Official TVS Thread!!!
Old Oct 17, 2012 | 11:11 AM
  #2751
JSimons47's Avatar
Yes
Old Oct 17, 2012 | 11:14 AM
  #2752
Bad-A-SS's Avatar
Originally Posted by Chevycobaltss3
Running the 80s will net you lower idcs and this will help with the lifespan of the injectors and better atomization and more. It's safer to run the 80s yes but the capabilities on the 60s are fine with the 2.9
But then again 80s will be there if I ever wanna pulley down again or even run E85 correct?
Old Oct 17, 2012 | 11:15 AM
  #2753
JSimons47's Avatar
To a certain extent..
Old Oct 17, 2012 | 11:21 AM
  #2754
Bad-A-SS's Avatar
What do you mean to a certain extent?
  #2755
Vander Nars's Avatar
yes
Old Oct 17, 2012 | 11:28 AM
  #2756
JSimons47's Avatar
Depends how low you wanna go with pulley size
  #2757
Melon's Avatar
just go all out and get the idc 1000s. lol. i'm only running 60s and i'll have a mp90 with meth. not runnin e85 and don't have any plans to any time soon tho as it's not readily available. so it all kinda depends on wut u want. if ur gonna go to e85 i would just do the 80s now and get it out of the way
Old Oct 17, 2012 | 11:45 AM
  #2758
armcclure's Avatar
The id1000's are worth every penny.
Old Oct 17, 2012 | 12:42 PM
  #2759
Chevycobaltss3's Avatar
Id1000s are expensive but worth it. But if you don't plan on doing a 2.5/2.6 get 80s and run meth.
Old Oct 17, 2012 | 12:50 PM
  #2760
InfraRedline's Avatar
If you plan on staying on 91 or 91 and meth do not get the 1000's. If you plan on going E85 and staying at a 2.9 pulley, again not really a need for the 1000's. If you go E85 and a smaller than 2.9" pulley or want to rev to 7500+ rpms on the 2.9 you will want either the 80's and a BRFPS or RSFS or to go to the 1000's.
Old Oct 17, 2012 | 12:52 PM
  #2761
carstedt's Avatar
1000s ftw!
Old Oct 17, 2012 | 12:59 PM
  #2762
Bad-A-SS's Avatar
Well now I just need out where to get a TVS from since OTTP is on backorder til December
Old Oct 17, 2012 | 01:48 PM
  #2763
Bluelightning's Avatar
Got Bewst?
Just keep on the lookout for one on here and save some cash.
Old Oct 17, 2012 | 01:55 PM
  #2764
Bad-A-SS's Avatar
I will do and I have posted up a Wanted thread in the parts Fourm
Old Oct 17, 2012 | 01:58 PM
  #2765
carstedt's Avatar
They surface once in awhile butba wanted thread works pretty good to
Old Oct 17, 2012 | 02:44 PM
  #2766
100% METH's Avatar
This or purchase a set of cams, NBS, valve springs and ATI dampener and rock the hell out of the M62 like ZZP did on their stroker.
Cams will set you back $500 after blanks and comp cam custom grind or $650 for ZZPs
NBS - $100-250
valve springs & retainers - $300ish
ATI dampener - $400
Front cover grinding - $ 150 w/o core (zzp)
If you can do the work yourself... this will cost as much as a TVS.
Old Oct 17, 2012 | 02:54 PM
  #2767
Bad-A-SS's Avatar
NBS - $100-250
ATI dampener - $400
Yeah I guess I could go that route and try to p&p the m62, tb, then maybe send the head off. And see the true potential of the car. Only problem is the cobalt is my DD so down time has to be a minimal.
Old Oct 17, 2012 | 02:56 PM
  #2768
armcclure's Avatar
NBS - $100-250
ATI dampener - $400
Stop telling ppl to do my build lol
Other than I will have built bottom end and progressive spray.
Old Oct 17, 2012 | 03:15 PM
  #2769
Got Bewst?
Qustion, whats safe to spin the motor to with neutral balance shafts and valve springs on stock rods?
Old Oct 17, 2012 | 03:17 PM
  #2770
100% METH's Avatar
NBS can be spun 8000+
GM has spun the stock rods to 8500 with out issue
valve springs... we have a variety available (ZZP 82 lb springs, Fererra, Bates, and 78lb supertech
Old Oct 17, 2012 | 03:21 PM
  #2771
Got Bewst?
I will probably go with the supertech's. So i'll have no problem spinning it to 8k on stock rods?
Old Oct 17, 2012 | 03:22 PM
  #2772
JSimons47's Avatar
no
Old Oct 17, 2012 | 03:23 PM
  #2773
100% METH's Avatar
Originally Posted by bluelightning
i will probably go with the supertech's. So i'll have no problem spinning it to 8k on stock rods?
Originally Posted by 100% meth
nbs can be spun 8000+
gm has spun the stock rods to 8500 with out issue
valve springs... We have a variety available (zzp 82 lb springs, fererra, bates, and 78lb supertech)
-_-
Old Oct 17, 2012 | 03:28 PM
  #2774
Got Bewst?
Calm down haha. Just wanted to make sure the stock valves and such can take it. This motor build is all kinda new to me. Never built up a 4 stroke motor before. Only 2 stroke (my sled).
Old Oct 17, 2012 | 03:30 PM
  #2775
carstedt's Avatar
U start up a build list yet?
