Official TVS Thread!!!
Old Aug 19, 2013 | 11:47 AM
  #6601
InfraRedline's Avatar
Almost as good as Jordan's
And take the damn bypass off and wire that bitch shut for a pull. It'll run like poo in vac FYI.
If I were to ever have such a motor there would be a turbo hanging off the back of it
Ill rig up a bracket to hold the arm closed and let her nuck if she buck lol
Old Aug 19, 2013 | 12:20 PM
  #6602
armcclure's Avatar
Like you would ever build something like that....
Old Aug 19, 2013 | 12:23 PM
  #6603
Yeah, I don't think I'd ever put together a motor like that. I wouldn't turn it down if I got my hands on one though...
Old Aug 19, 2013 | 12:28 PM
  #6604
Tennpenn83's Avatar
Keyword... almost.
Come on, Taylor... build yourself one already.
Old Aug 19, 2013 | 12:46 PM
  #6605
Im going to play stock block lotto on le turbo next year! But it wouldn't hurt to have a motor built just in case she decides to let go.
Old Aug 19, 2013 | 01:11 PM
  #6606
Bluelightning's Avatar
Got Bewst?
If only you could find one. That would be sweet...
Old Aug 19, 2013 | 02:28 PM
  #6607
Area47's Avatar
Rent me! per hour
Originally Posted by lsjion
The last time I saw a TVS bleed off boost like that, it was due to a faulty bypass solenoid. Of course it's frowned upon, but the "boost bypass mod" cured the issue
did it on my car. did it on johns car right in front of him on the dyno.
Old Aug 19, 2013 | 04:55 PM
  #6608
Powell Race Parts's Avatar
still runs . Now has a brand new harrop with no bypass. works for me. still on an area47 tune and running 20 psi boost levels with a GMR head etc( rear muffler is restrictive)
Old Aug 19, 2013 | 04:56 PM
  #6609
JapEatr's Avatar
South Central *********
those fittings come in yet?
Old Aug 19, 2013 | 05:00 PM
  #6610
No PLUS the 180 is only available in clown colors so get out the paint can. so you gonna have to wait . I cant believe how difficult it is to get russell fittings sometimes, but I buy on price the margins are so skinny and not even Area's shop has some of the fittings I use...email works but patience please. I am working as fast as I can and looking at alternative fittings.
Old Aug 19, 2013 | 05:04 PM
  #6611
JapEatr's Avatar
can i get the 180 in red?
ill send you an email... im considering the PCV too but no clown colors for that!
Old Aug 20, 2013 | 06:49 AM
  #6612
armcclure's Avatar
Anyone need an ATI?
Old Aug 20, 2013 | 07:13 AM
  #6613
Anyone need an ATI?
maybe lol
Old Aug 20, 2013 | 02:22 PM
  #6614
Area47's Avatar
Rent me! per hour
acid base wheel cleaner will remove the anodized finish in the clown fittings.
Old Aug 20, 2013 | 02:56 PM
  #6615
JapEatr's Avatar
hmmmmm
Old Aug 21, 2013 | 09:26 AM
  #6616
advise's Avatar
Got a LSD diff on my work bench if anyone is in need
I'll post it up in the classifieds later
Old Aug 21, 2013 | 09:32 AM
  #6617
armcclure's Avatar
I got one sitting inside of a blown trans at mrB's house. Yours is much more usable
Old Aug 21, 2013 | 09:53 AM
  #6618
Tjolley's Avatar
I have a modified one sitting on my bench at home too lol.
Old Aug 21, 2013 | 09:59 AM
  #6619
advise's Avatar
Also will include a 4.05 gear set
Old Aug 21, 2013 | 10:39 AM
  #6620
574's Avatar
574
Speaking of gearing, the lsj "bucks" in first is that due to the gear ratio? If you switch to an LNF trans would that go away?
Old Aug 21, 2013 | 11:06 AM
  #6621
advise's Avatar
That's just gear lash and I just switched to the lnf fluid and its minimal
Old Aug 21, 2013 | 11:09 AM
  #6622
JapEatr's Avatar
LNF Fluid is different from the saturn manual trans lubricant?
Old Aug 21, 2013 | 11:13 AM
  #6623
advise's Avatar
They changed it for the nls is the LNF, over all Its a better fluid
Smoother shifts, quieter trans ect
Old Aug 21, 2013 | 11:16 AM
  #6624
JapEatr's Avatar
Pn?
Old Aug 21, 2013 | 11:25 AM
  #6625
advise's Avatar
Manual Transmission Fluid SAE 75W-85 GL/4 88862472
