Possible Intercooler Pump Upgrade (Pump Information)
Old Aug 26, 2014 | 04:33 PM
blueLNFftw's Avatar
Originally Posted by mrbelvedere
the impeller is connected to the main shaft magnetically could have debris around the impeller
I will check that out. Regardless I am going to buy the new pump first so that if that isn't the issue I have a new one to install and don't have to do this twice.
Old Aug 26, 2014 | 04:34 PM
blueLNFftw's Avatar
Originally Posted by REDi DEViSTATOR
I see. Well if I am informed correctly, the single pass is more efficient than the dual pass and with a upgraded intercooler and a working stock pump, should cool better than a a dual pass and a higher flowing pump. If you upgrade the pump, you will create more of an electical draw.. That's a power robber as well. I think you would be better off with a stock pump and single pass and upgraded intercooler.
With your theory then a single pass, intercooler upgrade and higher gpm pump would be even more efficient.
Old Aug 26, 2014 | 04:39 PM
mrbelvedere's Avatar
I was talking to a guy that ran a m62 up to 20,000 rpms on a load generator the blower did not get stupid hot you could keep your hand on it while it was running
that's how the last one I had apart was
Old Aug 26, 2014 | 04:50 PM
This is exactly what I meant!
Thank you.
I will buy the Mercedes Benz pump as a replacement this time. Would be great to see a fall in time for recovery from it, but longevity would be even better. My main concern was not purchasing a downgrade thinking it was an upgrade like so many others have done.
To find out if it will make a difference in recovery time you need to know air flow to and away from the heat exchanger, as well as the surface area of the heat exchanger. The overall heat removal process is more complected than simply the pump flow. If the pump flow isnt the limiting step then it doesnt matter.
Old Aug 26, 2014 | 07:21 PM
blueLNFftw's Avatar
Okay, I understand that. All I can really do is find out surface area of my heat exchangers though. So all and all I will only find out if my temps are better based on logs and personal feelings basically? Since I can't measure air flow....
Old Aug 26, 2014 | 07:59 PM
Just a side thought, sure the coolant wont heat up as fast being in the laminovas not as long but it also might not cool as well being in the heat exchanger less time too
Old Aug 26, 2014 | 08:08 PM
yup and that is where capacity comes in or other things
Old Aug 26, 2014 | 08:16 PM
blueLNFftw's Avatar
All of these are great points. I wish I could do more technical testing, but I can't. I plan to buy the Mercedes pump and pig tail and popping it in. It seems it will flow 1gpm more, but I've also been reading it's a more stout pump. If anything, hopefully it lasts longer and doesn't end up cooling less. I have HPT and I can do log comparisons, but sadly it will all be personal opinions and no real scientific proof.
(The Benz pump is actually cheaper)
Old Aug 26, 2014 | 08:17 PM
REDi DEViSTATOR's Avatar
That's really irrelevant. . Compressed air gets hot.. but, that pretty neat! If you take a laser thermometer and stick it up your nose you can generate 120+° temps. Oh, and you can put your hand on my nose while I do it ;-)
Old Aug 26, 2014 | 08:25 PM
Mr.b is correct too. You will need volume. The griffin will definitely be the one to go with, using the Benz pump.
Old Aug 26, 2014 | 08:46 PM
  #36
blueLNFftw's Avatar
I have an OEM heat exchanger and cx fmhe. Switching to the ZZP or griffin would be great, but I'm also planning on selling this car for a LNF so I won't be buying a big ticket item like that.
Old Aug 26, 2014 | 09:24 PM
  #37
this thread is about lowering iat2 so actually its not irrelevant if you think why
Old Aug 27, 2014 | 07:44 AM
  #38
blueLNFftw's Avatar
Apparently this 010 Bosch upgrade is also used in the supercharged Dodge applications. Hopefully the Dodge dealership can get me the pig tail for the pump from a SRT6.
Old Aug 27, 2014 | 01:39 PM
  #39
Where are you getting the pigtail from? also be sure to post whether the inlet and outlet is bigger because it looks to be the case. as well as if it fits where our stock unit goes. i'm in for this because i need a new pump and wouild like it to be my last. i'm on a zzp stealth and ottp fmhe as well.
Old Aug 27, 2014 | 01:48 PM
  #40
Spawne32's Avatar
THe charts you provided definately seem to support the theory that the bosch pump will be an effective upgrade, will it actually make a difference is the question. In combination with a larger heat exchanger, dual pass and option b I think yes there would be a noticeable difference as the stock pump was designed to work exclusively with the stock heat exchanger.
Old Aug 27, 2014 | 02:11 PM
  #41
blueLNFftw's Avatar
I posted the pump blueprints in the first post.
The new pump has inlets and outlets about 1mm larger and they should fit. The Benz guys use 3/4" hose like we do.
As for the pig tail, I am scouring for it as both Benz and Dodge only sell it as part of the car's engine harness.
Old Aug 27, 2014 | 02:44 PM
  #42
Oh, gotcha!
Old Aug 27, 2014 | 03:45 PM
  #43
Check out some online Euro parts suppliers, i'm sure they might have one.
Old Aug 27, 2014 | 05:01 PM
  #44
I doubt gm had bosch design a pump specifically for our H.E. system they more then likely said this off the shelf part is close enough
Old Aug 27, 2014 | 05:30 PM
  #45
Spawne32's Avatar
I never said GM had bosch design a pump for them, merely that the intercooling system is designed with the specs of that particular pump in mind. When you start changing the system it might not be as efficient as it is when it is stock, therefore there might be some extra to be gained by increasing the size of the pump when you increase the size and density of the heat exchanger.
Old Aug 27, 2014 | 05:58 PM
  #46
close enough
Old Aug 27, 2014 | 06:50 PM
  #47
I would bet this also. They probably calc'd the flow needed and restrictions for a stock set up, maybe their Stage 1 (I honestly do not know the lsj GM Stage release/development time line) and this pump flowed corrected at the given back pressure.
Old Aug 27, 2014 | 10:50 PM
  #48
SSfamilywagon's Avatar
My best friend has been using the Johnson CM30 pump in his cobalt for 4-5 years, probably longer. It's been so long honestly can't remember when it was installed. Been a great pump. Not a single issue and temps have been great on his 2.5 and 2.4 pullied M62. All he has is dual pass, opt b and spacers.
Old Aug 28, 2014 | 03:44 AM
  #49
Twoozofjuice's Avatar
I wanna know how a 2.4 pulley m62 survived that many years ^
Old Aug 28, 2014 | 08:05 AM
  #50
blueLNFftw's Avatar
Not driven much?
Problem with the CM30, while it is a better built pump, is that its head pressure is less than OEM even though it does flow more GPM unrestricted. Mercedes Benz guys were using that as the go to option for the 002 replacement until more date came out about how it flowed restricted. Then the 010 was released and it is the go to pump for them all.
Last edited by blueLNFftw; Aug 28, 2014 at 08:06 AM. Reason: Automerged Doublepost
