Rebel TwinScrew testing new VIDS
Old Jan 4, 2008 | 01:00 AM
  #51
Coblt ss super's Avatar
subscribed
oo and btw, what would be the price without the tune, and injectors? i got them already
Last edited by Coblt ss super; Jan 4, 2008 at 01:00 AM. Reason: Automerged Doublepost
Old Jan 4, 2008 | 01:05 AM
  #52
MrSlickSter06SS's Avatar
Originally Posted by 2K5SS/SC?
You and me both! Solid numbers without issues FTW!
No internal work should be required, but you will definitely need to be retuned because you'll need the 60lb injectors.
Ok awesome, then im down, all I will have to do then, well my exhaust but ima try and do that first. Thanks 2k5. O one more thing if we go 42's or 60's do we have to get a better fuel pump for our cars, so we don't burn a piston?
Old Jan 4, 2008 | 01:13 AM
  #53
2K5SS/SC?'s Avatar
No fuel pump is needed to run the 60# injectors. 42#injectors will not support the twinscrews airflow, so 60's will be a must. Your stock pump will handle it just fine.
Old Jan 4, 2008 | 01:15 AM
  #54
what size pulley comes on this thing? doesnt it exceed its RPM's or something like that, isnt that what happened the first time?
Old Jan 4, 2008 | 01:18 AM
  #55
2K5SS/SC?'s Avatar
A 2.8" pulley is what came with my twinscrew. The original issue was that the snout seal failed causing the blower to blow out all the oil. The snout was redesigned and a new better seal was placed in it, and apparently it's working great thus far.
Old Jan 4, 2008 | 01:21 AM
  #56
fsickness's Avatar
Hmm may be looking into it...it has had my attention eversince I herd of the build...
Old Jan 4, 2008 | 01:23 AM
  #57
this is awsome, so what exactly comes in the kit? well yours when you first got it?
Old Jan 4, 2008 | 01:44 AM
  #58
2K5SS/SC?'s Avatar
I already had the 60# injectors and HPTuners, so I didn't need either of those. It came with the following:
- Lysholm 1200AX blower w/ snout and blower intake already bolted up
- 2.8" Pulley and hub already mounted
- Special dual pass endplate w/fittings for the the twinscrew
- Aluminum bypass valve
- Adapter plate for the intake manifold to blower
- All hardware, clamps, etc required
- Instructions PDF file
Old Jan 4, 2008 | 01:50 AM
  #59
JKennedy1612's Avatar
Too expensive...
Old Jan 4, 2008 | 02:05 AM
  #60
Dam i want this kit, What are your IAT2 temps and coolant temps look at idle, WOT, and Decellerating points?
Old Jan 4, 2008 | 03:40 AM
  #61
Awesome ok thanks.
Old Jan 4, 2008 | 04:27 AM
  #62
2K5SS/SC?'s Avatar
I don't remember the IAT2's as it's been almost 5 months since I've had the kit on my car. I do remember them being lower than my car with the 2.6" pulley without methanol however, and it was averaging 100*+ outside during that time frame it was on the car. Mase is going to have to post that data as he logs it.
Old Jan 4, 2008 | 10:34 AM
  #63
stage2's Avatar
One Q......How much psi is this s/sc puching?
Old Jan 4, 2008 | 11:04 AM
  #64
Eng@RebelAutoWorxs's Avatar
Thanks for all the answers 2Ks, hope you're doing well in the sand box.
The price includes all the parts, no tuning or injectors.
Tuning is $250CDN and injectors with harness are $265CDN.
One upgrade that is going to be available after my conversation with the specialist at PSE (Supercharger rebuild company) is a kit which will feed oil to the SC straight from the engine, this way it always is getting a fresh feed. This kit can be directly purchased from them.
We want this kit to last even longer than the Eaton.
Old Jan 4, 2008 | 11:44 AM
  #65
HOT CARLS SS's Avatar
Nice too know Mase....Now I just have too try that b**ch out! How is it running so far?
Colin
Old Jan 4, 2008 | 11:50 AM
  #66
wait that $3445 price is in CDN? so what is that in US dollars?
Old Jan 4, 2008 | 12:08 PM
  #67
Darkmanx's Avatar
LOL OH CHIT i just realized that wow guess ima wait for the tvs
Old Jan 4, 2008 | 12:41 PM
  #68
LE5CAV's Avatar
BETWEEN 3440 AND 3450 DEPENDING ON THE MARKET
BUT ITS ABOUT THE SAME
Old Jan 4, 2008 | 01:26 PM
  #69
i dont think its a bad price for how much horsepower//torque ur gonna gain out of it, and 2k5 do u notice a big difference in the reaction of your car with that ts?
Old Jan 4, 2008 | 01:35 PM
  #70
D4u2s0t's Avatar
edit: scratch that... already answered my own question
Old Jan 4, 2008 | 01:43 PM
  #71
an0malous's Avatar
after seeing this picture, i have that same question.
I dont see $3500 worth of parts sitting here.
Old Jan 4, 2008 | 01:46 PM
  #72
elecblue06's Avatar
the blower itself is probably like 2500 of that price tag just like a new m62 would be if you had to buy it from the dealer
Old Jan 4, 2008 | 01:50 PM
  #73
an0malous's Avatar
last i remember the blower is worth around $1400?
Old Jan 4, 2008 | 01:56 PM
  #74
D4u2s0t's Avatar
i just found a brand new one on pse for 1600. so i guess 2 adapters, snout, and injectors cost $2,000? what am i missing.
Old Jan 4, 2008 | 01:57 PM
  #75
Onyxd04Redline's Avatar
You can get a 2.3L Whipple supercharger on superchargersonline for 1894 dollars. I remember the 1.2L used to go for like 1400 before whipple said **** it and stayed with the larger units.
An extreme markup
