a lesser PSI (The pump itself also sprays with less intensity)
As rpms increases and PSI rises... the 2nd stage kicks in at a given PSI with usually the pump spraying at near pull power.
This works well on centrifugal setups due to the way they build PSI as they rev.
(There are also MAF based and RPM based kits. But most commonly used is your simple reliable boost switch)
The answer you're looking for is buy a stage 1 kit with a boost switch.
No you'll need the 50/50
That blower runs hot
Old Oct 17, 2012 | 12:12 AM
  #2723
Bad-A-SS's Avatar
Ok so Steve could I use a 2.9in pulley on the TVS and just a base meth kit like OTTP sales?
Old Oct 17, 2012 | 12:24 AM
  #2724
Bluelightning's Avatar
Got Bewst?
I run a Devilsown stage 1 (base) kit with my set up. Works great.
  #2725
100% METH's Avatar
yes
That will put you at 19-21 PSI depending on exhaust/elevation
