Official TVS Thread!!!
Old Oct 17, 2012 | 12:33 AM
  #2726
Bad-A-SS's Avatar
Well then what kind of blend would I need to run? I am running a full 3in exhaust and elevation is maybe 1000 ft lol I am pushing 15psi currently on a 2.8in pulley.
Old Oct 17, 2012 | 12:37 AM
  #2727
Bluelightning's Avatar
Got Bewst?
Just stick with 50/50
Old Oct 17, 2012 | 12:45 AM
  #2728
Bad-A-SS's Avatar
Ok so 60s, 50/50 meth, 2.9in pulley and I should easily break the 300hp
Old Oct 17, 2012 | 12:47 AM
  #2729
Got Bewst?
Providing your tune is in check.
Old Oct 17, 2012 | 12:50 AM
  #2730
Bad-A-SS's Avatar
Well I have heard lots of great things about James
Old Oct 17, 2012 | 01:27 AM
  #2731
carstedt's Avatar
oh jesus now its goona start again
Old Oct 17, 2012 | 01:29 AM
  #2732
Melon's Avatar
Lol don't jinx it. Thanx Steve I'll stay 50/50. Anything else I could throw at that sc that will make it run colder?
Old Oct 17, 2012 | 06:39 AM
  #2733
armcclure's Avatar
my lips are sealed...
Old Oct 17, 2012 | 08:19 AM
  #2734
Bad-A-SS's Avatar
Not as long as jsigmon or whoever that was that was jumping down james throat
Old Oct 17, 2012 | 08:24 AM
  #2735
armcclure's Avatar
Get a killer chiller and run it off of a CryO2 bottle.
Old Oct 17, 2012 | 08:49 AM
  #2736
JSimons47's Avatar
I'll stay out of this one....
Old Oct 17, 2012 | 09:04 AM
  #2737
Bad-A-SS's Avatar
Great less opinions about tuners n more facts thanks
Old Oct 17, 2012 | 09:47 AM
  #2738
JSimons47's Avatar
Oh I got facts ^.^ but I'll leave them alone.
But for serious, throw a 50/50 mix in and let It rip. easily over 300
Old Oct 17, 2012 | 10:32 AM
  #2739
Bad-A-SS's Avatar
Ok so I am putting together my whole TVS and meth kit. I am wondering since the base kit OTTP sales comes with only a 3-5gph nozzle if I am better off just bumping up to bigger injectors or shall I just get a higher flowing nozzle?
Old Oct 17, 2012 | 10:37 AM
  #2740
Chevycobaltss3's Avatar
Assumptions and childish accusations? Great facts..
  #2741
Omnigear's Avatar
pifff 90/10 or bust ^_^
Old Oct 17, 2012 | 10:38 AM
  #2742
carstedt's Avatar
5-7 gph is all i used on when i was on 92, 100% meth is great when working with bigger meth nozzles i suggest you pm him
Old Oct 17, 2012 | 10:40 AM
  #2743
Get a 10gph and start of with this..... You can go wit a 12/14gph but I dislike dd cars running meth as a fuel source due to the abundance of failures the meth kits can get.
Working with larger meth nozzles isn't hard, it just requires taking quite abit of fuel out to compensate the meth.
And etc.
Last edited by Chevycobaltss3; Oct 17, 2012 at 10:40 AM. Reason: Automerged Doublepost
Old Oct 17, 2012 | 10:44 AM
  #2744
Bad-A-SS's Avatar
Ok so would it be wrong of me to say grab some 80s and just use the 5gph nozzle that comes in the kit?
Old Oct 17, 2012 | 10:48 AM
  #2745
It all depends on your wants! If you want more timing and to be a lol leaner you'll needs more meth. If you want to be more reliable less timing and richer. Reliable being your not depending so much on meth.
Old Oct 17, 2012 | 10:55 AM
  #2746
Bad-A-SS's Avatar
Ok how about I put it this way lol, will I make MORE RELIABLE power with the 80s rather than the 60s as I am wanting to pulley down on the TVS to a 2.9?
Old Oct 17, 2012 | 11:03 AM
  #2747
Vander Nars's Avatar
I could be wrong but I swear i seen it quoted that u can run tvs on a 2.9 with just pump 93 and 80s. If i was u id get the 80s atleast.
Old Oct 17, 2012 | 11:08 AM
  #2748
You can run 60s and be fine on the 2.9 .. Methanol helps as well
Old Oct 17, 2012 | 11:09 AM
  #2749
Bad-A-SS's Avatar
Ok then if I run 80s the meth would be like a safety cushion or net to help the car run cooler temps and thus able to advance timing more? Am I catching on now?
Old Oct 17, 2012 | 11:11 AM
  #2750
Running the 80s will net you lower idcs and this will help with the lifespan of the injectors and better atomization and more. It's safer to run the 80s yes but the capabilities on the 60s are fine with the 2.9
