Rough Night!
Old Nov 11, 2009 | 12:50 PM
  #51
Matt M's Avatar
Originally Posted by schamsy
This is why you are a joke... lol... You comparing my nearly stock GN to a gutted ugly ass GP that you tossed thousands of dollars at is apples to oranges... Now lets compare apples to apples...
http://www.youtube.com/watch?v=0lzqI7wvZvU
..ouch.. haha owned!
I was simply saying I dont need my cobalt to go fast... If I did I could go elsewhere and make it go just as fast as any **** you have out there. But I dont want to spend $10,000+ to do it.
Back to the GN vs your "GP" that car in the vid vs your GP would be apples to apples... I was not comparing my 3.8 against yours... just shows your professionalism=0 AGAIN!
ZZP= FTL
Ok, so you are telling us that it's apples to oranges to compare our FWD GP 3800 against your RWD GN 3.8, but then you proceed to say that apples to apples would be putting us up against a RWD small block V8 powered GN? I can't think of any similarities between our GP and Chow's GN other than they both run 8s.
As far as "professionalism", there is a time and a place for it. However, most people posting on a Cobalt message forum would prefer to have vendors around to gossip with, call out, follow their progress, have emails or PMs answered day/night even on weekends or holidays, etc... It's a different approach, but most forum members prefer it. Acting in a strict, professional manner would mean 9-5, by the book tech support. No one would be contacting the owner or having questions answered after hours. It would be one way or the other, not mix and match.
Old Nov 11, 2009 | 12:51 PM
  #52
VeNoM0713's Avatar
hey ryan, what brand/ exact size of slicks are you running? just curious because ill be buying a set next spring
Old Nov 11, 2009 | 12:54 PM
  #53
InfraRedline's Avatar
Very well put Matt
Old Nov 11, 2009 | 01:14 PM
  #54
jimbos'ss's Avatar
check the crankshaft when you go to install a new key way, when they break, they tend to take a chunk out of the crank shaft.
jim
Old Nov 12, 2009 | 04:21 PM
  #55
LoveMyREDLINE's Avatar
130mph yikes !
What other companys dump thousands and thousands od dollars, just to brag to a bunch of 18 year old kids? exactly!
How come this guy hasnt been hit with the Ban Hammer?
Old Nov 13, 2009 | 07:55 AM
  #56
Ryan@zzp's Avatar
Originally Posted by LoveMyREDLINE
130mph yikes !
Maybe 140 next year, who knows, lol.
Old Nov 13, 2009 | 08:50 AM
  #57
VeNoM0713's Avatar
maybe you didnt see my post so ill ask ya again.. what brand/size slicks are you running? thanks.
Old Nov 13, 2009 | 09:01 AM
  #58
Matt M's Avatar
Mickey Thompson 26x10 ET Drags on 15" rims.
Old Nov 21, 2009 | 09:45 AM
  #59
hatrickstu's Avatar
really good times man. car sounds nasty as well
Old Nov 21, 2009 | 12:38 PM
  #60
hungryhip-ccp's Avatar
any update on what happen? did you wipe out the crank/bearings? tear it apart yet?
Old Nov 28, 2009 | 10:29 AM
  #61
damien's Avatar
bump, have you fixed the crank key? is it even replaceable?
Old Nov 28, 2009 | 02:17 PM
  #62
sometimes no news is good news???
Old Nov 28, 2009 | 03:55 PM
  #63
Matt M's Avatar
Ryan hasn't worked on his car yet. We have been busy with a lot of new projects.
As far as the motor being bad, I think it should be alright. At first we didn't know how there would have been any oil pressure without the crank driving the oil pump. Then I remembered that any time there is significant airflow through the supercharger, the rotors spin. Spinning rotors means a spinning supercharger pulley, which means a spinning crank pulley, which means a spinning oil pump. The keyway is most likely destroyed, but we should be able to come up with a fix for that.
Old Nov 28, 2009 | 11:52 PM
  #64
yeah, hopefully its ok. a tad off topic,
on the S256 you guys run, is the turbine wheel the 69.5/61.5 or the 74/64? will the smaller wheel help spool the larger wheel will decrease back pressure from what i understand? which one would be best for hahn kit looking to swap to BW S256
i think i would like the spool over the decreased back pressure, as the turbo should flow fine on a cobalt (as proven by you guys)
is the non extended tip any good? i plan on never running 30+psi or more than 450whp max (stock cams), i would like to save the 400+ dollars and get the non et. @ 49lb/min it should still get me to my goals? you guys are the only cobalts running the bw's and great times too!
Old Nov 29, 2009 | 02:57 AM
  #65
Matt M's Avatar
I would recommend spending the extra on the extended tip setup. At 15psi it wouldn't matter, but once you get up into the 20+ psi range, there is a big difference.
We run the 74/64 exhaust wheel in a .55 AR housing. It works well, but doesn't spool nearly as soon as the stock turbo.(obviously) I wouldn't mind trying the 69.5/61.5 to see how it compares. If it still works well up to 450whp, it would be nice to gain the quicker response.
Old Nov 29, 2009 | 07:21 AM
  #66
HunterKiller89's Avatar
he just got owned so god damn hard right there! Matt, have I ever told you I love you?
Old Nov 29, 2009 | 01:10 PM
  #67
jimbos'ss's Avatar
swap crankshafts, thats what i did. unless you know a good crank guy that can weld material back onto the crank and remachine it back to spec. i know theres a guy in cali that does.
Old Nov 29, 2009 | 03:50 PM
  #68
thanks, i think im gonna try the smaller wheel, the compressor housing on the ett is super sexy also...
do you know what size the gt 4 bolt exit is? 3" or 2.75"? i think you guys are running the 5 bolt exit though? and the comp outlet for charge pipe is it 2.5"?
thanks.
Old Nov 30, 2009 | 01:09 AM
  #69
elecblue06's Avatar
muhahahaha stoker that lnf DO IT!
Old Nov 30, 2009 | 10:42 AM
  #70
Matt M's Avatar
Uhh, not that I recall.
thanks.
We are using the 5 bolt on the LNF(with V-band flange welded on) and .70AR V-band on the twincharge setups.
Old Dec 1, 2009 | 07:32 AM
  #71
USMCFieldMP's Avatar
Rattlesnake Race Shop
Nice, Nice times.
Old Dec 1, 2009 | 12:17 PM
  #72
I didnt even think of that, but since the housing is SS it will be very easy to just get a 3" v-band clamp flange and weld it on for a mere portion of the cost for a adapter!
I thank you for your time/info.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
bigdeertz
Nov 17, 2016 09:41 AM
Oct 13, 2015 09:32 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
Trav3480
Sep 28, 2015 02:46 PM
