Official TVS Thread!!!
Old Jun 15, 2013 | 09:52 AM
  #6076
mrbelvedere's Avatar
Originally Posted by wRcKLes
ok so I installed my TVS 2.8 and 80s today and when I hit the dyno everything was great up until I get some mysterious Knock
now the plugs where changed a week before I shot down to the shop and it was holding full boost the entire time on the dyno
further more my tuner turned down the sensitivity on the knock sensor to practically nothing and in lower timing it was still around
so question is
Faulty knock sensor or something more serious?
the knock sensor should not need to be turned down the problem should be found and fixed
Ive never had an issue with this place and have been going to him for a while now and its not his first tvs car he's tuned.
its the same man who tuned 07metalliacSC
well he should have known that when he turned down the knock sensor and the problem was still there that you had a problem that needed fixed
Old Jun 15, 2013 | 10:06 AM
  #6077
wRcKLes's Avatar
It was only turned down temporarily to trouble shoot the issue my car wasn't left that way
Old Jun 15, 2013 | 11:47 AM
  #6078
then you should have posted that before now
its either mechanical or tune related
Old Jun 15, 2013 | 02:44 PM
  #6079
wRcKLes's Avatar
Well that was the issue at hand from the get go "faulty knock sensor or something more serious" but thanks for your input I trust the tunes that come out of smg and just replaced the knock sensor headed back to smg this friday
Old Jun 15, 2013 | 04:46 PM
  #6080
Hope you find out what it is, hopefully it was that sensor so you can finish out the tune and see what she makes!
I wish I could build my head that's sitting in the closet, and the bottom end of the motor and shoot for 400 crank, but I don't know if the car will ever see that, between wedding, honeymoon, and house happening from now till spring.
we'll see tho
Old Jun 15, 2013 | 05:20 PM
  #6081
RooTBeeR's Avatar
lame excuse of a tvs bump
Old Jun 16, 2013 | 12:00 PM
  #6082
nhanson's Avatar
What pulley was that?
Old Jun 16, 2013 | 01:22 PM
  #6083
RooTBeeR's Avatar
80mm(3.15")
also a K&N Filter in a full stock airbox, which is why its hard to hear whine.
Old Jun 16, 2013 | 02:06 PM
  #6084
Bluelightning's Avatar
Got Bewst?
Ever since Ive bolted my TVS on I've had belt squealing issues. It squeals like a dying pig till its warm then stops. Anyone else have this issue? Things I've done:
- Flipped over my GMS2 shorter belt to run on the other side
- Replaced my belt (shorter one)
- Ran the stock belt with an oversized tensioner
- Currently running a GMS2 belt with oversized tensioner
None seem to cure the issue
Old Jun 16, 2013 | 02:17 PM
  #6085
RooTBeeR's Avatar
have you tried to look and see which pulley is causing the issue?
Old Jun 16, 2013 | 02:20 PM
  #6086
Verbatim's Avatar
Have you checked the other pullies or the tensioner itself?
Also; pull the belt off and start it to eliminate the timing set/engine itself.
Damn rootbeer; I have the 80mm and I thought 15psi was a lot...
Can't wait to try the 2.6"
Old Jun 16, 2013 | 02:41 PM
  #6087
RooTBeeR's Avatar
ottp long tube header, stock muffler, reving to 7250-7500
...also ambient was around 15-30*F iirc lol
normal weather(70*F) was more like 20psi
Old Jun 16, 2013 | 02:47 PM
  #6088
I don't know how many psi im running, im on a 2.8, thing pegs at 20 ( stock ss/sc gauge ) then goes to zero.
I might get an aem boost gauge when I have an extra 3-400 laying around
Old Jun 16, 2013 | 02:49 PM
  #6089
Got Bewst?
I know for a fact it's the belt. I can spray lube on the belt while its running and it will stop for a short time. It did it with the stock and oversized tensioner. It's definitely squealing off one of the top pullies. Just don't get why after I put my TVS on this has been an issue. I even swapped blower pullies with no difference.
Old Jun 16, 2013 | 03:44 PM
  #6090
armcclure's Avatar
Crooked alternator? Crooked idler pulley bracket?
Old Jun 16, 2013 | 04:23 PM
  #6091
Got Bewst?
I guess there's a possibility of it. It's just odd I started this battle the day my TVS went on. I thought I had it beat last year but it came back when I put my motor back in. After 10 min of driving it goes away. Very annoying haha.
Old Jun 16, 2013 | 04:58 PM
  #6092
JapEatr's Avatar
South Central *********
Is your tvs pulley backwards? They arent symetrical
Old Jun 16, 2013 | 04:59 PM
  #6093
Melon's Avatar
Autometer cobalt series. Full sweep -30-30 from thm for like 80. Mechanical gauge. Y spend 3-400. Just gonna tell u the same ****
Old Jun 16, 2013 | 05:40 PM
  #6094
06cobalt racer's Avatar
the stock 30 psi TC gauge is only $59 brand new
INDICATOR. Instrument Cluster Warning. TRIM/FRONT. Fits: Chevrolet: Cobalt (2008-2010); Pontiac: Pursuit (2008-2010). # 25800715
Old Jun 16, 2013 | 06:23 PM
  #6095
RooTBeeR's Avatar
what about the cobalt mechanical 30-30?
if i did it again, i wouldnt get the cobalt series...bright ass blue leds are fking annoying
Old Jun 16, 2013 | 06:36 PM
  #6096
Melon's Avatar
I like the blue and that's the gauge I have to put in my car as soon as my triple is done with carbon. Lol when I saw ur video I said "i have that gauge" lol
Originally Posted by 06cobalt racer
Fits 08-10. Sc's were 05-07
Old Jun 16, 2013 | 06:47 PM
  #6097
RooTBeeR's Avatar
still somewhat on topic lol
Old Jun 17, 2013 | 03:09 AM
  #6098
it says that because that is the gauge that is in the TC's. i am almost positive that it will be a plug and play replacement for SC's
Old Jun 17, 2013 | 03:37 AM
  #6099
ok i think i am wrong. i was reading more on it. i guess it reads 5 psi off if you swap them. so nevermind.
Old Jun 17, 2013 | 08:20 AM
  #6100
574's Avatar
574
Or you could just get a mechanical boost gauge from glowshift for about $60
