ported blower worth it?
Old Mar 10, 2010 | 06:22 PM
BlackMagic's Avatar
Im thinking of porting my blower and i was wondering if its worth it? Noticeable gains?
Old Mar 10, 2010 | 06:26 PM
NinjaHampster's Avatar
this is arguable, but i have it done and i noticed a quicker boost and a higher pitched whine.
06SIBLT's Avatar
Porting both the blower and intake manifold you will see respectable gains, also upgrading to an ls4 tb would also help. I would (because people, derek, have told me abou this) port your head as well because yeah porting the supercharger and your intake manifold will help, but then the air is just going to get stopped or slowed down when it enters your head. Ya know? You are on a eaton m62 right?
Old Mar 10, 2010 | 06:29 PM
BlackMagic's Avatar
yup i'm running the m62
Old Mar 10, 2010 | 07:49 PM
DC4LIFE's Avatar
I have mine ported and i noticed a quicker boost and it runs more efficient. Do It.
Old Mar 10, 2010 | 08:27 PM
Nighthawk243's Avatar
Just have it ported correctly. Don't get rid of the triangle.
Old Mar 10, 2010 | 08:37 PM
YzRider452's Avatar
Lets see some pics of a Correctly ported blower. Ive heard nothin good about ported blowers, but Somethign always keep bringing the idea into my head.
Old Mar 10, 2010 | 08:46 PM
mrbelvedere's Avatar
im running the ls4 tb it ******* rocks period
Old Mar 10, 2010 | 08:53 PM
qwikredline's Avatar
Steigmeir do an excellent job I have paid for and looked at their work. Very nice, and if you need a rebuild on the snout well worth the money, but unless I needed that front end rebuild, I personally would not do it tho'....
Old Mar 10, 2010 | 08:59 PM
Zach06CobaltSC's Avatar
Here is my 2 cents on it. First off I always went by the saying if it's not broke don't fix it. The eaton m62 is a VERY efficient blower stock, let alone when we pulley it down so low. With that being said I am not a fan of porting the inlet any larger then stock, however smoothing out the burs/roughness on the inside of that and the intake manifold is a good idea. For anyone who has stuck there hand inside of the m62/intake manifold you know how rough it can be, smoothing this out im sure would "slightly" help iat2's and air flow. Considering most people don't have the tools that eaton does at there finger tips for flow testing things I personally don't think its a good idea to have the average run of the mill person port the inlet. Porting something to much can cause you to lose horsepower/torque and simply just change the way the air is flowing which can be good/bad but without any testing I wouldn't do it.
If you are going to go this route obviously smooth things out but make sure you do a before and after dyno. If you are looking for big gains, you won't find them in the supercharger. Instead look towards the head, mainly the exhaust side of it. I recommend finding someone decent with a dremel that knows what there doing to smooth out the supercharger, intake manifold and port your head. Then you will pick up some real power.
Old Mar 10, 2010 | 09:21 PM
compliments of Euthanasia
Old Mar 10, 2010 | 09:31 PM
G11's Avatar
G11
^^^...shiny!!! :d
Old Mar 10, 2010 | 09:33 PM
Cefaln452's Avatar
save your money and port the head.... wayyyyyyy bigger gains
Old Mar 11, 2010 | 02:57 AM
YzRider452's Avatar
Agreed.
Old Mar 11, 2010 | 07:23 PM
SS Pyro IV's Avatar
do the charger, intake manifold and the head at the same time!!!! woot for gains
Oct 13, 2015 09:32 PM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
goaliemo
Sep 28, 2015 01:37 PM
