Porting your Supercharger
Old Jan 28, 2006 | 09:55 PM
1stbluSS's Avatar
Yikes shaky vendor territory... proceed with caution
Old Jan 28, 2006 | 09:57 PM
Sinisterredlines's Avatar
My ported head should be done soon so things are coming together nicely. (as Mr Burns) excellent.
Old Jan 28, 2006 | 10:02 PM
Tofu's Avatar
Sinister, are you porting your stock head? Or did you manage to get a donor? I've been trying to find an LSJ head forever because one of my good friend's does excellent port work...I just can't afford to not have my car down to get it done.
Old Jan 28, 2006 | 10:09 PM
I bought a spare engine from a rl forum member it came with the sc and evrything else. Be carefull I tried to go with extrudahone and the exhaust port is VERY close to a oil passage so then I went to patriot who does cnc porting for the pro cars. BTW SMS is hookin it up, Springs, titanium retainers, and I have a local cam grinder workin on the cams.
Old Jan 28, 2006 | 10:11 PM
It took me almost six months to find a doner. The source I have may have some more heads coming, we are thinking about setting up a head program (exchange) BTW I used to work in a machine shop in the head department...
Old Jan 28, 2006 | 11:48 PM
mrbelvedere's Avatar
cool **** sinister
mrb
Old Jan 29, 2006 | 02:37 AM
Tofu's Avatar
Wow interesting, from what I've seen the exhaust ports seem to be pretty restrictive, does the oil passage limit the amount of porting to a small portion? Or is it even safe to do some work on the port at all? Patriot does some good work, I've got a few buddies w/ heads from them on their ls1's and mustangs. Are the springs and retainers available for anyone? Or are they custom making them for you? I'm to go the same route, build up the bottom end and valvetrain before anything else. I contacted diamond about forged pistons a few days ago, but have not heard a response yet.
Old Jan 29, 2006 | 08:50 AM
trilo68's Avatar
I imagine that since ZZP is getting into cobalts that they will start porting the M62's. They already do work with the M90's so they can probably transfer most of that R&D over.
Old Jan 29, 2006 | 11:35 AM
theBLUEone's Avatar
Sounds promising if your running a smaller pulley...
Old Jan 29, 2006 | 12:21 PM
yes all the stuff I am doing is availabe to anyone. I am working with SMS for the discount thats all. BTW nobody will have rods available they can be made but they want a huge order so what I did is buy the eagle 2.2 rods which are a different length and had cp pistons compensate the wrist pin hiegth. Since the crank is the same journal size. The valve springs that I am using are ferrea's in the high seat pressure with theyre seat and titanium retainers .
brandon04
Oct 21, 2015 07:04 AM
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
